[DemoCode下载]
I2C从机都可以唤醒系统
816|16
wanduzi|  楼主 | 2020-1-23 21:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 16 $
* $Date: 16/06/21 7:44p $
* @brief
*           Demonstrate how to set I2C to wake-up MCU from power-down mode.
*           Needs to work with I2C_Wakeup_Master sample code.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define PLLCON_SETTING      CLK_PLLCON_72MHz_HXT
#define PLL_CLOCK           72000000
/* Global variables        */
volatile uint32_t slave_buff_addr;
volatile uint8_t g_au8SlvData[256];
volatile uint8_t g_au8SlvRxData[3];
volatile uint8_t g_u8SlvPWRDNWK, g_u8SlvI2CWK;
volatile uint8_t g_u8DeviceAddr;
volatile uint8_t g_u8SlvDataLen;
typedef void (*I2C_FUNC)(uint32_t u32Status);
static I2C_FUNC s_I2C0HandlerFn = NULL;
/*  I2C0 IRQ Handler        */
void I2C0_IRQHandler(void)
    uint32_t u32Status;
    /* Check I2C Wake-up interrupt flag set or not */
    if(I2C_GET_WAKEUP_FLAG(I2C0))
        /* Clear I2C Wake-up interrupt flag */
        I2C_CLEAR_WAKEUP_FLAG(I2C0);
        g_u8SlvI2CWK = 1;
        return;
    u32Status = I2C_GET_STATUS(I2C0);
    if(I2C_GET_TIMEOUT_FLAG(I2C0))
        /* Clear I2C0 Timeout Flag */
        I2C_ClearTimeoutFlag(I2C0);
    else
        if(s_I2C0HandlerFn != NULL)
            s_I2C0HandlerFn(u32Status);
/*  Power Wake-up IRQ Handler        */
void PWRWU_IRQHandler(void)
    /* Check system power down mode wake-up interrupt flag */
    if(((CLK->PWRCON) & CLK_PWRCON_PD_WU_STS_Msk) != 0)
        /* Clear system power down wake-up interrupt flag */
        CLK->PWRCON |= CLK_PWRCON_PD_WU_STS_Msk;
        g_u8SlvPWRDNWK = 1;
/*  I2C Slave Transmit/Receive Callback Function                                                           */
void I2C_SlaveTRx(uint32_t u32Status)
    if(u32Status == 0x60)                       /* Own SLA+W has been receive; ACK has been return */
        g_u8SlvDataLen = 0;
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI_AA);
    else if(u32Status == 0x80)                 /* Previously address with own SLA address
                                                   Data has been received; ACK has been returned*/
        g_au8SlvRxData[g_u8SlvDataLen] = (unsigned char)I2C_GET_DATA(I2C0);
        g_u8SlvDataLen++;
        if(g_u8SlvDataLen == 2)
            slave_buff_addr = (g_au8SlvRxData[0] << 8) + g_au8SlvRxData[1];
        if(g_u8SlvDataLen == 3)
            g_au8SlvData[slave_buff_addr] = g_au8SlvRxData[2];
            g_u8SlvDataLen = 0;
    else if(u32Status == 0xA8)                  /* Own SLA+R has been receive; ACK has been return */
        I2C_SET_DATA(I2C0, g_au8SlvData[slave_buff_addr]);
        slave_buff_addr++;
    else if(u32Status == 0xC0)                 /* Data byte or last data in I2CDAT has been transmitted
                                                   Not ACK has been received */
    else if(u32Status == 0x88)                 /* Previously addressed with own SLA address; NOT ACK has
                                                   been returned */
        g_u8SlvDataLen = 0;
    else if(u32Status == 0xA0)                 /* A STOP or repeated START has been received while still
                                                   addressed as Slave/Receiver*/
        g_u8SlvDataLen = 0;
    else
        /* TO DO */
        printf("Status 0x%x is NOT processed\n", u32Status);
/*  System initial function        */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable XT1_OUT (PF0) and XT1_IN (PF1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable I2C0 module clock */
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
    /* Set GPF multi-function pins for I2C0 SDA and SCL */
    SYS->GPF_MFP |= (SYS_GPF_MFP_PF2_I2C0_SDA | SYS_GPF_MFP_PF3_I2C0_SCL);
    SYS->ALT_MFP1 &= ~(SYS_ALT_MFP1_PF2_Msk | SYS_ALT_MFP1_PF3_Msk);
