[活动专区]
【AC7811开发板试用活动】+另一种HT1621
404|0
Cjy_JDxy|  楼主 | 2019-11-2 19:46 | 显示全部楼层 |阅读模式
上次搞了一下HT1621,这次是另一种HT1621。
代码:
#include "ac78xx_gpio.h"
#include "ac78xx_debugout.h"
#include "ac78xx.h"
#define uchar unsigned char
#define uint unsigned int
/* makesure n < 16 */
#define PAout(n)   BIT_ADDR(GPIOA_ODR_ADDR, n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_ADDR, n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_ADDR, n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_ADDR, n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_ADDR, n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_ADDR, n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_ADDR, n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_ADDR, n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_ADDR, n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_ADDR, n)
/* gpio bit-band control */
#define LED PAout(0)
unsigned int tmp;
unsigned int n1, n2, n3, n4;
unsigned char Ht1621Tab[]={0x00,0x00,0x00,0x00};
unsigned char DispTab[]={0x7B,0x12,0x67,0x57,0x1E,0x5D,0x7D,0x13,0x7F,0x5F,0x69,0x45,0x3f, 0x7a, 0x3e};
              //          0    1    2    3    4    5    6    7    8    9    C    ?   A     V     H
#define  BIAS     0x52             //0b1000 0101 0010  1/3duty 4com
#define  SYSDIS   0X00             //0b1000 0000 0000  ???????LCD?????
#define  SYSEN    0X02             //0b1000 0000 0010 ???????
#define  LCDOFF   0X04             //0b1000 0000 0100  ?LCD??
#define  LCDON    0X06             //0b1000 0000 0110  ??LCD??
#define  XTAL     0x28             //0b1000 0010 1000 ?????
#define  RC256    0X30             //0b1000 0011 0000  ????
#define  WDTDIS1  0X0A            //0b1000 0000 1010  ?????
void Ht1621_CS_0() { PAout(4)=0;}  // define P2.2 ---> CS
void Ht1621_CS_1() { PAout(4)=1;}
void Ht1621_WR_0() { PAout(2)=0;}  // define P2.1 ---> WR
void Ht1621_WR_1() { PAout(2)=1;}
void Ht1621_DO_0() { PAout(0)=0;}  // define P2.0 ---> DAT
void Ht1621_DO_1() { PAout(0)=1;}
unsigned int counter;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
//Ht1621Wr_Data()
void Ht1621Wr_Data(unsigned char Data,unsigned char cnt)
  unsigned char i;
  for (i=0;i<cnt;i++)
     Ht1621_WR_0();
     if((Data & 0x80)==0x80) {Ht1621_DO_1();}
     else {Ht1621_DO_0();}
     Ht1621_WR_1();
     Data<<=1;
//void Ht1621WrCmd(uchar Cmd)
void Ht1621WrCmd(unsigned char Cmd)
   Ht1621_CS_0();
   Ht1621Wr_Data(0x80,4);          //??????100
   Ht1621Wr_Data(Cmd,8);           //??????
   Ht1621_CS_1();
//void Ht1621WrOneData(uchar Addr,uchar Data)
void Ht1621WrOneData(unsigned char Addr,unsigned char Data)
  Ht1621_CS_0();
  Ht1621Wr_Data(0xa0,3);  //??????101
  Ht1621Wr_Data(Addr<<2,6); //??????
  Ht1621Wr_Data(Data,4); //???????? 7  6  5  4
  Ht1621_CS_1();
//void Ht1621WrAllData()
void Ht1621WrAllData(unsigned char Addr,unsigned char *p,unsigned char cnt)
  unsigned char i;
  Ht1621_CS_0();
  for (i=0;i<cnt;i++)
    Ht1621Wr_Data(*p,8); //????
    p++;
  Ht1621_CS_1();
//void Ht1621_Init(void)
   Ht1621WrCmd(BIAS);
   Ht1621WrCmd(RC256);             //???????
   //Ht1621WrCmd(XTAL);             //???????
