[活动专区]
【AC7811开发板试用活动】点LED灯及库的研究
337|0
ddllxxrr|  楼主 | 2019-10-26 21:02 | 显示全部楼层 |阅读模式
今天,有点时间研究了下库,AC7811的库是在安装PACK时装进MDK的。且比较特别同STM32不一样。
比如说这个库函数:
int32_t GPIO_SetDir(uint32_t gpioNum, uint32_t pinMode)
    uint32_t tmpGPIOx = 0, tmpGPIOxPinNum = 0;
    tmpGPIOx = gpioNum / GPIO_ONE_GROUP_NUM;                  // Calculate GPIO Group(A~E)
    tmpGPIOxPinNum = gpioNum % GPIO_ONE_GROUP_NUM;            // Calculate GPIO Group's Internal Pin Number(0~15)
    switch (tmpGPIOx)
    case 0:
        GPIO_SetGPIOxMODE(GPIOA, tmpGPIOxPinNum, pinMode);
        break;
    case 1:
        GPIO_SetGPIOxMODE(GPIOB, tmpGPIOxPinNum, pinMode);
        break;
    case 2:
        GPIO_SetGPIOxMODE(GPIOC, tmpGPIOxPinNum, pinMode);
        break;
    case 3:
        GPIO_SetGPIOxMODE(GPIOD, tmpGPIOxPinNum, pinMode);
        break;
    case 4:
        GPIO_SetGPIOxMODE(GPIOE, tmpGPIOxPinNum, pinMode);
        break;
    default:
        return -1;
    return 0;
它是把所有的管脚都罗列在一起然后再分。我认为这是比ST的库要进步。
还有一点是,不用给管脚外设特意加时钟。比如我的点灯程序如下:
int main(void)
        InitDelay();
        InitDebug();
        GPIO_SetDir(MY_LED_PIN, GPIO_OUTPUT);//设置LED引脚为输出
        do
                MY_LED = 0;
                 mdelay(1000);
                MY_LED = 1;
                  mdelay(1000);
        }while(1);
而管脚定义是在GPIO.h中
#define MY_LED          (GPIOC_OUT(5))//定义MY_LED引脚别名
#define MY_LED_ON       MY_LED =1
#define MY_LED_OFF      MY_LED =0
#define MY_LED_TOGGLE   MY_LED = !MY_LED
我只是定义了管脚是输出并没有给时钟使能,但好用:
以下是截图:
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2392