    SYS->ALT_MFP1 |= (SYS_ALT_MFP1_PF2_I2C0_SDA | SYS_ALT_MFP1_PF3_I2C0_SCL);
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C0 clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
    /* Set I2C 4 Slave Addresses */
    I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
    I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
    I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
    I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
    /* Set I2C 4 Slave Addresses Mask */
    I2C_SetSlaveAddrMask(I2C0, 0, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 1, 0x04);
    I2C_SetSlaveAddrMask(I2C0, 2, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 3, 0x04);
    /* Enable I2C interrupt */
    I2C_EnableInt(I2C0);
    NVIC_EnableIRQ(I2C0_IRQn);
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
/*  Main Function        */
int32_t main(void)
    uint32_t i;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Lock protected registers */
    SYS_LockReg();;
        This sample code is I2C SLAVE mode and it simulates EEPROM function
    printf("\n");
    printf("+-----------------------------------------------------------------------+\n");
    printf("| NUC123 I2C Driver Sample Code (Slave) for wake-up & access Slave test |\n");
    printf("| Needs to work with I2C_Wakeup_Master sample code.                     |\n");
    printf("|      I2C Master (I2C0) <---> I2C Slave (I2C0)                         |\n");
    printf("| !! This sample code requires two borads to test !!                    |\n");
    printf("Configure I2C0 as a slave.\n");
    printf("The I/O connection for I2C0:\n");
    printf("I2C0_SDA(PF.2), I2C0_SCL(PF.3)\n");
    /* Init I2C0 */
    I2C0_Init();
    for(i = 0; i < 0x100; i++)
        g_au8SlvData[i] = 0;
    /* I2C function to Transmit/Receive data as slave */
    s_I2C0HandlerFn = I2C_SlaveTRx;
    /* Set I2C0 enter Not Address SLAVE mode */
    SYS_UnlockReg();
    /* Enable power wake-up interrupt */
    CLK->PWRCON |= CLK_PWRCON_PD_WU_INT_EN_Msk;
    NVIC_EnableIRQ(PWRWU_IRQn);
    /* Enable I2C wake-up */
    I2C_EnableWakeup(I2C0);
    printf("\n");
    printf("Enter PD 0x%x 0x%x\n", I2C0->I2CON , I2C0->I2CSTATUS);
    printf("\n");
    printf("CHIP enter power down status.\n");
    /* Waiting for UART printf finish*/
    while(((UART0->FSR) & UART_FSR_TE_FLAG_Msk) == 0);
    if(((I2C0->I2CON)&I2C_I2CON_SI_Msk) != 0)
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
    /*  Use WFI instruction to idle the CPU. NOTE:
        If ICE is attached, system will wakeup immediately because ICE is a wakeup event. */
    CLK_PowerDown();
    while((g_u8SlvPWRDNWK & g_u8SlvI2CWK) == 0);
    printf("Power-down Wake-up INT 0x%x\n", ((CLK->PWRCON) & CLK_PWRCON_PD_WU_STS_Msk));
    printf("I2C0 WAKE INT 0x%x\n", I2C0->I2CWKUPSTS);
    /* Disable power wake-up interrupt */
    CLK->PWRCON &= ~CLK_PWRCON_PD_WU_INT_EN_Msk;
    NVIC_DisableIRQ(PWRWU_IRQn);
    SYS_LockReg();
    printf("\n");
    printf("Slave wake-up from power down status.\n");
    printf("\n");
    printf("Slave Waiting for receiving data.\n");
    while(1);
wanduzi|  楼主 | 2020-1-23 21:45 | 只看该作者
通过从机都可以唤醒休眠的系统也是非常非常牛的。
这种方法非常实用于低功耗系统。
xixi2017| | 2020-1-24 13:58 | 只看该作者
所有的唤醒,均来自中断。
xuanhuanzi| | 2020-1-24 14:39 | 只看该作者
一般的中断都可以唤醒休眠
antusheng| | 2020-1-24 15:10 | 只看该作者
硬件收发器用好了非常棒
dongnanxibei| | 2020-1-24 15:26 | 只看该作者
例子中使用了大量的printf
会不会影响系统的速度。另外I2C的速度由什么控制的
gejigeji521| | 2020-1-25 15:46 | 只看该作者
中断应用十分广泛。
zhuotuzi| | 2020-1-25 22:21 | 只看该作者
我要找个I2C的文档看看。
gejigeji521| | 2020-1-26 11:29 | 只看该作者
volatile关键字用的好
全局变量在地址里,用这个关键字可以保证每次从原来地址读取
xixi2017| | 2020-1-26 19:18 | 只看该作者
太赞了。
zhuomuniao110| | 2020-1-31 22:05 | 只看该作者
SPI也可以唤醒吧
zhuomuniao110| | 2020-1-31 22:06 | 只看该作者
查看了一下,SPI不可以唤醒。
643757107| | 2020-1-31 22:15 | 只看该作者
分享的资料不错。
jiekou001| | 2020-2-2 21:04 | 只看该作者
中断系统的强大,低功耗设计的高级。
