[STM32F4]
屏幕闪烁问题
1010|8
supernan|  楼主 | 2019-9-22 13:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用野火的429开发板,实测《21-LTDC—液晶显示汉字(显示任意大小)》的例程,发现双层显示使用的都是ARGB1555格式,如果都换成RGB565,或者一层是ARGB15555另外一层使用RGB565,则屏幕都会闪烁
huwr| | 2019-9-22 13:51 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
supernan|  楼主 | 2019-9-22 13:56 | 只看该作者
void LCD_LayerInit(void)
LTDC_Layer_InitTypeDef LTDC_Layer_InitStruct;
  /* 层窗口配置 */
  /* 配置本层的窗口边界,注意这些参数是包含HBP HSW VBP VSW的 */
        //一行的第一个起始像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedHBP+1)的值
        LTDC_Layer_InitStruct.LTDC_HorizontalStart = HBP + HSW;
        //一行的最后一个像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedActiveW)的值
        LTDC_Layer_InitStruct.LTDC_HorizontalStop = HSW+HBP+LCD_PIXEL_WIDTH-1;
        //一列的第一个起始像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedVBP+1)的值
        LTDC_Layer_InitStruct.LTDC_VerticalStart =  VBP + VSW;
        //一列的最后一个像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedActiveH)的值
        LTDC_Layer_InitStruct.LTDC_VerticalStop = VSW+VBP+LCD_PIXEL_HEIGHT-1;
/* Pixel Format configuration*/
LTDC_Layer_InitStruct.LTDC_PixelFormat = LTDC_Pixelformat_RGB565;
/* Alpha constant (255 totally opaque) */
LTDC_Layer_InitStruct.LTDC_ConstantAlpha = 255;
/* Default Color configuration (configure A,R,G,B component values) */
LTDC_Layer_InitStruct.LTDC_DefaultColorBlue = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorGreen = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorRed = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorAlpha = 0;
/* Configure blending factors */
LTDC_Layer_InitStruct.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_CA;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_CA;
/* the length of one line of pixels in bytes + 3 then :
Line Lenth = Active high width x number of bytes per pixel + 3
Active high width         = LCD_PIXEL_WIDTH
number of bytes per pixel = 2    (pixel_format : RGB565)
LTDC_Layer_InitStruct.LTDC_CFBLineLength = ((LCD_PIXEL_WIDTH * 2) + 3);
/* the pitch is the increment from the start of one line of pixels to the
start of the next line in bytes, then :
Pitch = Active high width x number of bytes per pixel */
LTDC_Layer_InitStruct.LTDC_CFBPitch = (LCD_PIXEL_WIDTH * 2);
/* Configure the number of lines */
LTDC_Layer_InitStruct.LTDC_CFBLineNumber = LCD_PIXEL_HEIGHT;
/* Start Address configuration : the LCD Frame buffer is defined on SDRAM */
LTDC_Layer_InitStruct.LTDC_CFBStartAdress = LCD_FRAME_BUFFER;
/* Initialize LTDC layer 1 */
LTDC_LayerInit(LTDC_Layer1, <DC_Layer_InitStruct);
  /* Configure Layer2 */
LTDC_Layer_InitStruct.LTDC_PixelFormat = LTDC_Pixelformat_ARGB1555;
  /* Start Address configuration : the LCD Frame buffer is defined on SDRAM w/ Offset */
LTDC_Layer_InitStruct.LTDC_CFBStartAdress = LCD_FRAME_BUFFER + BUFFER_OFFSET;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_PAxCA;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_PAxCA;
  /* Initialize LTDC layer 2 */
LTDC_LayerInit(LTDC_Layer2, <DC_Layer_InitStruct);
  /* LTDC configuration reload */
LTDC_ReloadConfig(LTDC_IMReload);
  /* Enable foreground & background Layers */
LTDC_LayerCmd(LTDC_Layer1, ENABLE);
LTDC_LayerCmd(LTDC_Layer2, ENABLE);
  /* Set default font */
LCD_SetFont(&LCD_DEFAULT_FONT);
  /* dithering activation */
LTDC_DitherCmd(ENABLE);
gongche| | 2019-9-22 13:58 | 只看该作者
不是很懂这个格式,只是说是软字幕。
happy_10| | 2019-9-22 14:05 | 只看该作者
应该是不兼容。
supernan|  楼主 | 2019-9-22 14:07 | 只看该作者
嗯,那我按大家的说法挨个排查一下,先结贴啦,谢谢哈
木木guainv| | 2019-10-16 08:32 | 只看该作者
刷新频率是多少啊
xiaoqizi| | 2019-10-16 08:39 | 只看该作者
是不是哪里配置不匹配了
wowu| | 2019-10-16 08:48 | 只看该作者
帮楼主顶一下
