[技术问答]
MS51用Bandgap_Voltage推VDD差距好大,根本不能用。
1895|12
Q80351951|  楼主 | 2019-10-14 09:58 | 显示全部楼层 |阅读模式
        double  vdd_Voltage,Bandgap_Voltage;
double READ_BANDGAP(void)
        UINT8 BandgapHigh, BandgapLow, BandgapMark;
        double Bandgap_Value;
        Enable_ADC_BandGap;
        set_CHPCON_IAPEN;
        IAPCN = READ_UID;
        IAPAL = 0x0d;
        IAPAH = 0x00;
        set_IAPTRG_IAPGO;
        BandgapLow = IAPFD;
        BandgapMark = BandgapLow & 0xF0;
        BandgapLow = BandgapLow & 0x0F;
        IAPAL = 0x0C;
        IAPAH = 0x00;
        set_IAPTRG_IAPGO;
        BandgapHigh = IAPFD;
        clr_CHPCON_IAPEN;
        Bandgap_Value = ((double)((BandgapHigh << 4) + BandgapLow));
        return (Bandgap_Value * 3072 / 4096);
        Bandgap_Voltage=READ_BANDGAP();
        vdd_Voltage=(((double)0x1000) / (double)ad.bandgap)*Bandgap_Voltage;
串口发出数据为
ad.bandgap = 00725 |         Bandgap_Voltage = 01199mv |         vdd_Voltage = 06775mv |
ad.bandgap = 00726 |         Bandgap_Voltage = 01199mv |         vdd_Voltage = 06766mv |
ad.bandgap = 00727 |         Bandgap_Voltage = 01199mv |         vdd_Voltage = 06756mv |
ad.bandgap = 00728 |         Bandgap_Voltage = 01199mv |         vdd_Voltage = 06747mv |
结果实际万用表测得电压4.94V, 整个不能用,问题在哪里?
小明的同学| | 2019-10-14 10:23 | 显示全部楼层
        VDD_Voltage = ((float)READ_BANDGAP()/(float)ADC_BG_Result)*3.072;
小明的同学| | 2019-10-14 10:24 | 显示全部楼层
没有用过MS51,但是我觉得楼主的代码有问题,因为我用的ML51的是这么给测试的。
小明的同学| | 2019-10-14 10:26 | 显示全部楼层
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  File Function: ML51 series use bandgap result to calculate VDD demo code
#include "ML51.h"
double  VDD_Voltage,Bandgap_Voltage;             /*please always use "double" mode for this */
unsigned char xdata ADCdataH[5], ADCdataL[5];
unsigned int ADCsumH=0, ADCsumL=0;
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    unsigned int  ADC_BG_Result;
    MFP_P31_UART0_TXD;                                /* UART0 define @P0.5 & P0.6 multi function setting */
    P31_QUASI_MODE;
    UART_Open(24000000,UART0_Timer3,115200);            /* set UART0 output, baudrate 115200 generate by timer1 */
    ENABLE_UART0_PRINTF;;
/* ADC bandgap initial
  * include adc.c in Library for initial setting
    ADC_Open(ADC_SINGLE,VBG);
/* For the best result wait 10us delay for each sampling, ADCDIV=3, ADCAQT=7 is better */
    ADC_ConvertTime(3,7);
//    ADC_Calibration();
    while (1)
        clr_ADCCON0_ADCF;
        set_ADCCON0_ADCS;
        while(!(ADCCON0&SET_BIT7));
        ADC_BG_Result = (ADCRH<<4) + ADCRL;
        printf ("\n ADC_BG_Result = 0x%02X",ADC_BG_Result);
/*                  VDD  Now                         READ_BANDGAP() VALUE
/*    3072mV(Storage value test condition)      NOW ADC Bandgap convert reuslt
        printf ("\n VDD_Voltage = %e",VDD_Voltage);
/*            Bandgap real voltage                    READ_BANDGAP() VALUE
/*    3072mV(Storage value test condition)              4096(12bit ADC)
