[DemoCode下载]
ML51的Clock输出
555|1
捉虫天师|  楼主 | 2019-11-29 21:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  File Function: ML51 simple GPIO toggle out demo code
#include "ML51.h"
* [url=home.php?mod=space&uid=247401]@brief[/url]       Clock output enable
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     P3.2 / P4.6 / P5.6 can be setting as clock out function.
void main (void)
/* Setting P3.2 or P4.6 or P5.6 Multi function pin setting for GPIO clock out toggle
         * include gipo.c in Common for GPIO mode setting
                MFP_P32_GPIO;
                P32_PUSHPULL_MODE;
                MFP_P46_GPIO;
                P46_PUSHPULL_MODE;
                MFP_P56_GPIO;
                P56_PUSHPULL_MODE;
Clock out enable setting
                set_CKCON_CLOEN;
                while(1);        //check the pin setting as clock output.
jiekou001| | 2019-11-29 21:36 | 只看该作者
时钟输出,可以检测时钟,或者给外部需要时钟的设备提供时钟源,而且内部的RC时钟源是非常可靠的。
