[DemoCode下载]
M451的点灯操作
418|5
ck, TE, se, rc
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Date: 15/09/02 10:03a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Toggle PC.9 to turn on / off the board LED
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define HCLK_CLOCK       72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set GPD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
/* MAIN function        */
int main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Select SysTick clock source as HXT */
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HXT);
    /* Configure PC.9 as Output mode */
    GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
    while(1)
        /* Configure PC.9 to low */
        PC9 = 0;
        /* Delay 200 ms */
        CLK_SysTickDelay(200000);
        /* Configure PC.9 to high */
        PC9 = 1;
        /* Delay 200 ms */
huangcunxiake|  楼主 | 2019-9-30 20:49 | 只看该作者
天灵灵地灵灵| | 2019-9-30 21:14 | 只看该作者
如果搭配最新的库函数和管脚时钟初始化工具,效果更好
直接就上手了。
天灵灵地灵灵| | 2019-9-30 21:29 | 只看该作者
可以针对位操作。
xinpian101| | 2019-9-30 21:48 | 只看该作者
入门必备的,类似Helloworld
