3A 开关型同步降压多节锂电池充电管理芯片ZCC6688
461|2
SWdianzi|  楼主 | 2019-11-21 15:19 | 显示全部楼层 |阅读模式
General Description
The ZCC6688 is a 2A Li-Ion battery charger. It utilizes
a 500KHz synchronous buck converter topology to
reduce power dissipation during charging. Low power
dissipation, an internal MOSFET allow a physically
small charger that can be embedded in a wide range
of handheld applications. The ZCC6688 includes
complete charge termination circuitry, automatic
recharge and a ±1% 4.2V / 8.4V / 12.6V float voltage.
Battery charge current, charge timeout and end-ofcharge
indication parameters are set with external
components. Additional features include shorted cell
detection; temperature qualified charging and
overvoltage protection. The ZCC6688 is available in a
low profile ESOP8 and package.
Features
‹ Input voltage range 4V~20V
‹ Dynamic input current allocation for maximum
charging rate
‹ 3.0A Maximum Charge Current
‹ No External MOSFETs and Blocking Diode
Required
‹ Efficiency up to 90%
‹ Constant-Current/Constant-Voltage Operation
with Thermal Regulation to Maximize Charge
Rate Without Risk of Overheating
‹ Optional Battery Temperature Monitoring Before and During Charge Automatic Sleep Mode for
Low-Power
‹ Over Current Protection
‹ Consumption Available in ESOP8
‹ RoHS Compliant and 100% Lead (Pb)-Free
li201312| | 2020-2-22 19:24 | 显示全部楼层
我~~~~~~~~~~~~~~~ 真~~~~~~~~~~ 挫~~~~~~~~~
发新帖
