[DemoCode下载]
M051使用库函数输出互补PWM信号方法
1723|4
734774645|  楼主 | 2020-2-20 12:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 15/05/22 2:05p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    通过P40(24)和P41(PIN36)输出两路PWM信号.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global variables        */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
    /* Enable PLL and Set PLL frequency */
    CLK_SetCoreClock(PLLCON_SETTING);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM module clock */
    CLK_EnableModuleClock(PWM01_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select PWM module clock source */
    CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT, 0);
    /* Reset PWMA channel0~channel3 */
    SYS_ResetModule(PWM03_RST);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Set P4 multi-function pins for PWMA Channel 0 and 1 */
    SYS->P4_MFP &= ~(SYS_MFP_P40_Msk|SYS_MFP_P41_Msk);
    SYS->P4_MFP |= (SYS_MFP_P40_PWM0|SYS_MFP_P41_PWM1);
void UART0_Init(void)
    /* Init UART        */
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
        uint8_t i=100;
        /* Unlock protected registers */
        SYS_UnlockReg();
        /* Init System, IP clock and multi-function I/O */
        SYS_Init();
        /* Lock protected registers */
        SYS_LockReg();
        /* Init UART0 for printf */
        UART0_Init();
//使能PWM0和PWM1通道
        PWM_EnableOutput(PWMA, 0x1|0x2);
        //设置PWM0通道的频率与占空比配置,因为是互补输出,只需要设置PWM0的即可
        PWM_ConfigOutputChannel(PWMA, PWM_CH0, 1000, i);
//使能死区功能,死区设置为0,即生成完全互补信号。
        PWM_EnableDeadZone(PWMA,PWM_CH0,0);
        PWM_Start(PWMA, 0x1|0x2);
        GPIO_SetMode(P3,BIT6,GPIO_PMD_OUTPUT);
        while(1)
                while(i>0)
                        i=i-1;
                        CLK_SysTickDelay(10000);
//驱动板载的LED红灯闪烁
                P36 ^=1;
                while(i<100)
                        i=i+1;
//驱动板载的LED红灯闪烁
                P36 ^=1;
新版的库函数在多个系列中都是通用的, 因此会了新版库函数,可以在任意一款新唐单片机中实现。移植能力超强。
zhuomuniao110| | 2020-2-20 12:21 | 只看该作者
大佬给力,精简,易懂
antusheng| | 2020-2-20 12:27 | 只看该作者
看懂了,比例程还好懂。
yiy| | 2020-2-20 23:25 | 只看该作者
学会了好容易啊。
