CX3 GPIO 中断不响应求助
893|1
byrin|  楼主 | 2019-6-23 13:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi All,
    最近使用Cypress CY3065学习GPIO操作。现在结果是基本的控制IO输出,和非中断输入读取电平是OK的。但中断输入却一直无法触发。不知道问题出在哪?麻烦坛友高人指点一二。下面是CX3的中断配置!
CyU3PGpioClock_t gpioClock;
    /* Init the GPIO module */
    gpioClock.fastClkDiv = 2;
    gpioClock.slowClkDiv = 0;
    gpioClock.simpleDiv = CY_U3P_GPIO_SIMPLE_DIV_BY_2;
    gpioClock.clkSrc = CY_U3P_SYS_CLK;
    gpioClock.halfDiv = 0;
    status = CyU3PGpioInit(&gpioClock, CyCX3AppGpioCB);
    if( status != CY_U3P_SUCCESS)
        CyU3PDebugPrint (4, "\n\rAppInit:GPIOInit Err = 0x%x",status);
        CyCx3AppErrorHandler(status);
    status = CyU3PDeviceGpioOverride(20, CyTrue);
    if(status != 0)
        CyU3PDebugPrint (4, "GPIO Override failed, Error Code = %d\n",status);
        CyCx3AppErrorHandler (status);
    gpioConfig.outValue    = CyFalse;  //默认输出低电平
    gpioConfig.driveLowEn  = CyFalse; //不允许输出低
    gpioConfig.driveHighEn = CyFalse; //不允许输出高
    gpioConfig.inputEn     = CyTrue; //输入使能
    gpioConfig.intrMode    = CY_U3P_GPIO_INTR_POS_EDGE;
    status = CyU3PGpioSetSimpleConfig (20, &gpioConfig);
    if (status != CY_U3P_SUCCESS)
        CyU3PDebugPrint (4, "GPIO Set Config Error, Error Code = %d\n", status);
byrin|  楼主 | 2019-6-25 10:19 | 只看该作者
都没人互动,算了,撤了。问题仍在。
