[demo程序]
【转载】DES加密解密算法C语言代码实现
628|5
merry_zsp|  楼主 | 2019-10-31 09:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<stdio.h>
#include<string.h>
#include<stdlib.h>
     定义枚举型全局变量
typedef enum
    false = 0,
    true  = 1
  } bool;
  // 十六轮子密钥
static bool SubKey[16][48]={0};
     各种置换表
// IP置换表
const char IP_Table[64]={
58,50,42,34,26,18,10, 2,60,52,44,36,28,20,12, 4,
62,54,46,38,30,22,14, 6,64,56,48,40,32,24,16, 8,
57,49,41,33,25,17, 9, 1,59,51,43,35,27,19,11, 3,
61,53,45,37,29,21,13, 5,63,55,47,39,31,23,15, 7
// IP-1置换表
const char IPR_Table[64]={
40, 8,48,16,56,24,64,32,39, 7,47,15,55,23,63,31,
38, 6,46,14,54,22,62,30,37, 5,45,13,53,21,61,29,
36, 4,44,12,52,20,60,28,35, 3,43,11,51,19,59,27,
34, 2,42,10,50,18,58,26,33, 1,41, 9,49,17,57,25
// E扩展表
static char E_Table[48]={
32, 1, 2, 3, 4, 5, 4, 5, 6, 7, 8, 9,
  8, 9,10,11,12,13,12,13,14,15,16,17,
    16,17,18,19,20,21,20,21,22,23,24,25,
    24,25,26,27,28,29,28,29,30,31,32, 1
// PC1置换表
static char PC1_Table[56]={
57,49,41,33,25,17, 9, 1,58,50,42,34,26,18,
10, 2,59,51,43,35,27,19,11, 3,60,52,44,36,
63,55,47,39,31,23,15, 7,62,54,46,38,30,22,
14, 6,61,53,45,37,29,21,13, 5,28,20,12, 4
// pc2表
static char PC2_Table[48]={
14,17,11,24, 1, 5, 3,28,15, 6,21,10,
23,19,12, 4,26, 8,16, 7,27,20,13, 2,
41,52,31,37,47,55,30,40,51,34,33,48,
44,49,39,56,34,53,46,42,50,36,29,32
//  移位表
static char Move_Table[16]={
  1, 1, 2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1
// S盒
static char S_Box[8][4][16]={
//S1
14, 4,13, 1, 2,15,11, 8, 3,10, 6,12, 5, 9, 0, 7,
  0,15, 7, 4,14, 2,13, 1,10, 6,12,11, 9, 5, 3, 8,
  4, 1,14, 8,13, 6, 2,11,15,12, 9, 7, 3,10, 5, 0,
15,12, 8, 2, 4, 9, 1, 7, 5,11, 3,14,10, 0, 6,13,
//S2
15, 1, 8,14, 6,11, 3, 4, 9, 7, 2,13,12, 0, 5,10,
  3,13, 4, 7,15, 2, 8,14,12, 0, 1,10, 6, 9,11, 5,
  0,14, 7,11,10, 4,13, 1, 5, 8,12, 6, 9, 3, 2,15,
13, 8,10, 1, 3,15, 4, 2,11, 6, 7,12, 0, 5,14, 9,
//S3
10, 0, 9,14, 6, 3,15, 5, 1,13,12, 7,11, 4, 2, 8,
13, 7, 0, 9, 3, 4, 6,10, 2, 8, 5,14,12,11,15, 1,
13, 6, 4, 9, 8,15, 3, 0,11, 1, 2,12, 5,10,14, 7,
  1,10,13, 0, 6, 9, 8, 7, 4,15,14, 3,11, 5, 2,12,
//S4
  7,13,14, 3, 0, 6, 9,10, 1, 2, 8, 5,11,12, 4,15,
13, 8,11, 5, 6,15, 0, 3, 4, 7, 2,12, 1,10,14, 9,
10, 6, 9, 0,12,11, 7,13,15, 1, 3,14, 5, 2, 8, 4,
  3,15, 0, 6,10, 1,13, 8, 9, 4, 5,11,12, 7, 2,14,
//S5
  2,12, 4, 1, 7,10,11, 6, 8, 5, 3,15,13, 0,14, 9,
14,11, 2,12, 4, 7,13, 1, 5, 0,15,10, 3, 9, 8, 6,
  4, 2, 1,11,10,13, 7, 8,15, 9,12, 5, 6, 3, 0,14,
11, 8,12, 7, 1,14, 2,13, 6,15, 0, 9,10, 4, 5, 3,
//S6
12, 1,10,15, 9, 2, 6, 8, 0,13, 3, 4,14, 7, 5,11,
10,15, 4, 2, 7,12, 0, 5, 6, 1,13,14, 0,11, 3, 8,
  9,14,15, 5, 2, 8,12, 3, 7, 0, 4,10, 1,13,11, 6,
     4, 3, 2,12, 9, 5,15,10,11,14, 1, 7, 6, 0, 8,13,
//S7
  4,11, 2,14,15, 0, 8,13, 3,12, 9, 7, 5,10, 6, 1,
13, 0,11, 7, 4, 0, 1,10,14, 3, 5,12, 2,15, 8, 6,
  1, 4,11,13,12, 3, 7,14,10,15, 6, 8, 0, 5, 9, 2,
  6,11,13, 8, 1, 4,10, 7, 9, 5, 0,15,14, 2, 3,12,
//S8
13, 2, 8, 4, 6,15,11, 1,10, 9, 3,14, 5, 0,12, 7,
  1,15,13, 8,10, 3, 7, 4,12, 5, 6,11, 0,14, 9, 2,
  7,11, 4, 1, 9,12,14, 2, 0, 6,10,13,15, 3, 5, 8,
