[开发工具]
Keil MDK STM32全系列 最新PACK包 下载汇总分享 MARK!
10518|17
shizes1989|  楼主 | 2019-7-24 09:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(点击上方目录可以快速定位下载,附更新记录)
在Keil官网上下载PACK包速度特别慢,为方便大家下载STM32的PACK包,特将STM32所有系列的PACK上传至网盘供大家下载,点击普通下载,
下载后将扩展名改为.pack即可双击打开,后面会持续更新。
STM32库函数下载请转帖:https://bbs.21ic.com/icview-2837448-1-1.html
# Keil.STM32F0xx_DFP.2.0.0.pack
下载链接:https://u20384633.ctfile.com/fs/20384633-377184535
Version: 2.0.0 (2018-01-18)  更新记录:
This DFP works either with STM32CubeMX (STM32CubeMX V4.23.0 and STM32Cube_FW_F0 V1.9.0 or higher) or Standalone (no support for STM32CubeMX).
STM32CubeMX is mandatory for use of CMSIS-Driver and MDK-Middleware.
- New projects require the component 'Device:STM32Cube Framework:STM32CubeMX' from the STM32Cube MX bundle for configuration of pins and clocks
   via STM32CubeMX.
This pack only contains a subset of the files from STM32Cube_FW_F0 version 1.9.0 (ST Drivers, STM32Cube documentation and fonts).
Updated documentation for STM32Cube Framework usage.
Device support:
- Updated device names to match STM32CubeMX notation
- Added DBGMCU INI files configuring debug settings of the target for debug units without support for debug sequences
- Updated documentation.
CMSIS Driver:
- Added CAN driver
- Added I2C driver
- Added SPI driver
- Added UART/USART/IrDA/SmartCard driver
- Added USB Device driver
Board support:
- Added STM32072B-EVAL and STM32091C-EVAL
Example projects:
- added emWin graphics library on STM32072B-EVAL and STM32091C-EVAL boards
- added USB Device HID on STM32F072-Discovery Board
- updated all examples to use STM32CubeMX integration
新的小白 2020-7-23 08:54 回复TA
很有用的资料,但是这个下载方式???
风云ljh| | 2019-7-24 09:24 | 只看该作者
怎么下载不了呢
shizes1989|  楼主 | 2019-7-24 09:59 | 只看该作者
可以下载,点击普通下载后等几秒就开始下载了
heimaojingzhang| | 2019-8-13 10:48 | 只看该作者
非常感谢楼主分享
keaibukelian| | 2019-8-13 10:56 | 只看该作者
非常感谢楼主分享
labasi| | 2019-8-13 11:00 | 只看该作者
非常感谢楼主分享
燕子flying| | 2019-9-11 11:48 | 只看该作者
谢楼主分享
香水城| | 2019-9-12 10:43 | 只看该作者
这个MDK一般都会自动更新的,如果下载的话,建议去ARM网站下载。
www.keil.com/pack
sxwnwxj| | 2020-2-21 16:46 | 只看该作者
弱弱问下,下载了某个 pack后怎么安装?
shilingdao2005| | 2020-2-26 12:07 | 只看该作者
611zhaogw| | 2020-4-21 10:52 | 只看该作者
忧忧| | 2020-7-19 12:43 | 只看该作者
G0 系列pack 包是假的
zsljs| | 2020-8-25 23:30 | 只看该作者
必须点赞你!
liaogf| | 2020-8-26 14:31 | 只看该作者
非常感谢楼主分享
Rivenrealsense| | 2020-8-27 15:22 | 只看该作者
非常感谢楼主分享
马六甲海峡| | 2020-9-3 19:32 | 只看该作者
谢谢分享。
hyxstrive| | 2021-8-25 22:00 | 只看该作者
还能下载吗