   Ht1621WrCmd(SYSDIS);
   Ht1621WrCmd(WDTDIS1);
   Ht1621WrCmd(SYSEN);
   Ht1621WrCmd(LCDON);
//DISPLAY
void Display(void)
   unsigned char com;
   com = 0;
   if((DispTab[n1]&0x01) == 0x01){ com = com + 0x10;}
   if((DispTab[n2]&0x01) == 0x01){ com = com + 0x20;}
   if((DispTab[n3]&0x01) == 0x01){ com = com + 0x40;}
   if((DispTab[n4]&0x01) == 0x01){ com = com + 0x80;}
   Ht1621WrOneData(0 , com);
   com = 0;
   if((DispTab[n1]&0x02) == 0x02){ com = com + 0x10;}
   if((DispTab[n2]&0x02) == 0x02){ com = com + 0x20;}
   if((DispTab[n3]&0x02) == 0x02){ com = com + 0x40;}
   if((DispTab[n4]&0x02) == 0x02){ com = com + 0x80;}
   Ht1621WrOneData(1 , com);
   com = 0;
   if((DispTab[n1]&0x10) == 0x10){ com = com + 0x10;}
   if((DispTab[n2]&0x10) == 0x10){ com = com + 0x20;}
   if((DispTab[n3]&0x10) == 0x10){ com = com + 0x40;}
   if((DispTab[n4]&0x10) == 0x10){ com = com + 0x80;}
   Ht1621WrOneData(2 , com);
   com = 0;
   if((DispTab[n1]&0x40) == 0x40){ com = com + 0x10;}
   if((DispTab[n2]&0x40) == 0x40){ com = com + 0x20;}
   if((DispTab[n3]&0x40) == 0x40){ com = com + 0x40;}
   if((DispTab[n4]&0x40) == 0x40){ com = com + 0x80;}
   Ht1621WrOneData(3 , com);
   com = 0;
   if((DispTab[n1]&0x20) == 0x20){ com = com + 0x10;}
   if((DispTab[n2]&0x20) == 0x20){ com = com + 0x20;}
   if((DispTab[n3]&0x20) == 0x20){ com = com + 0x40;}
   if((DispTab[n4]&0x20) == 0x20){ com = com + 0x80;}
   Ht1621WrOneData(4 , com);
   com = 0;
   if((DispTab[n1]&0x08) == 0x08){ com = com + 0x10;}
   if((DispTab[n2]&0x08) == 0x08){ com = com + 0x20;}
   if((DispTab[n3]&0x08) == 0x08){ com = com + 0x40;}
   if((DispTab[n4]&0x08) == 0x08){ com = com + 0x80;}
   Ht1621WrOneData(5 , com);
   com = 0;
   if((DispTab[n1]&0x04) == 0x04){ com = com + 0x10;}
   if((DispTab[n2]&0x04) == 0x04){ com = com + 0x20;}
   if((DispTab[n3]&0x04) == 0x04){ com = com + 0x40;}
   if((DispTab[n4]&0x04) == 0x04){ com = com + 0x80;}
   Ht1621WrOneData(6 , com);
//Display_lcd_dot
void Display_lcd_dot(void)
   Ht1621WrOneData(7 , 0x50);
//convertor()
void data_convertor(unsigned long adc_value)
    tmp=adc_value;         //adc
    n4=tmp/100;
    tmp=tmp%100;
    n3=tmp/10;
    tmp=tmp%10;
    n2=tmp;
                 // 4
    n1=10;       //display "C"
* main
* @param[in]  none
* @return none
* @brief  entry
int main(void)
    InitDebug();    //´òÓ¡³õʼ»¯
    InitDelay();    //ÑÓʱº¯Êý³õʼ»¯
    GPIO_SetDir(GPIO_PA0, 1);
                GPIO_SetDir(GPIO_PA2, 1);
                GPIO_SetDir(GPIO_PA4, 1);
                counter = 235;
                Ht1621_Init();        //?????LCD
    Delay(100);           //??????
    Ht1621WrAllData(0,Ht1621Tab,16);// Clear LCD display
    Ht1621_Init();
    while (1)
                                data_convertor(counter);
        Display();
        Display_lcd_dot();
        //Delayms(1000);
        counter++;
        LED = !LED;
        mdelay(1000);
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
