[DemoCode下载]
基于寄存器操作的IO输出
397|10
xixi2017|  楼主 | 2019-9-26 23:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 7 $
* $Date: 15/07/13 1:27p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to set GPIO pin mode and use pin data input/output control.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
    /* Waiting for Internal RC clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_HIRC;
    CLK->CLKDIV = (CLK->CLKDIV & (~CLK_CLKDIV_HCLK_N_Msk)) | CLK_CLKDIV_HCLK(1);
    /* Set PLL to Power down mode and HW will also clear PLL_STB bit in CLKSTATUS register */
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external XTAL 12MHz clock */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for external XTAL clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK->PLLCON = PLLCON_SETTING;
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk));
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_PLL;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For CLK_SysTickDelay()
    /* Enable UART module clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk;
    /* Select UART module clock source */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UART_S_Msk)) | CLK_CLKSEL1_UART_S_PLL;
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART0_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(PLL_CLOCK, 115200);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/* MAIN function        */
int main(void)
    int32_t i32Err;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------+\n");
    printf("|    P1.2(Output) and P4.1(Input) Sample Code     |\n");
    printf("+-------------------------------------------------+\n\n");
    /* Configure P1.2 as Output mode and P4.1 as Input mode then close it */
    P1->PMD = (P1->PMD & (~GPIO_PMD_PMD2_Msk)) | (GPIO_PMD_OUTPUT << GPIO_PMD_PMD2_Pos);
    P4->PMD = (P4->PMD & (~GPIO_PMD_PMD1_Msk)) | (GPIO_PMD_INPUT << GPIO_PMD_PMD1_Pos);
    i32Err = 0;
    printf("GPIO P1.2(output mode) connect to P4.1(input mode) ......");
    /* Use Pin Data Input/Output Control to pull specified I/O or get I/O pin status */
    P12 = 0;
    if(P41 != 0)
        i32Err = 1;
    P12 = 1;
    if(P41 != 1)
        i32Err = 1;
    if(i32Err)
        printf("  [FAIL].\n");
    else
        printf("  [OK].\n");
    /* Configure P1.2 and P4.1 to default Quasi-bidirectional mode */
    P1->PMD = (P1->PMD & (~GPIO_PMD_PMD2_Msk)) | (GPIO_PMD_QUASI << GPIO_PMD_PMD2_Pos);
    P4->PMD = (P4->PMD & (~GPIO_PMD_PMD1_Msk)) | (GPIO_PMD_QUASI << GPIO_PMD_PMD1_Pos);
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
ARM单片机的IO操作其实非常简单。
幸福小强| | 2019-9-27 21:42 | 只看该作者
很好懂的样子。新唐的库函数和头文件都做的很好。
598330983| | 2019-9-28 18:27 | 只看该作者
多功能选择配置。
小灵通2018| | 2019-9-28 21:03 | 只看该作者
好多的逻辑位操作。
eyu66| | 2019-9-29 08:56 | 只看该作者
我是寄存器名称都不用,直接粗爆的操作寄存器地址,是不是没救了
比如类似下面这一句:
我的写法基本是:
unsigned int *pCLK_CLKSEL0 = (unsigned int *)(0x40000200 + 0x10);
*pCLK_CLKSEL0 &= ~0x00000100;   *pCLK_CLKSEL0 |= 0x00000100;
xixi2017|  楼主 | 2019-9-29 10:21 | 只看该作者
eyu66 发表于 2019-9-29 08:56
我是寄存器名称都不用,直接粗爆的操作寄存器地址,是不是没救了?
比如类似下面这一句:
CLK->CLKS ...
这种才是原生态,比较生猛。你太牛了。
john_lee| | 2019-9-29 13:29 | 只看该作者
我对位操作比较来气,就这样写了:
  RCC.CR().HSION(true);                         // Set HSION bit
  RCC.CFGR().SW(rcc::sw_t::HSI)                 // HSI Selected as System Clock source
            .HPRE(rcc::hpre_t::DIV1)            // HCLK = SYSCLK
            .PPRE1(rcc::ppre_t::DIV1)           // PCLK1 = HCLK
            .PPRE2(rcc::ppre_t::DIV1)           // PCLK2 = HCLK
            .ADCPRE(rcc::adcpre_t::DIV2)        // Reset ADCPRE bit
            .MCO(rcc::mco_t::NONE);             // Reset MCO bit
  RCC.CR().HSEON(false)                         // Reset HSEON bit
          .HSEBYP(false)                        // Reset HSEBYP bit
          .CSSON(false)                         // Reset CSSON bit
          .PLLON(false);                        // Reset PLLON bit
xixi2017 2019-9-29 18:28 回复TA
这是高手。
xixi2017|  楼主 | 2019-9-29 18:28 | 只看该作者
john_lee 发表于 2019-9-29 13:29
我对位操作比较来气,就这样写了:
这种写法我还真不会,是定义的宏还是C语言本身的功能?
john_lee| | 2019-9-30 12:01 | 只看该作者
C++
