[资源分享]
AC7811ADC采集
604|1
Cjy_JDxy|  楼主 | 2019-11-16 18:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
代码:
#include "ac78xx_adc.h"
#include "ac78xx_gpio.h"
#include "ac78xx.h"
#include "ac78xx_debugout.h"
#include "oled.h"
#include "bmp.h"
#define DISABLE                         0
#define ENABLE                          1
#define VOLTAGE_BG                      (1.2)             ///<Bandgap Voltage
uint32_t g_adcValue = 0;
uint32_t g_displayValue = 0;
float g_vdd = 0;                                          ///<Power Voltage
#define ADC_KEY_NUM                     3                 ///<define keypad number
static float s_ADC_DatMap[ADC_KEY_NUM] = {0.9, 0.6, 0.3}; ///<define KEY voltage
* OSD_KEY
* @param[in]  no
* @return no
* @brief  Display select KEY pad
void OSD_KEY()
    ADC_SoftwareStartRegularConvCmd(ADC, ADC_ENABLE);
    while (!ADC_GetIntFlag(ADC, ADC_FLAG_EOC));
    udelay(1);
    g_adcValue = ADC_GetRegularConversionValue(ADC);
    if(g_adcValue < (4096 * s_ADC_DatMap[2]))             ///<select KEY pad
        OLED_ShowString(8, 4, "K5", 8);
    else if(g_adcValue < (4096 * s_ADC_DatMap[1]))
        OLED_ShowString(8, 4, "K4", 8);
    else if(g_adcValue < (4096 * s_ADC_DatMap[0]))
        OLED_ShowString(8, 4, "K3", 8);
    else
        OLED_ShowString(8, 4, "NO", 8);
* OSD_VDD
* @param[in]  no
* @return no
* @brief  Display Power Voltage
void OSD_VDD()
    OLED_ShowString(8, 2, "VDD:", 8);
    udelay(1);
    g_adcValue = ADC_GetRegularConversionValue(ADC);       ///<Float Voltage display
    g_vdd = (VOLTAGE_BG / g_adcValue) * 4095;
    g_displayValue = (uint32_t)g_vdd;
    OLED_ShowNum(48, 2, g_displayValue, 1, 8);
    OLED_ShowString(56, 2, ".", 8);
    g_displayValue = (uint32_t)(g_vdd * 10) % 10;
    OLED_ShowNum(64, 2, g_displayValue , 1, 8);
    g_displayValue = (uint32_t)(g_vdd * 100) % 10;         ///<Float Voltage display
    OLED_ShowNum(72, 2, g_displayValue , 1, 8);
    OLED_ShowString(80, 2, "V", 8);
* main
* @param[in]  none
* @return 0: success, other: error value
* @brief  use ADC detect pressed KEYss
int main(void)
    ADC_InitType tempAdcConfig = {0, 0, 0, 0, 0, 0, 1};
    ADC_TrigSourceType tempAdcTrigSource = {0, 0};
    ADC_InitType* adcConfig;
    ADC_TrigSourceType* adcTrigSource;
    adcConfig = &tempAdcConfig;
    adcTrigSource = &tempAdcTrigSource;
    adcConfig->scanMode = 0;///ADC mode 0
    adcConfig->continousMode = 0;
    adcConfig->disContinousModeOnRegularGroup = 0;
    adcConfig->disContinousModeOnInjectGroup = 0;
    adcConfig->injectAutoMode = 0;
    GPIO_SetFunc(8, 1); ///ADC_IN1 Analog function enable
    ADC_Init(ADC, adcConfig);  ///ADC works Mode Config
    ADC_SetClockPrescaler(ADC, 4); ///Set ADC Prescaler
    ADC_TrigSourceInit(ADC, adcTrigSource);
    ADC_SetRegularGroupLength(ADC, 1);
    ADC_SetRegularGroupSequence(ADC, 1, ADC_CHANNEL_AD16_BANDGAP); ///set ADC_CHANNEL_AD16_BANDGAP for AD Sample
    ADC_ChannelSampleTimeSel(ADC, ADC_CHANNEL_AD1, ADC_SampleTime_14Cycle);///Set ADC_CHANNEL1 Sample Cycles
    ADC_ChannelSampleTimeSel(ADC, ADC_CHANNEL_AD16_BANDGAP, ADC_SampleTime_14Cycle);///Set ADC_CHANNEL_AD16_BANDGAP Sample Cycles
    ADC_Cmd(ADC, ENABLE);
    InitDelay();
    InitDebug(); /// Initialize debug UART 1
    OLED_Init();
    OLED_Clear();
    printf("\r\nAC7811: ADC_Demo\r\n");
    OLED_ShowString(0, 0, "ADC Demo", 8);
    OLED_DrawBMP(64, 4, 128, 8, g_atc**BMP);
    OSD_VDD();
    OLED_ShowString(8, 3, "Pressed Keypad:", 8);
    OLED_ShowString(8, 4, "NO Key", 8);
    ADC_SetRegularGroupSequence(ADC, 1, ADC_CHANNEL_AD1); //set ADC_CHANNEL1 for AD Sample
    mdelay(100);
    while(1)
        OSD_KEY();
        mdelay(100);
效果图:
operating| | 2019-11-17 17:42 | 只看该作者
感谢楼主分享!
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
