[资料干货]
RK3399 MIPI显示驱动
2667|11
RK3399 MIPI显示驱动
eDP显示驱动
配置文件:"arch/arm64/boot/dts/rockchip/lcd-edp-for-sunychip-rk3399.dtsi"
如果需要去掉eDP屏,需要在arch/arm64/boot/dts/rockchip/rk3399-sunychip.dtsi中删除include "lcd-edp-for-sunychip.dtsi"
电源控制:enable-gpios= <&gpio4 rk_pd6="" gpio_active_high="">;
原理图:
timing时序
1.   timing0: timing0 {
         clock-frequency = <200000000>;
         hactive = <1536>;
         vactive = <2048>;
         hfront-porch = <12>;
         hsync-len = <16>;
         hback-porch = <48>;
         vfront-porch = <8>;
         vsync-len = <4>;
         vback-porch = <8>;
         hsync-active = <0>;
         vsync-active = <0>;
         de-active = <0>;
         pixelclk-active = <0>;
eDP信号从vopb输出
1.   &edp_in_vopl {
        status = "disabled";
&edp_in_vopb {
        status = "okay";
触摸
1.   &i2c4 {
    status = "okay";
    i2c-scl-rising-time-ns = <345>;
    i2c-scl-falling-time-ns = <11>;
    gsl3673: gsl3673@40 {
                compatible = "GSL,GSL3673";
                reg = <0x40>;
                screen_max_x = <1536>;
                screen_max_y = <2048>;
                irq_gpio_number = <&gpio4 RK_PC5 IRQ_TYPE_LEVEL_LOW>;
                rst_gpio_number = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>;
MIPI显示驱动
配置文件:"arch/arm64/boot/dts/rockchip/lcd-mipi-for-sunychip.dtsi"
电源控制:enable-gpios= <&gpio4 30="" gpio_active_high="">;
MIPI屏初始化:
1.   panel-init-sequence = [
      05 fa 01 11
      39 00 04 b9 f1 12 83
      39 00 1c ba 33 81 05 f9 0e 0e 00 00 00
            00 00 00 00 00 44 25 00 91 0a
            00 00 02 4f 01 00 00 37
      15 00 02 b8 25
      39 00 04 bf 02 11 00
      39 00 0b b3 0c 10 0a 50 03 ff 00 00 00
            00
      39 00 0a c0 73 73 50 50 00 00 08 70 00
      15 00 02 bc 46
      15 00 02 cc 0b
      15 00 02 b4 80
      39 00 04 b2 c8 12 30
      39 00 0f e3 07 07 0b 0b 03 0b 00 00 00
            00 ff 00 c0 10
      39 00 0d c1 53 00 1e 1e 77 e1 cc dd 67
            77 33 33
      39 00 07 c6 00 00 ff ff 01 ff
      39 00 03 b5 09 09
      39 00 03 b6 87 95
      39 00 40 e9 c2 10 05 05 10 05 a0 12 31
            23 3f 81 0a a0 37 18 00 80 01
            00 00 00 00 80 01 00 00 00 48
            f8 86 42 08 88 88 80 88 88 88
            58 f8 87 53 18 88 88 81 88 88
            88 00 00 00 01 00 00 00 00 00
            00 00 00 00
      39 00 3e ea 00 1a 00 00 00 00 02 00 00
            00 00 00 1f 88 81 35 78 88 88
            85 88 88 88 0f 88 80 24 68 88
            88 84 88 88 88 23 10 00 00 1c
            00 00 00 00 00 00 00 00 00 00
            00 00 00 00 00 30 05 a0 00 00
            00 00
      39 00 23 e0 00 06 08 2a 31 3f 38 36 07
            0c 0d 11 13 12 13 11 18 00 06
            08 2a 31 3f 38 36 07 0c 0d 11
            13 12 13 11 18
      05 32 01 29
panel-exit-sequence = [
      05 00 01 28
      05 00 01 10
MIPI初始化命令:一行是一条命令(tab为接上行);
命令格式:type+命令(没有则为00)+参数数量+参数
timing时序:
1.   display-timings {
         native-mode = <&timing1>;
         iming1: timing1 {
                   clock-frequency = <64000000>;
                   hactive = <720>;
                   vactive = <1280>;
                   hfront-porch = <40>;
                   hsync-len = <10>;
                   hback-porch = <40>;
                   vfront-porch = <22>;
                   vsync-len = <4>;
                   vback-porch = <11>;
                   hsync-active = <0>;
                   vsync-active = <0>;
                   de-active = <0>;
MIPI信号从vopl输出:
1.   &dsi_in_vopl {
      status = "okay";
&dsi_in_vopb {
触摸
1.   &i2c4 {
     status = "okay";
     gt1x: gt1x@14 {
              status = "okay";
              compatible = "goodix,gt1x";
              reg = <0x14>;
              goodix,rst-gpio = <&gpio4 RK_PC6 GPIO_ACTIVE_LOW>;
              goodix,irq-gpio = <&gpio4 RK_PC5 IRQ_TYPE_LEVEL_LOW>;
              goodix,enable-gpio = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>;
注意:如果客户需要LVDS需要加TC358775把MIPI转成LVDS。
hyd4001| | 2019-9-21 10:50 | 只看该作者
lvds的调式教程有出来吗
dufanghua| | 2019-9-27 14:41 | 只看该作者
大力支持  大力支持
qq7643066|  楼主 | 2019-10-15 13:58 | 只看该作者
一款rk3399主板接口图
yhgwork 2020-2-3 11:00 回复TA
4面都有接口,你们不考虑以后开磨具的吗
幽魂| | 2019-10-16 14:26 | 只看该作者
支持
qq7643066|  楼主 | 2020-2-2 19:20 | 只看该作者
为了sunychip-RK3399达到最好的性能,需要将CPU 及GPU 定频,特别是GPU。
CPU 定频方法参考:
cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
echo "userspace" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo "1416000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
echo "userspace" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo "1416000" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_setspeed
echo "userspace" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo "1416000" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_setspeed
echo "userspace" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
echo "1416000" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_setspeed
echo "userspace" > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
echo "1800000" > /sys/devices/system/cpu/cpu4/cpufreq/scaling_setspeed
echo "userspace" > /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor
echo "1800000" > /sys/devices/system/cpu/cpu5/cpufreq/scaling_setspeed
GPU 定频方法参考:
echo "userspace" >/sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/governor
echo "800000000" >/sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/userspace/set_freq
cat /sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/cur_freq
qq7643066|  楼主 | 2020-2-2 19:23 | 只看该作者
android7.1怎么调式显示屏方向,现在给出方法
otation = Surface.ROTATION_0; // 默认横屏
如果有部分用户需要选择HDMI ,或者LCD,需要选择显示的话。就把上面的默认横屏去掉就可以了。
这样修改ro.sf.hwrotation 参数,上下旋转是可以的。
修改的代码在framwork/base/core/services/core/;" />
幽魂| | 2020-2-10 21:05 | 只看该作者
加油 加油 加油
qq7643066|  楼主 | 2020-6-9 08:54 | 只看该作者
qq7643066|  楼主 | 2020-7-16 14:45 | 只看该作者
dufanghua| | 2020-8-3 17:57 | 只看该作者
大佬厉害 学习了
个人签名:承接MID、Android TV等项目定制 QQ:7643066
107
