[技术问答]
n76e003串口1中断问题
865|6
n76e003 使用官方代码串口1,中断进不去,我是脱机下用ttl发串口数据让它进入中断看IO取反电平但是没看到电平变化估计没进入中断。请问大家有没有办法
643757107| | 2019-7-5 09:18 | 只看该作者
你中断里没任何实际操作,怎么可以看到效果。
734774645| | 2019-7-6 23:09 | 只看该作者
楼上说的是,没看到你有翻转。
xinpian101| | 2019-7-7 11:45 | 只看该作者
没看出来你对哪个IO取反。
xinpian101| | 2019-7-7 11:46 | 只看该作者
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 UART-1 Mode1 demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#define BUFFER_SIZE                16
UINT8  UART_BUFFER[BUFFER_SIZE],temp;
UINT16 u16CNT=0,u16CNT1=0;
bit riflag;
* FUNCTION_PURPOSE: Serial port 1 interrupt, echo received data.
* FUNCTION_INPUTS : P0.2(RXD) serial input
* FUNCTION_OUTPUTS: P1.6(TXD) serial output
* Following setting in Common.c
#if 0
//void InitialUART1_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
//                P02_Quasi_Mode;                //Setting UART pin as Quasi mode for transmit
//                P16_Quasi_Mode;                //Setting UART pin as Quasi mode for transmit
//          SCON_1 = 0x50;           //UART1 Mode1,REN_1=1,TI_1=1
//    T3CON = 0x08;           //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1), UART1 in MODE 1
//                clr_BRCK;
//#ifdef FOSC_160000
//                RH3    = HIBYTE(65536 - (1000000/u32Baudrate)-1);                  /*16 MHz */
//                RL3    = LOBYTE(65536 - (1000000/u32Baudrate)-1);                        /*16 MHz */
//#endif
//#ifdef FOSC_166000
//                RH3    = HIBYTE(65536 - (1037500/u32Baudrate));                          /*16.6 MHz */
//                RL3    = LOBYTE(65536 - (1037500/u32Baudrate));                                /*16.6 MHz */
//#endif
//    set_TR3;         //Trigger Timer3
#endif
void SerialPort1_ISR(void) interrupt 15
    if (RI_1==1)
    {                                       /* if reception occur */
        clr_RI_1;                             /* clear reception flag for next reception */
        UART_BUFFER[u16CNT] = SBUF_1;
        u16CNT ++;
                                riflag =1;
    if(TI_1==1)
        clr_TI_1;                             /* if emission occur */
* FUNCTION_PURPOSE: Main function
!!! N76E003 UART1 pin also occupied by debug pin,
please remove Nu-link or not in debug mode to test UART1 function.
External UART1 connect also disturb debug download
void main (void)
        P12_PushPull_Mode;                // For I/O toggle display
#if 0
//for Simple use UART1 transmit out
                InitialUART1_Timer3(115200);
    while(1)
    Send_Data_To_UART1(0x55);
#else
// For interrupt setting check receive
                set_ES_1;                                        //For interrupt enable
                set_EA;
                while(1)
                        if (riflag)
                                        P12 = ~ P12;                        //Receive each byte P12 toggle, never work under debug mode
                                        riflag = 0;
#endif
xinpian101| | 2019-7-7 11:47 | 只看该作者
给你个例子,你想翻转哪个,直接写入中断函数里就行了。
仔细看,里面有个标志位,在主函数里判断后再在主函数里翻转。
