[DemoCode下载]
BOD欠压关闭
404|3
捉虫天师|  楼主 | 2019-11-29 21:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Jan/21/2019
//  File Function: ML51 power down code for test power down current, BOD disabled.
#include "ML51.H"
void main (void)
  unsigned char i;
/*As Default all GPIO multi function is GPIO mode */
/*Quasi mode better for power down power comsuption */
  ALL_GPIO_QUASI_MODE;
  P0=0;
  P1=0;
  P2=0;
/* clock only for reference, real chip please don't output clock*/
  set_CKCON_CLOEN;
/*MUST DISABLE BOD to low power */
  DISABLE_BOD;              //BOD enable power down current please check datasheet DC charactor.
  while(P01);
  for (i=0;i<0x05;i++)
    P3 = ~P3;
    Timer0_Delay(24000000,200,1000);
/* Real into power down mode */
  set_PCON_PD;
  while(1);
jiekou001| | 2019-11-29 21:35 | 只看该作者
51内核的看着没多大区别
天灵灵地灵灵| | 2019-11-30 18:03 | 只看该作者
这种根本不用搞库函数,新唐做的头文件宏就完全搞定,看着so easy.
天灵灵地灵灵| | 2019-11-30 18:06 | 只看该作者
如果要求不高用增强51内核是非常科学的,用起来更简单,开发周期短,代码紧凑。