  2, 1,14, 7, 4,10, 8,13,15,12, 9, 0, 3, 5, 6,11
//P置换表
static char P_Table[32]={
16, 7,20,21,29,12,28,17, 1,15,23,26, 5,18,31,10,
  2, 8,24,14,32,27, 3, 9,19,13,30, 6,22,11, 4,25
/*-----------------------------自定义函数-----------------------------*/
void SetKey(char My_key[8]); //生成16轮的子密钥;
void ByteToBit(bool * Data_out,char * Data_in,int Num); //字节转换成位;
void Change_bit(bool * Data_out,int Num);//二进制的位置进行转换;
void BitToByte(char My_message[8],bool * Message_in,int Num); //位转换成字节;
void TableReplace(bool *Data_out,bool *Data_in,const char *Table,int Num);  //各种表的置换算法;
void Bitcopy(bool * Data_out,bool * Data_in,int Num);  //二进制数组的拷贝
void Loop_bit(bool * Data_out,int movstep,int len);  //左移位;
void Run_Des(char My_message[8],char HexMssage[16]);//des的轮加密算法
void Xor(bool * Message_out, bool * Message_in,int Num); //执行异或
void S_change(bool * Data_out, bool * Data_in);  // S盒变换;
void HexToBit(bool * Data_out,char * Data_in,int Num); // 十六进制转二进制
void BitToHex(char * Data_out,bool * Data_in,int Num); //二进制转换成十六进制;
void Run_desDes(char My_message[8],char HexMessage[16]);// DES轮解密算法;
/*--------------------------主函数----------------------------------*/
int main()
int i=0,j;
char My_key[8]={0};  //记录加密密钥;
char You_key[8]={0}; //解密密钥
char My_message[8]={0}; //明文
char Message_hex[16]={0};//16进制的密文
printf("请输入你要加密的内容(8 Byte):\n");
gets(My_message);
printf("请输入你的加密密钥:\n");
gets(My_key);
i=strlen(My_key);
while(i!=8)
  printf("请输入加密密钥(8 Byte)\n");
  gets(My_key);
  i=0;
  i=strlen(My_key);
SetKey(My_key);  //生成16轮的加密子密钥;
Run_Des(My_message,Message_hex); //des的轮加密过程
printf("经过加密的密文为:\n");
for(i=0;i<16;i++)
  printf("%c ",Message_hex[i]);
printf("\n");
printf("请输入你的解密密钥(8 Byte):\n");
gets(You_key);
i=strlen(You_key);
while(i!=8)
  printf("请输入解密密钥(8 Byte)\n");
  gets(You_key);
  i=0;
  i=strlen(You_key);
SetKey(You_key);  //生成16轮的解密子密钥;
Run_desDes(My_message,Message_hex);//解密;
printf("解密结果为:\n");
for(i=0;i<8;i++)
  printf("%c ",My_message[i]);
printf("\n");
return 0;
/*--------------------具体函数定义----------------------*/
void Bitcopy(bool * Data_out, bool * Data_in,int Num) //二进制数组拷贝
int i=0;
for(i=0;i<Num;i++)
  Data_out[i]=Data_in[i];
void Change_bit(bool * Data_out,int Num) //二进制的位置进行转换;
int i,j;
static bool Temp[8]={0};
for(i=0;i<Num/8;i++)
  Bitcopy(Temp,Data_out,Num/8);
  for(j=0;j<Num/8;j++)
   Data_out[j]=Temp[Num/8-1-j];
  Data_out+=Num/8;
void ByteToBit( bool * Data_out,char * Data_in,int Num) //字节转位
int i,j;
for(i=0;i<Num;i++)
  Data_out[i]=(Data_in[i/8]>>(i%8))&0x01;
//Change_bit(Data_out,Num);
void BitToHex(char * Data_out, bool * Data_in,int Num) //二进制转十六进制
int i;
for(i=0;i<Num/4;i++)
  Data_out[i]=0;
  Data_out[i]=Data_in[4*i]+Data_in[4*i+1]*2+Data_in[4*i+2]*4+Data_in[4*i+3]*8;
  if(Data_out[i]%16>9)
   Data_out[i]=Data_out[i]%16+'7';
  else
  Data_out[i]=Data_out[i]%16+'0';
void HexToBit(bool * Data_out,char * Data_in,int Num) //十六进制转二进制
int i;
for(i=0;i<Num;i++)
  if(Data_in[i/4]<='9')
   Data_out[i]=((Data_in[i/4]-'0')>>(i%4))&0x01;
  else
   Data_out[i]=((Data_in[i/4]-'7')>>(i%4))&0x01;
