TDS510连接不上DSP,请指教
2616|1
zyok|  楼主 | 2011-11-7 11:37 | 显示全部楼层 |阅读模式
连接时返回错误码:
Error connecting to the target:
Error 0x80000200/-1073
Fatal Error during: OCS,
Bad Target Silicon Revision Number
Please check your multi-processor configuration.
The number of devices in the JTAG scan path
must be correct for the silicon revision to be read.
Or, you may have selected the wrong DSP device driver.
Sequence ID: 0
Error Code: -1073
Error Class: 0x80000200
I/O Port = 240
Board Name: C671x TDS510USB 2.0 Emulator
Cpu Name: CPU_1
遇到过的大侠请指教。。谢谢
zyok|  楼主 | 2011-11-8 09:05 | 显示全部楼层
汗!整版被水军淹没...
个人签名:这个签名No.1,最有特色..
65
