[DemoCode下载]
M051的ADC突发模式
681|2
zhuomuniao110|  楼主 | 2019-6-30 23:35 | 显示全部楼层 |阅读模式
ADC, RS, ck, se
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 8 $
* $Date: 15/05/22 2:04p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate A/D conversion with burst mode.
*           In burst mode, ADC will sample and convert a specified channel continuously and
*           store the conversion result in FIFO buffers.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcBurstModeTest(void);
/* Define global variables and constants        */
#define BURST_COUNT 20
volatile uint32_t g_u32AdcDataCount;
uint16_t g_au16AdcData[BURST_COUNT];
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: ADC_GetConversionRate        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*      Return the A/D conversion rate (sample/second)                                                     */
/* Description:        */
/*   The conversion rate depends on the clock source of ADC clock.                                         */
/*   It only needs 21 ADC clocks to complete an A/D conversion.                                            */
static __INLINE uint32_t ADC_GetConversionRate()
    uint32_t u32AdcClkSrcSel;
    uint32_t u32ClkTbl[4] = {__HXT, 0, 0, __HIRC};
    /* Set the PLL clock frequency */
    u32ClkTbl[1] = PllClock;
    /* Set the system core clock frequency */
    u32ClkTbl[2] = SystemCoreClock;
    /* Get the clock source setting */
    u32AdcClkSrcSel = ((CLK->CLKSEL1 & CLK_CLKSEL1_ADC_S_Msk) >> CLK_CLKSEL1_ADC_S_Pos);
    /* Return the ADC conversion rate */
    return ((u32ClkTbl[u32AdcClkSrcSel]) / (((CLK->CLKDIV & CLK_CLKDIV_ADC_N_Msk) >> CLK_CLKDIV_ADC_N_Pos) + 1) / 21);
/* Function: AdcBurstModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC burst mode test.        */
void AdcBurstModeTest()
    uint8_t  u8Option;
    uint32_t u32Count;
    printf("\n\nConversion rate: %d samples/second\n", ADC_GetConversionRate());
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      ADC burst mode sample code                      |\n");
    printf("\nIn this test, software will get %d conversion results from the specified channel.\n", BURST_COUNT);
    while(1)
        printf("\nSelect input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only)\n");
        printf("  Other keys: exit burst mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            printf("%d conversion results of channel 2:\n", BURST_COUNT);
            /* Set the ADC operation mode as burst, input mode as single-end and enable the analog input channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_BURST, 0x1 << 2);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* Enable the ADC interrupt */
            ADC_EnableInt(ADC, ADC_ADF_INT);
            NVIC_EnableIRQ(ADC_IRQn);
            /* Reset the ADC data counter and start A/D conversion */
            g_u32AdcDataCount = 0;
            ADC_START_CONV(ADC);
            while(g_u32AdcDataCount < BURST_COUNT);
            /* Stop A/D conversion */
            ADC_STOP_CONV(ADC);
            /* Disable the ADC interrupt */
            ADC_DisableInt(ADC, ADC_ADF_INT);
        else if(u8Option == '2')
            printf("%d conversion results of differential input channel pair 1:\n", BURST_COUNT);
            /* Set the ADC operation mode as burst, input mode as differential and
                             enable analog input channel 2 for differential input channel pair 1*/
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_BURST, 1 << 2);
            ADC_POWER_ON(ADC);
            ADC_STOP_CONV(ADC);
        else
            return ;
        for(u32Count = 0; u32Count < BURST_COUNT; u32Count++)
            printf("Conversion result: 0x%X\n", g_au16AdcData[u32Count]);
        /* Change operation mode to clear burst mode FIFO buffers */
        ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, 2);
/* ADC interrupt handler        */
void ADC_IRQHandler(void)
    while(ADC_IS_DATA_VALID(ADC, 0)) /* Check the VALID bits */
        if(g_u32AdcDataCount >= BURST_COUNT)
            return;
        /* In burst mode, the software always gets the conversion result of the specified channel from channel 0 */
        g_au16AdcData[g_u32AdcDataCount++] = (uint16_t)ADC_GET_CONVERSION_DATA(ADC, 0);
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* clear the A/D conversion flag */
/* MAIN function        */
main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Burst Mode test */
    AdcBurstModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
这个模式大家可以好好阅读一下手册,非常有用。
wahahaheihei| | 2019-6-30 23:37 | 显示全部楼层
这个概念的第一次听说,是不是这个模式发生后,就一直在执行这个。
