CMAKE如何编译出静态库
1207|1
limee|  楼主 | 2019-8-16 15:20 | 显示全部楼层 |阅读模式
经过一段时间的折腾,我也入坑CMAKE了
Linking CXX shared library libtag.dll
Creating library file: libtag.dll.a
[ 98%] Built target tag
Scanning dependencies of target tag_c
[100%] Building CXX object bindings/c/CMakeFiles/tag_c.dir/tag_c.obj
Linking CXX shared library libtag_c.dll
Creating library file: libtag_c.dll.a
[100%] Built target tag_c
为什么我编译出的库是共享的,静态库需要如何配置?
谢谢!
编译的时候还有这2个警告。
-- Could NOT find ZLIB (missing:  ZLIB_INCLUDE_DIR)
-- WARNING: you are using the obsolete 'PKGCONFIG' macro, use FindPkgConfig
-- PKGCONFIG() indicates that cppunit is not installed (install the package whic
h contains cppunit.pc if you want to support this feature)
-- Looking for __RTTI___ in Crun
-- Looking for __RTTI___ in Crun - not found
CMake Warning (dev) in CMakeLists.txt:
