[STM32F1]
串口发送数组问题
348|2
WUZHIXIONG23|  楼主 | 2019-11-9 10:01 | 显示全部楼层 |阅读模式
const unsigned char ESPC_COMMAND[]={'A','T','+','R','S','T','F',0x0d,0x0a};
void SendData_String(unsigned char *str,int strlen)
  while (strlen--)
    Send_Uart(*str);
    str++;
SendData_String( ESPC_COMMAND ,9);
WUZHIXIONG23 2019-11-9 10:02 回复TA
这样传数组有问题吗?
WUZHIXIONG23|  楼主 | 2019-11-9 10:06 | 显示全部楼层
我编译的时候会报警
warning: passing argument 1 of 'SendData_String' discards 'const' qualifier from pointer target type
