[FPGA]
第一个verilog的LED程序,仿真成功
1567|9
因为偶的板子是Cyclone系列的片子,实在太老,所以用的quartus II 9.1
先感受下verilog结构和仿真操作,改天烧到俺的板子试试
仿真要修改下程序里计数器的最大值,实际在板子上跑时,再改回实际所需的值,比如这里流水灯的200ms间隔
module FPGA_EP1C6Q240_led (
        input sys_clk,
        input sys_rst_n,
        output reg [3:0] led,
        //7 seg shumaguan  segment select
        output reg [7:0] seg_sel,
        //7 seg shumaguan  bit  select
        output reg [1:0] bit_sel
reg [23:0] counter;
reg [7:0] magic_liushui_counter;
always @(posedge sys_clk or negedge sys_rst_n)
begin
        if(!sys_rst_n)
                begin
                        counter <= 24'd0;
                        magic_liushui_counter <= 8'd0;
                end
        //else if(counter < 24'd1000_0000)
        else if(counter < 24'd4)
                counter <= counter + 24'd1;
        //else if(counter == 24'd1000_0000)
        else if(counter == 24'd4)
                begin
                        counter <= 24'd0;
                        if(magic_liushui_counter < 8'd7)
                                magic_liushui_counter <= magic_liushui_counter + 8'd1;
                        else if(magic_liushui_counter == 8'd7)
                end
end
//high level turn on the led, low level turn off the led
//when counter == 24'd1000_0000, level 1 left shift,
//[3:0] = 0001 -> [3:0] = 0010 -> [3:0] = 0100 -> [3:0] = 1000
begin
        if(!sys_rst_n)
                begin
                        led <= 4'b0001;
                        //when power on, sgsel0 and sgsel1 are valid both.
                        bit_sel <= 2'b11;
                end
                begin
                        led[3:0] <= {led[2:0], led[3]};
                        if(magic_liushui_counter == 8'd0)
                                //seg a is on
                                seg_sel <= 8'b0000_0001;
                        else if(magic_liushui_counter == 8'd1)
                                //seg b is on
                                seg_sel <= 8'b0000_0010;
                        else if(magic_liushui_counter == 8'd2)
                                //seg g is on
                                seg_sel <= 8'b0100_0000;
                        else if(magic_liushui_counter == 8'd3)
                                //seg e is on
                                seg_sel <= 8'b0001_0000;
                        else if(magic_liushui_counter == 8'd4)
                                //seg d is on
                                seg_sel <= 8'b0000_1000;
                        else if(magic_liushui_counter == 8'd5)
                                //seg c is on
                                seg_sel <= 8'b0000_0100;
                        else if(magic_liushui_counter == 8'd6)
                                //seg g is on
                                //seg f is on
                                seg_sel <= 8'b0010_0000;
                end
        else
                led <= led;
end
endmodule
springvirus 2019-7-2 17:25 回复TA
@21ic小喇叭 :哈哈,感觉FPGA有些难
21ic小喇叭 2019-7-2 17:09 回复TA
恭喜
springvirus|  楼主 | 2019-7-2 11:28 | 只看该作者
参考了原子哥的代码
实际跑程序时,需要的激励模块
module main_test_flow_led();
        //f = 50MHz  T = 20ns
        parameter T = 20;
        reg main_sys_clk;
        reg main_sys_rst_n;
        //answer: use pin planner in quartus II to assign pins.
        wire [3:0] main_led;
        wire [7:0] main_seg_sel;
        wire [1:0] main_bit_sel;
        initial
                begin
                        main_sys_clk <= 1'b0;
                        main_sys_rst_n <= 1'b0;
                        //when power on, after 20ns, sys_rst_n pull high
                        # T main_sys_rst_n <= 1'b1;
                end
        //every 10ns , sys_clk toggle
        always # (T/2) main_sys_clk <= ~main_sys_clk;
        //in module main_led, make FPGA_EP1C6Q240 shilihua
        FPGA_EP1C6Q240_led  u0_flow_led (
                .sys_clk(main_sys_clk),
                .sys_rst_n(main_sys_rst_n),
                .led(main_led),
                .seg_sel(main_seg_sel),
                .bit_sel(main_bit_sel)
endmodule
zhangmangui| | 2019-7-2 23:13 | 只看该作者
FPGA是有些难度   尤其是到后期严谨的时序上
springvirus|  楼主 | 2019-7-3 10:37 | 只看该作者
在面包板社区,看到小梅哥的一系列博文,时序方面的
感觉写的不错
https://www.mianbaoban.cn/search.php?mod=blog&searchid=14&searchsubmit=yes&kw=%E5%B0%8F%E6%A2%85%E5%93%A5FPGA%E6%97%B6%E5%BA%8F%E5%88%86%E6%9E%90%E7%AC%94%E8%AE%B0
18971591125| | 2019-7-3 11:15 | 只看该作者
恭喜成功入“坑”,
feihufuture| | 2019-7-3 15:09 | 只看该作者
欢迎来到苦逼钱少荣耀,恶心老板还有5秒即将到达战场!
affe33| | 2019-7-6 07:09 | 只看该作者
楼主这是加班熬夜的开始 ,入坑了
fzwwj95| | 2020-5-15 18:09 | 只看该作者
恭喜!!!!!!!
