[技术支持]
[HELP!] flash download failed - target DLL has been cancelled in Keil
1158|5
hsl1888|  楼主 | 2019-7-10 20:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
When updating code in Keil, it shows "flash download failed - target DLL has been cancelled" in Keil C51
Already reinstall HC-LINk, driver and K51, it can'r be solved. How can fix it?
hsl1888|  楼主 | 2019-7-10 20:45 | 只看该作者
it seems the bug comes from F0541 using 2-wire simulation
hsl1888|  楼主 | 2019-7-10 20:48 | 只看该作者
While trying to ground RST pin P2_4 before enter debugging mode, then it is ok. Hopefully, HolyChip can fix the issue!
guyufeng××| | 2019-9-30 19:38 | 只看该作者
hsl1888 发表于 2019-7-10 20:48
While trying to ground RST pin P2_4 before enter debugging mode, then it is ok. Hopefully, HolyChip  ...
I had the same problem.Could you please tell me how to solve it.Trying to ground RST pin P2_4 before enter debugging mode?
zlmin| | 2019-10-3 15:21 | 只看该作者
谢谢分享!谢谢分享!谢谢分享!谢谢分享!谢谢分享!
hsl1888|  楼主 | 2019-10-28 07:50 | 只看该作者
guyufeng×× 发表于 2019-9-30 19:38
I had the same problem.Could you please tell me how to solve it.Trying to ground RST pin P2_4 befo ...
yes!
