[DemoCode下载]
M261的串口自动波特率
366|8
xuanhuanzi|  楼主 | 2019-6-24 23:57 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
*           Show how to use auto baud rate detection function.
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2019 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
/* Define functions prototype        */
void AutoBaudRate_Test(void);
void AutoBaudRate_TxTest(void);
void AutoBaudRate_RxTest(void);
void SYS_Init(void)
    /* Set PF multi-function pins for XT1_OUT(PF.2) and XT1_IN(PF.3) */
    SYS->GPF_MFPL = (SYS->GPF_MFPL & (~SYS_GPF_MFPL_PF2MFP_Msk)) | SYS_GPF_MFPL_PF2MFP_XT1_OUT;
    SYS->GPF_MFPL = (SYS->GPF_MFPL & (~SYS_GPF_MFPL_PF3MFP_Msk)) | SYS_GPF_MFPL_PF3MFP_XT1_IN;
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Enable PLL */
    CLK->PLLCTL = CLK_PLLCTL_128MHz_HIRC;
    /* Waiting for PLL stable */
    CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
    /* Select HCLK clock source as PLL and HCLK source divider as 2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART1SEL_HXT, CLK_CLKDIV0_UART1(1));
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & (~(UART0_RXD_PB12_Msk | UART0_TXD_PB13_Msk))) | UART0_RXD_PB12 | UART0_TXD_PB13;
    /* Set PB multi-function pins for UART1 RXD(PB.6) and TXD(PB.7) */
    SYS->GPB_MFPL = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB6MFP_Msk)) | SYS_GPB_MFPL_PB6MFP_UART1_RXD;
    SYS->GPB_MFPL = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB7MFP_Msk)) | SYS_GPB_MFPL_PB7MFP_UART1_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
void UART1_Init(void)
    /* Init UART        */
    /* Reset UART1 */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\nUART Sample Program\n");
    /* UART auto baud rate sample function */
    AutoBaudRate_Test();
    printf("\nUART Sample Program End\n");
    while(1);
/*  Auto Baud Rate Function Test        */
void AutoBaudRate_Test()
    uint32_t u32Item;
    printf("\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|     Pin Configure                                         |\n");
    printf("|  ______                                            _____  |\n");
    printf("| |      |                                          |     | |\n");
    printf("| |Master|--UART1_TXD(PB.7)  <==>  UART1_RXD(PB.6)--|Slave| |\n");
    printf("| |______|                                          |_____| |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|     Auto Baud Rate Function Test                          |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code needs two boards. One is Master and    |\n");
    printf("|    the other is slave.  Master will send input pattern    |\n");
    printf("|    0x1 with different baud rate. It can check if Slave    |\n");
    printf("|    calculates correct baud rate.                          |\n");
    printf("|  Please select Master or Slave test                       |\n");
    printf("|  [0] Master    [1] Slave                                  |\n");
    u32Item = getchar();
    if(u32Item == '0')
        AutoBaudRate_TxTest();
    else
        AutoBaudRate_RxTest();
/*  Auto Baud Rate Function Tx Test        */
void AutoBaudRate_TxTest()
    uint32_t u32Item;
    do
        printf("\n");
        printf("|     Auto Baud Rate Function Test (Master)                 |\n");
        printf("| [1] baud rate 38400 bps                                   |\n");
        printf("| [2] baud rate 57600 bps                                   |\n");
        printf("| [3] baud rate 115200 bps                                  |\n");
        printf("|                                                           |\n");
        printf("| Select baud rate and master will send 0x1 to slave ...    |\n");
        printf("| Quit                                              - [ESC] |\n");
        printf("+-----------------------------------------------------------+\n\n");
        if(u32Item == 27) break;
        printf("%c\n", u32Item);
        /* Set different baud rate */
        switch(u32Item)
            case '1':
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 38400);
                break;
            case '2':
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 57600);
                break;
            default:
