[嵌入式Linux]
rk3128点LVDS显示屏
696|1
幽魂|  楼主 | 2019-9-25 17:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RK3128 点LVDS过程
1、进入dts目录
rk\rk312844\rk3128_android4.4\kernel\arch\arm\boot\dts
2、打开修改dts
默认是HDMI输出 配置文件为LCD-BOX.dtsi
注释LCD-BOX.dtsi
增加LCD-b101ew05.dtsi
3、增加dtsi
                disp_timings: display-timings {
                        native-mode = <&timing0>;
                        timing0: timing0 {
                                screen-type =;
                                lvds-format =;
                                out-face    =;
                                color-mode =;
                                clock-frequency =<71000000>;
                                hactive =<1280>;
                                vactive =<800>;
                                hback-porch =<100>;
                                hfront-porch =<18>;
                                vback-porch =<8>;
                                vfront-porch =<6>;
                                hsync-len =<10>;
                                vsync-len =<2>;
                                hsync-active =<0>;
                                vsync-active =<0>;
                                de-active =<0>;
                                pixelclk-active =<0>;
                                swap-rb =<0>;
                                swap-rg =<0>;
                                swap-gb =<0>;
这里填上屏的参数
4、编译kernel
5、烧录kernel
这个时候应该有显示了
RK3128
mcuzone| | 2019-9-26 09:37 | 只看该作者
这个帖子没有灵魂
