基于7421的超声波避障
696|1
 楼主| 刘捣蛋 发表于 2019-6-13 20:31 | 显示全部楼层 |阅读模式
我的程序有点乱,请大神们批评指出
#include "Function_Init.H"
˵Ã÷£º±¾Àý³ÌÑÝʾÁËADC¶ÁÈ¡´«¸ÐÆ÷µÄÊýÖµ£¬È»ºóÅжϵ±Ç°´«¸ÐÆ÷ÊÇ·ñ´¦ÓÚºÚɫѭ¼£ÏßÇøÓò£¬
Èç¹û´«¸ÐÆ÷ÔÚºÚÉ«ÇøÓò£¬¾ÍµãÁÁ¶ÔÓ¦µÄLED×÷Ϊָʾ¡£
±àд£ºËïºìÁÁ
ʱ¼ä£º2019.4.29
extern void ADC_Init(uint Channel);
extern void void Timer_Init(void);
extern void PWM_Init(void);
extern void PWM_ctr(uchar pwmL,uchar pwmR);
extern void ADC_ch();
extern void Uart0_Init(uint Freq,unsigned long int baud);
extern bit Uart0SendFlag ;
extern uint adcL,adcR;
uchar pwmL,pwmR;
#define uint unsigned int
#define uchar unsigned char
#define TRIG P1_1
#define ECHO  p1_0
unsigned int  time=0;
unsigned int  timer=0;
unsigned int k = 0;
unsigned int s = 0;
void main(void)
        uint m,k;
        IO_Init();  //Òý½Å³õʼ»¯
        PWM_Init();  //PWM³õʼ»¯
        Uart0_Init(16,9600);
        pwmL=100,pwmR=100;//Õ¼¿Õ±È³õÖµ
        P1CON|=0x01;
  P1CON|=~0x02;
        TOMD = 0x21;
        TH0 = 0;
        TL0 = 0;
        EA = 1;
        IE |=0X44;       //¿ªÆôADCÖжÏ
        while(1)
        {WDTCON |= 0x10;                    //Çå¿´ÃÅ
          ADC_ch();
                for(m=0;m<500;m++);//ÑÓʱһ¶Îʱ¼ä£¬ ÒÔÅäºÏС³µÔ˶¯ËٶȽÏÂýµÄÇé¿ö
                if((adcR>3300) &&(adcL<2800))  //ÓÒ´«¸ÐÆ÷λÓÚºÚÉ«ÇøÓò£¬×ó´«¸ÐÆ÷λÓÚ°×É«ÇøÓò
                {if(pwmL<250)pwmL++;//Ìá¸ß×óµç»úÇý¶¯ÐźŵÄÕ¼¿Õ±È£¬ÊµÏÖÓÒת
                        pwmR=400;
                        P1&=~0X80; //µãÁÁP1.7Òý½ÅµÄLED,D5
                  P1|=0X40;  //¹Ø±ÕLED
                        PWM_ctr(pwmL,pwmR);
                                        if((adcR>3300) &&(adcL>3300))  //×ó,ÓÒ´«¸ÐÆ÷λÓÚºÚÉ«ÇøÓò£¬
                        pwmR=150;
                        pwmL=pwmR;  //Ö±ÐÐ
                        PWM_ctr(pwmL,pwmR);
                        P1|=0X80;  //¹Ø±ÕLED
                        P1&=~0X40; //µãÁÁP1.6Òý½ÅµÄLED,D6
                        if((adcR<2800) &&(adcL<2800))  //×ó,ÓÒ´«¸ÐÆ÷λÓÚ°×É«ÇøÓò£¬
                {pwmR=0;  //Ô­µØÐýת
                        pwmL=0;
                        PWM_ctr(pwmL,pwmR);
                                if((adcR<2800) &&(adcL>3300))  //×ó´«¸ÐÆ÷λÓÚºÚÉ«ÇøÓò£¬ÓÒ´«¸ÐÆ÷λÓÚ°×É«ÇøÓò
                {if(pwmR<150)pwmR++;//Ìá¸ßÓÒµç»úÇý¶¯ÐźŵÄÕ¼¿Õ±È£¬×óʵÏÖת
                        pwmL=800;
                        PWM_ctr(pwmL,pwmR);
                                P1|=0X80;  //¹Ø±ÕLED
                         P1|=0X40;  //¹Ø±ÕLED
          k++;
                if(k>=100)                //ÿѭ»·1000´Î£¬·¢ËÍÒ»´Î¹âµç´«¸ÐÆ÷Êý¾Ý
    { SS0DAT = adcL>>8;  //×ó´«¸ÐÆ÷Êý¾Ý¸ß×Ö½Ú
                while(!Uart0SendFlag);
                Uart0SendFlag = 0;
                SS0DAT = (uchar)adcL;  //×ó´«¸ÐÆ÷Êý¾ÝµÍ×Ö½Ú
                Uart0SendFlag = 0;
                  SS0DAT = adcR>>8;  //ÓÒ´«¸ÐÆ÷Êý¾Ý¸ß×Ö½Ú
                Uart0SendFlag = 0;
                SS0DAT = (uchar)adcR;  //ÓÒ´«¸ÐÆ÷Êý¾ÝµÍ×Ö½Ú
                Uart0SendFlag = 0;
          k=0;
                void Timer_Count(void);
         if(s==)
void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.88)/10;     //Ëã³öÀ´ÊÇMM
        //³¬³ö²âÁ¿·¶Î§ÏÔʾ¡°-¡±
void Delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=587;j>0;j--)
void Micro Wait( int timeout )
        while(timeout--)
                TRIG = 1;
    asm"NOP";
                asm"NOP";
    asm"NOP";
                 asm"NOP";
                 asm"NOP";
                 asm"NOP";
                 asm"NOP";
                 asm"NOP";
                TRIG = 0;
void delay_10us(void)
        Micro Wait(10);
                 TR0=0;                            //¿ªÆô¼ÆÊý
             while(ECHO==0);                        //µ±RXΪ1¼ÆÊý²¢µÈ´ý
             TR0=1;                                //¹Ø±Õ¼ÆÊý
         Conut();                        //¼ÆËã
void zd0() interrupt 1
          TR0 = 0;
         TL0 = 0;
dirtwillfly 发表于 2019-6-13 22:52 | 显示全部楼层
注释都乱码了。
建议代码以“添加代码文字”的方式加入到帖子中