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
                break;
        /* Send input pattern 0x1 for auto baud rate detection bit length is 1-bit */
        UART_WRITE(UART1, 0x1);
    while(1);
/*  Get UART Baud Rate Function        */
uint32_t GetUartBaudrate(UART_T* uart)
    uint8_t u8UartClkSrcSel = 0, u8UartClkDivNum = 0;
    uint32_t au32ClkTbl[4] = {__HXT, 0, __LXT, __HIRC};
    uint32_t u32BaudDiv;
    /* Get UART clock source selection and UART clock divider number */
    switch((uint32_t)uart)
        case UART0_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL1 & CLK_CLKSEL1_UART0SEL_Msk) >> CLK_CLKSEL1_UART0SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV0 & CLK_CLKDIV0_UART0DIV_Msk) >> CLK_CLKDIV0_UART0DIV_Pos;
            break;
        case UART1_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL1 & CLK_CLKSEL1_UART1SEL_Msk) >> CLK_CLKSEL1_UART1SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV0 & CLK_CLKDIV0_UART1DIV_Msk) >> CLK_CLKDIV0_UART1DIV_Pos;
            break;
        case UART2_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL3 & CLK_CLKSEL3_UART2SEL_Msk) >> CLK_CLKSEL3_UART2SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV4 & CLK_CLKDIV4_UART2DIV_Msk) >> CLK_CLKDIV4_UART2DIV_Pos;
            break;
        case UART3_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL3 & CLK_CLKSEL3_UART3SEL_Msk) >> CLK_CLKSEL3_UART3SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV4 & CLK_CLKDIV4_UART3DIV_Msk) >> CLK_CLKDIV4_UART3DIV_Pos;
            break;
        case UART4_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL3 & CLK_CLKSEL3_UART4SEL_Msk) >> CLK_CLKSEL3_UART4SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV4 & CLK_CLKDIV4_UART4DIV_Msk) >> CLK_CLKDIV4_UART4DIV_Pos;
            break;
        case UART5_BASE:
            u8UartClkSrcSel = (CLK->CLKSEL3 & CLK_CLKSEL3_UART5SEL_Msk) >> CLK_CLKSEL3_UART5SEL_Pos;
            u8UartClkDivNum = (CLK->CLKDIV4 & CLK_CLKDIV4_UART5DIV_Msk) >> CLK_CLKDIV4_UART5DIV_Pos;
            break;
    /* Get PLL clock frequency if UART clock source selection is PLL */
    if(u8UartClkSrcSel == 1)
        au32ClkTbl[u8UartClkSrcSel] = CLK_GetPLLClockFreq();
    /* Get UART baud rate divider */
    u32BaudDiv = (uart->BAUD & UART_BAUD_BRD_Msk) >> UART_BAUD_BRD_Pos;
    /* Calculate UART baud rate if baud rate is set in MODE 0 */
    if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE0)
        return ((au32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32BaudDiv + 2)) >> 4;
    /* Calculate UART baud rate if baud rate is set in MODE 2 */
    else if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE2)
        return ((au32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32BaudDiv + 2));
    /* Calculate UART baud rate if baud rate is set in MODE 1 */
    else if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_BAUDM1_Msk)
        return ((au32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32BaudDiv + 2)) / (((uart->BAUD & UART_BAUD_EDIVM1_Msk) >> UART_BAUD_EDIVM1_Pos) + 1);
    /* Unsupported baud rate setting */
    else
        return 0;
/*  Auto Baud Rate Function Rx Test        */
void AutoBaudRate_RxTest()
    /* Enable auto baud rate detect function */
    UART1->ALTCTL |= UART_ALTCTL_ABRDEN_Msk;
    printf("\nreceiving input pattern... ");
    /* Wait until auto baud rate detect finished or time-out */
    while((UART1->ALTCTL & UART_ALTCTL_ABRIF_Msk) == 0);
    if(UART1->FIFOSTS & UART_FIFOSTS_ABRDIF_Msk)
        /* Clear auto baud rate detect finished flag */
        UART1->FIFOSTS = UART_FIFOSTS_ABRDIF_Msk;
        printf("Baud rate is %dbps.\n", GetUartBaudrate(UART1));
    else if(UART1->FIFOSTS & UART_FIFOSTS_ABRDTOIF_Msk)
        /* Clear auto baud rate detect time-out flag */
        UART1->FIFOSTS = UART_FIFOSTS_ABRDTOIF_Msk;
        printf("Time-out!\n");
/*** (C) COPYRIGHT 2019 Nuvoton Technology Corp. ***/
对波特率自动设置感兴趣的可以学习一下。
这个例子通用性很强
21mengnan| | 2019-6-24 23:59 | 显示全部楼层
多谢分享,我去下载看看。
zhuotuzi| | 2019-6-26 00:01 | 显示全部楼层
学习一下这个方法。
mintspring| | 2019-6-27 00:01 | 显示全部楼层
这个功能很好。
heisexingqisi| | 2019-6-27 00:36 | 显示全部楼层
例子很丰富,要不然真不好学。
xinpian101| | 2019-6-27 23:45 | 显示全部楼层
这属于硬件实现,还是软件实现
这属于硬件实现,还是软件实现
