[DemoCode下载]
N76E003的启动代码
746|3
huangcunxiake|  楼主 | 2019-6-30 22:33 | 显示全部楼层 |阅读模式
$NOMOD51
;  This file is part of the C51 Compiler package
;  Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
;  STARTUP.A51:  This code is executed after processor reset.
;  To translate this file use A51 with the following invocation:
;     A51 STARTUP.A51
;  To link the modified STARTUP.OBJ file to your application use the following
;  BL51 invocation:
;     BL51 <your object file list>, STARTUP.OBJ <controls>
;  User-defined Power-On Initialization of Memory
;  With the following EQU statements the initialization of memory
;  at processor reset can be defined:
;               ; the absolute start-address of IDATA memory is always 0
IDATALEN        EQU     80H     ; the length of IDATA memory in bytes.
XDATASTART      EQU     0H      ; the absolute start-address of XDATA memory
XDATALEN        EQU     2FFH     ; the length of XDATA memory in bytes.
PDATASTART      EQU     0H      ; the absolute start-address of PDATA memory
PDATALEN        EQU     0H      ; the length of PDATA memory in bytes.
;  Notes:  The IDATA space overlaps physically the DATA and BIT areas of the
;          8051 CPU. At minimum the memory space occupied from the C51
;          run-time routines must be set to zero.
;  Reentrant Stack Initilization
;  The following EQU statements define the stack pointer for reentrant
;  functions and initialized it:
;  Stack Space for reentrant functions in the SMALL model.
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
IBPSTACKTOP     EQU     0FFH+1  ; set top of stack to highest location+1.
;  Stack Space for reentrant functions in the LARGE model.
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
XBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;  Stack Space for reentrant functions in the COMPACT model.
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
PBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;  Page Definition for Using the Compact Model with 64 KByte xdata RAM
;  The following EQU statements define the xdata page used for pdata
;  variables. The EQU PPAGE must conform with the PPAGE control used
;  in the linker invocation.
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
PPAGE           EQU     0       ; define PPAGE number.
PPAGE_SFR       DATA    0A0H    ; SFR that supplies uppermost address byte
;               (most 8051 variants use P2 as uppermost address byte)
; Standard SFR Symbols
ACC     DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                RSEG    ?STACK
                DS      1
                EXTRN CODE (?C_START)
                PUBLIC  ?C_STARTUP
                CSEG    AT      0
?C_STARTUP:     LJMP    STARTUP1
                RSEG    ?C_C51STARTUP
STARTUP1:
;Disable POR
        MOV 0C7H,#0AAH
        MOV 0C7H,#55H
        MOV 0FDH,#5AH
        MOV 0C7H,#0AAH
        MOV 0C7H,#55H
        MOV 0FDH,#0A5H
IF IDATALEN <> 0
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
  IF (LOW (XDATALEN)) <> 0
                MOV     R6,#(HIGH (XDATALEN)) +1
  ELSE
                MOV     R6,#HIGH (XDATALEN)
  ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; EXTRN CODE (?B_SWITCH0)
;               CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
                LJMP    ?C_START
                END
huangcunxiake|  楼主 | 2019-6-30 22:34 | 显示全部楼层
看文件前面的介绍还是比较老的,说明这个启动代码属于标准C51.
zhuomuniao110| | 2019-6-30 23:19 | 显示全部楼层
启动代码都是汇编的,所以要成为高手还要学汇编。
643757107| | 2019-7-2 22:24 | 显示全部楼层
要学一下汇编了,学这种,需要看什么
