死活都不能进行读操作
296|4
supernan|  楼主 | 2019-12-1 15:26 | 显示全部楼层 |阅读模式
可以向SPI从设备写操作,但是死活都不能进行读操作
chuxh| | 2019-12-1 15:30 | 显示全部楼层
什么片子啊
llljh| | 2019-12-1 15:33 | 显示全部楼层
程序看看
supernan|  楼主 | 2019-12-1 15:37 | 显示全部楼层
void SPI_Write(unsigned char dig)
        PRT2DR |= CS;
        while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_TX_BUFFER_EMPTY)){};
        PRT2DR &= ~CS;                         // set slave select low
        SPIM_1_SendTxData(dig); // set message to transmit
        while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_SPI_COMPLETE)){};
        PRT2DR |= CS;                        //
unsigned char SPI_Read(void)
        unsigned char ReceivedData;
        PRT2DR |= CS;
        PRT2DR &= ~CS;
        SPIM_1_SendTxData(0x00);  // 写伪数据,以便读到数据
        while(!(SPIM_1_bReadStatus() &  SPIM_1_SPIM_RX_BUFFER_FULL));//RX Buffer register has received current data
        ReceivedData = SPIM_1_bReadRxData();
        PRT2DR |= CS;
        return ReceivedData;
supernan|  楼主 | 2019-12-1 15:39 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家,结贴了哈