void BitToByte(char My_message[8],bool * Message_in,int Num) //位转换成字节
int i=0;
for(i=0;i<(Num/8);i++)
  My_message[i]=0;
for(i=0;i<Num;i++)
  My_message[i/8]|=Message_in[i]<<(i%8);
void TableReplace( bool *Data_out, bool * Data_in,const char *Table ,int Num) // 置换算法
int i=0;
static bool Temp[256]={0};
for(i=0;i<Num;i++)
  Temp[i]=Data_in[Table[i]-1];
Bitcopy(Data_out,Temp,Num);
Bitcopy(Temp,Data_out,movstep);
Bitcopy(Data_out,Data_out+movstep,len-movstep);
Bitcopy(Data_out+len-movstep,Temp,movstep);
/*Temp=Data_out;
Temp[movstep]='\0';
Data_out=Data_out+movstep;
Data_out+(len-movstep)=Temp;*/
void Xor(bool * Message_out,bool * Message_in,int Num)//执行异或
int i;
for(i=0;i<Num;i++)
  Message_out[i]=Message_out[i]^Message_in[i];
int i,j;
static bool Key_bit[64]={0}; //Key的二进制缓存;
static bool *Key_bit_L,*Key_bit_R;
Key_bit_L=&Key_bit[0]; //key的左边28位;
Key_bit_R=&Key_bit[28]; //key的右边28位;
ByteToBit(Key_bit,My_key,64);
/* Change_bit(Key_bit,64) ;//二进制的位置进行转换;
for(i=0;i<64;i++)
  printf("%d ",Key_bit[i]);
printf("\n");
printf("\n");*/
TableReplace(Key_bit,Key_bit,PC1_Table,56);//pc-1 置换
for(i=0;i<16;i++)
  Loop_bit(Key_bit_L,Move_Table[i],28);
  Loop_bit(Key_bit_R,Move_Table[i],28);
  TableReplace(SubKey[i],Key_bit,PC2_Table,48);//pc-2置换
void S_change(bool * Data_out, bool * Data_in) //S盒变换
int i;
int r=0,c=0;//S盒的行和列;
for(i=0;i<8;i++,Data_in=Data_in+6,Data_out=Data_out+4)
  r=Data_in[0]*2+Data_in[5]*1;
  c=Data_in[1]*8+Data_in[2]*4+Data_in[3]*2+Data_in[4]*1;
  ByteToBit(Data_out,&S_Box[i][r][c],4);
void F_change(bool Data_out[32],bool Data_in[48])   // f函数;
int i;
static bool Message_E[48]={0};  //存放E置换的结果;
TableReplace(Message_E,Data_out,E_Table,48);//E表置换
Xor(Message_E,Data_in,48);
S_change(Data_out,Message_E);                 // S盒变换
TableReplace(Data_out,Data_out,P_Table,32);  //P置换
void Run_Des(char My_message[8],char HexMssage[16])//des轮加密算法;
int i;
static bool Message_bit[64]={0};
static bool *Message_bit_L=&Message_bit[0],*Message_bit_R=&Message_bit[32];
static bool Temp[32]={0};
ByteToBit(Message_bit,My_message,64);
/*Change_bit(Message_bit,64) ;//二进制的位置进行转换;
for(i=0;i<64;i++)
  printf("%d ",Message_bit[i]);
printf("\n");
printf("\n");*/
TableReplace(Message_bit,Message_bit,IP_Table,64);
for(i=0;i<16;i++)
  Bitcopy(Temp,Message_bit_R,32);
  F_change(Message_bit_R,SubKey[i]);
  Xor(Message_bit_R,Message_bit_L,32);
  Bitcopy(Message_bit_L,Temp,32);
TableReplace(Message_bit,Message_bit,IPR_Table,64);
BitToHex(HexMssage,Message_bit,64);//二进制转换成十六进制;
void Run_desDes(char My_message[8],char HexMessage[16])// DES轮解密算法;
int i=0;
static bool * Message_bit_L=&Message_bit[0], * Message_bit_R=&Message_bit[32];
HexToBit(Message_bit,HexMessage,64);
for(i=15;i>=0;i--)
  Bitcopy(Temp,Message_bit_L,32);
  F_change(Message_bit_L,SubKey[i]);
  Xor(Message_bit_L,Message_bit_R,32);
  Bitcopy(Message_bit_R,Temp,32);
BitToByte(My_message,Message_bit,64);
aoyi| | 2019-11-13 10:04 | 只看该作者
非常感谢分享
drer| | 2019-11-13 10:26 | 只看该作者
非常感谢分享
gwsan| | 2019-11-13 10:52 | 只看该作者
非常不错的资料
kxsi| | 2019-11-13 11:29 | 只看该作者
非常不错的资料
nawu| | 2019-11-13 11:41 | 只看该作者
非常不错的资料
