[STC单片机]
STC15W204S做一个串口通讯程序,为什么没有反应?
1846|7
xiong0821|  楼主 | 2019-10-24 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
//若无特别说明,工作频率一般为11.0592MHz
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 11059200L          //系统频率
#define BAUD 9600             //串口波特率
#define NONE_PARITY     0       //无校验
#define ODD_PARITY      1       //奇校验
#define EVEN_PARITY     2       //偶校验
#define MARK_PARITY     3       //标记校验
#define SPACE_PARITY    4       //空白校验
#define PARITYBIT EVEN_PARITY   //定义校验位
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr AUXR  = 0x8e;               //辅助寄存器
sfr T2H   = 0xd6;               //定时器2高8位
sfr T2L   = 0xd7;               //定时器2低8位
sfr P_SW1   = 0xA2;             //外设功能切换寄存器1
#define S1_S0 0x40              //P_SW1.6
#define S1_S1 0x80              //P_SW1.7
sbit P22 = P2^2;
bit busy;
void SendData(BYTE dat);
void SendString(char *s);
void main()
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
    ACC = P_SW1;
    ACC &= ~(S1_S0 | S1_S1);    //S1_S0=0 S1_S1=0
    P_SW1 = ACC;                //(P3.0/RxD, P3.1/TxD)
//  ACC = P_SW1;
//  ACC &= ~(S1_S0 | S1_S1);    //S1_S0=1 S1_S1=0
//  ACC |= S1_S0;               //(P3.6/RxD_2, P3.7/TxD_2)
//  P_SW1 = ACC;
//  ACC = P_SW1;
//  ACC &= ~(S1_S0 | S1_S1);    //S1_S0=0 S1_S1=1
//  ACC |= S1_S1;               //(P1.6/RxD_3, P1.7/TxD_3)
//  P_SW1 = ACC;
#if (PARITYBIT == NONE_PARITY)
    SCON = 0x50;                //8位可变波特率
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    SCON = 0xda;                //9位可变波特率,校验位初始为1
#elif (PARITYBIT == SPACE_PARITY)
    SCON = 0xd2;                //9位可变波特率,校验位初始为0
#endif
   PCON &= 0x7F;                //波特率不倍速
    SCON = 0x50;                //8位数据,可变波特率
        AUXR |= 0x01;                //串口1选择定时器2为波特率发生器
        AUXR |= 0x04;                //定时器2时钟为Fosc,即1T
        T2L = 0xE0;                //设定定时初值
        T2H = 0xFE;                //设定定时初值
        AUXR |= 0x10;                //启动定时器2
        ET2 = 0;                //禁止定时器2中断
    SendString("STC15F2K60S2\r\nUart Test !\r\n");
    while(1);
UART 中断服务程序
void Uart() interrupt 4
    if (RI)
        RI = 0;                 //清除RI位
        P0 = SBUF;              //P0显示串口数据
        P22 = RB8;              //P2.2显示校验位
    if (TI)
        TI = 0;                 //清除TI位
        busy = 0;               //清忙标志
发送串口数据
    while (busy);               //等待前面的数据发送完成
    ACC = dat;                  //获取校验位P (PSW.0)
    if (P)                      //根据P来设置校验位
#if (PARITYBIT == ODD_PARITY)
        TB8 = 0;                //设置校验位为0
#elif (PARITYBIT == EVEN_PARITY)
        TB8 = 1;                //设置校验位为1
#endif
    else
        TB8 = 1;                //设置校验位为1
        TB8 = 0;                //设置校验位为0
#endif
    busy = 1;
    SBUF = ACC;                 //写数据到UART数据寄存器
发送字符串
    while (*s)                  //检测字符串结束标志
        SendData(*s++);         //发送当前字符
cainiao518| | 2019-10-24 21:51 | 只看该作者
串口初始化没问题?
硬件有没问题
ayb_ice| | 2019-10-25 15:35 | 只看该作者
NB,直接操控ACC
ayb_ice| | 2019-10-25 15:36 | 只看该作者
ET0 = 0;                //禁止定时器2中断
luochaojin1990| | 2019-10-25 17:45 | 只看该作者
#define PARITYBIT EVEN_PARITY   //定义校验位校验位是偶校验,利用串口助手试试,设置校验位为偶校验
coody| | 2019-10-27 20:12 | 只看该作者
可以直接下载STC ISP里的范例程序,15系列用定时器2做波特率发生器,直接下载HEX测试。
lym_96| | 2019-11-13 08:44 | 只看该作者
没打开中断吧?ES=1;EA=1;
xuyaqi| | 2019-11-13 10:25 | 只看该作者
这是一个靠中断发送的串口程序,你在串口初始化中没有开中断,必然不会发送。