        Bandgap_Voltage = ((float)READ_BANDGAP()*3/4/1000);
        printf ("\n Bandgap_Voltage = %e", Bandgap_Voltage);
        ADCsumH = 0;
        ADCsumL = 0;
        printf ("\n " );
        printf ("\n " );
另外给你找了MS51官方的例子,你可以试试看
/*  Website: http://www.nuvoton.com        */
/*  E-Mail : MicroC-8bit@nuvoton.com        */
/*  Date   : June/21/2019        */
//  File Function: MS51 ADC read bandgap to VDD demo code                                                  */
#include "MS51_8K.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
double  Bandgap_Voltage,VDD_Voltage,Bandgap_Value;      //please always use "double" mode for this
unsigned char ADCavgH,ADCavgL;
void READ_BANDGAP()
    UINT8 BandgapHigh,BandgapLow,BandgapMark;
    set_CHPCON_IAPEN;
    IAPCN = READ_UID;
    IAPAL = 0x0d;
    IAPAH = 0x00;
    set_IAPTRG_IAPGO;
    BandgapLow = IAPFD;
    BandgapMark = BandgapLow&0xF0;
    BandgapLow = BandgapLow&0x0F;
    IAPAL = 0x0C;
    IAPAH = 0x00;
    set_IAPTRG_IAPGO;
    Bandgap_Value = (BandgapHigh<<4)+BandgapLow;
    Bandgap_Voltage= Bandgap_Value*3/4;
    clr_CHPCON_IAPEN;
void main (void)
    double bgvalue;
    unsigned int i;
/*Read bandgap value */
    READ_BANDGAP();
/* ADC Low speed initial*/
    ENABLE_ADC_BANDGAP;
    ADCCON1|=0x30;            /* clock divider */
    ADCCON2|=0x0E;            /* AQT time */
    AUXR1|=SET_BIT4;          /* ADC clock low speed */
/*start bandgap ADC */
    clr_ADCCON0_ADCF;
    set_ADCCON0_ADCS;
    while(ADCF == 0);
    ADCdataH[i] = ADCRH;
    ADCdataL[i] = ADCRL;
/* to convert VDD value */
    bgvalue = (ADCRH<<4) + ADCRL;
    VDD_Voltage = (0x1000/bgvalue)*Bandgap_Voltage;
/* UART0 settting for printf function */
    MODIFY_HIRC_24();
/*printf result value */
    printf ("\n BG Voltage = %e", Bandgap_Voltage);
    printf ("\n VDD voltage = %e", VDD_Voltage);
    while(1);
小明的同学| | 2019-10-14 10:27 | 显示全部楼层
/*  Date   : Jan/21/2019        */
#include "MS51_16K.H"
void READ_BANDGAP()
    set_CHPCON_IAPEN;
    IAPCN = READ_UID;
    IAPAL = 0x0d;
    IAPAH = 0x00;
    set_IAPTRG_IAPGO;
    BandgapLow = IAPFD;
    IAPAL = 0x0C;
    IAPAH = 0x00;
    set_IAPTRG_IAPGO;
    clr_CHPCON_IAPEN;
void main (void)
    double bgvalue;
    unsigned int i;
    READ_BANDGAP();
    ENABLE_ADC_BANDGAP;
    clr_ADCCON0_ADCF;
    set_ADCCON0_ADCS;
    while(ADCF == 0);
    MODIFY_HIRC_24();
    while(1);
不知道楼主试过这个官方的BSP提供的例子没。
Q80351951|  楼主 | 2019-10-14 17:16 | 显示全部楼层
我这个和官方的一样呀,就是官方改来的。
antusheng| | 2019-10-14 20:48 | 显示全部楼层
你先别乱改,直接跑官方的例子,看看print的结果是什么。
connorzhang| | 2021-1-21 17:11 | 显示全部楼层
我用ML51_BSP_Keil_C51_V1.00\SampleCode\StdDriver\ADC_Bandgap_VDD 这个例子打印出来一直是这个,不知道是哪里的问题,我的vdd 上接的3.3v,芯片用的 ML51FB9AE:
ADC_BG_Result = 0xFFF
VDD_Voltage = 8.184499e-01
Bandgap_Voltage = 8.182500e-01
coshi| | 2021-2-6 10:10 | 显示全部楼层
楼主的这个题目我就没看明白
zljiu| | 2021-2-6 10:11 | 显示全部楼层
楼主说的有点矛盾 一会儿说是跟官方一样的 一会儿说是根据官方改了的
wiba| | 2021-2-6 10:17 | 显示全部楼层
可以用工具对比一下你的程序和官方程序哪里不一样
