[DemoCode下载] NUC200的时钟演示
688|8
 楼主| heisexingqisi 发表于 2019-11-24 20:33 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
  4. * $Revision: 6 $
  5. * $Date: 15/04/13 11:46a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Get the current RTC data/time per tick.
  7. * @note
  8. * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
  9. ******************************************************************************/
  10. #include <stdio.h>
  11. #include "NUC200Series.h"
  12. #define PLL_CLOCK           50000000
  13. /*---------------------------------------------------------------------------------------------------------*/
  14. /* Global Interface Variables Declarations        */
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. volatile uint32_t g_u32RTCTickINT;
  17. /**
  18. * @brief       IRQ Handler for RTC Interrupt
  19. *
  20. * @param       None
  21. *
  22. * [url=home.php?mod=space&uid=266161]@return[/url]      None
  23. *
  24. * [url=home.php?mod=space&uid=1543424]@Details[/url]     The RTC_IRQHandler is default IRQ of RTC, declared in startup_NUC200Series.s.
  25. */
  26. void RTC_IRQHandler(void)
  27. {
  28.     /* To check if RTC Tick interrupt occurred */
  29.     if(RTC_GET_TICK_INT_FLAG() == 1)
  30.     {
  31.         /* Clear RTC tick interrupt flag */
  32.         RTC_CLEAR_TICK_INT_FLAG();
  33.         g_u32RTCTickINT++;
  34.         PB8 ^= 1;
  35.     }
  36. }
  37. void SYS_Init(void)
  38. {
  39.     /*---------------------------------------------------------------------------------------------------------*/
  40.     /* Init System Clock        */
  41.     /*---------------------------------------------------------------------------------------------------------*/
  42.     /* Enable Internal RC 22.1184MHz clock */
  43.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  44.     /* Waiting for Internal RC clock ready */
  45.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  46.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  47.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  48.     /* Enable external XTAL 12MHz clock and 32 kHz XTAL */
  49.     CLK_EnableXtalRC((CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_XTL32K_EN_Msk));
  50.     /* Waiting for clock ready */
  51.     CLK_WaitClockReady((CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_XTL32K_STB_Msk));
  52.     /* Set core clock as PLL_CLOCK from PLL */
  53.     CLK_SetCoreClock(PLL_CLOCK);
  54.
  55.     /* Enable UART module clock */
  56.     CLK_EnableModuleClock(UART0_MODULE);
  57.
  58.     /* Select UART module clock source */
  59.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  60.
  61.     /* Enable RTC module clock */
  62.     CLK_EnableModuleClock(RTC_MODULE);
  63.     /*---------------------------------------------------------------------------------------------------------*/
  64.     /* Init I/O Multi-function        */
  65.     /*---------------------------------------------------------------------------------------------------------*/
  66.     /* Set PB multi-function pins for UART0 RXD, TXD */
  67.     SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
  68.     SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
  69. }
  70. void UART0_Init(void)
  71. {
  72.     /*---------------------------------------------------------------------------------------------------------*/
  73.     /* Init UART        */
  74.     /*---------------------------------------------------------------------------------------------------------*/
  75.     /* Reset UART0 */
  76.     SYS_ResetModule(UART0_RST);
  77.     /* Configure UART0 and set UART0 Baudrate */
  78.     UART_Open(UART0, 115200);
  79. }
  80. /*---------------------------------------------------------------------------------------------------------*/
  81. /*  MAIN function        */
  82. /*---------------------------------------------------------------------------------------------------------*/
  83. int main(void)
  84. {
  85.     S_RTC_TIME_DATA_T sWriteRTC, sReadRTC;
  86.     uint32_t u32Sec;
  87.     /* Unlock protected registers */
  88.     SYS_UnlockReg();
  89.     /* Init System, peripheral clock and multi-function I/O */
  90.     SYS_Init();
  91.     /* Lock protected registers */
  92.     SYS_LockReg();
  93.     /* Init UART0 for printf */
  94.     UART0_Init();
  95.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  96.     printf("+-----------------------------------------+\n");
  97.     printf("|    RTC Date/Time and Tick Sample Code   |\n");
  98.     printf("+-----------------------------------------+\n\n");
  99.     /* Open RTC and start counting */
  100.     sWriteRTC.u32Year       = 2014;
  101.     sWriteRTC.u32Month      = 2;
  102.     sWriteRTC.u32Day        = 6;
  103.     sWriteRTC.u32DayOfWeek  = RTC_THURSDAY;
  104.     sWriteRTC.u32Hour       = 15;
  105.     sWriteRTC.u32Minute     = 30;
  106.     sWriteRTC.u32Second     = 30;
  107.     sWriteRTC.u32TimeScale  = RTC_CLOCK_24;
  108.     RTC_Open(&sWriteRTC);
  109.     /* Enable RTC tick interrupt, one RTC tick is 1/4 second */
  110.     NVIC_EnableIRQ(RTC_IRQn);
  111.     RTC_EnableInt(RTC_RIER_TIER_Msk);
  112.     RTC_SetTickPeriod(RTC_TICK_1_4_SEC);
  113.     printf("# Showing RTC Date/Time on UART-0.\n\n");
  114.     printf("Date/Time is: (Use PB.8 to check tick period time is 1/4 second) \n");
  115.     /* Use PB.8 to check tick period time */
  116.     PB->PMD = (PB->PMD & ~0x00030000) | (0x00010000);
  117.     u32Sec = 0;
  118.     g_u32RTCTickINT = 0;
  119.     while(1)
  120.     {
  121.         if(g_u32RTCTickINT == 4)
  122.         {
  123.             g_u32RTCTickINT = 0;
  124.             /* Read current RTC date/time */
  125.             RTC_GetDateAndTime(&sReadRTC);
  126.             printf("    %d/%02d/%02d %02d:%02d:%02d\r",
  127.                    sReadRTC.u32Year, sReadRTC.u32Month, sReadRTC.u32Day, sReadRTC.u32Hour, sReadRTC.u32Minute, sReadRTC.u32Second);
  128.             if(u32Sec == sReadRTC.u32Second)
  129.             {
  130.                 printf("\nRTC tick period time is incorrect.\n");
  131.                 while(1);
  132.             }
  133.             u32Sec = sReadRTC.u32Second;
  134.         }
  135.     }
  136. }
  137. /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
RTC很强大的。
幸福小强 发表于 2019-11-24 21:43 | 显示全部楼层
这个好懂。
caoqing 发表于 2019-11-25 11:56 | 显示全部楼层
有误差在哪里调节参数???
manufact 发表于 2019-11-25 16:41 | 显示全部楼层
有些简介说明的话更好
huahuagg 发表于 2019-11-26 21:26 来自手机 | 显示全部楼层
误差应该是时钟源
一般rtc都要用到这种结构体
dongnanxibei 发表于 2019-11-27 07:05 | 显示全部楼层
滴答时钟。
滴答时钟。
