[DemoCode下载]
51定义const数据的方法
329|2
jiekou001|  楼主 | 2019-11-29 21:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Jan/21/2019
//  File Function: ML51 Table complier in APROM demo code.
#include "ML51.H"
/* define table data in the APROM */
/*table loacation is defined by keil compiler */
code unsigned char IMAGE_DATA[] = {
    0x02, 0x02, 0x01, 0x11, 0x12, 0x12, 0x22, 0x22,
    0x66, 0x69, 0x69, 0x59, 0x58, 0x99, 0x99, 0x88,
void main(void)
    unsigned char readtemp;
    ALL_GPIO_QUASI_MODE;
/* Initial UART0 for printf */
    MFP_P31_UART0_TXD;
    P31_PUSHPULL_MODE;
    UART_Open(24000000,UART0_Timer3,115200);
    ENABLE_UART0_PRINTF;
    printf ("\n Table Value = ");
    for(readtemp;readtemp<0x10;readtemp++)
      printf (" 0x%bx",IMAGE_DATA[readtemp]);
    while(1);
天灵灵地灵灵| | 2019-11-30 17:44 | 只看该作者
code放第一位。
wanduzi| | 2019-11-30 20:01 | 只看该作者
这个需要试试,体验一下,当年这个关键词没有学好
