先上代码:
UINT8 znFAT_Enter_Dir2(INT8 *dirpath,UINT32 *pCluster,UINT32 *pos)
 UINT8 index=0,res=0;
 UINT32 i=1;
// #ifndef USE_LFN
 INT8 dirname[13];
// #else
// INT8 dirname[MAX_LFN_LEN+1];
// #endif
 *pos=1;
 *pCluster=2;
        printf("000\r\n");
 if(('\\'==dirpath[0] || '/'==dirpath[0]) && '\0'==dirpath[1]) //Èç¹ûÊÇ"\\"£¬ÔòÖ±½ÓÈ¡Ê×Ŀ¼´Ø£¬¼´µÚ2´Ø
         printf("222\r\n");
  return ERR_SUCC;
 printf("111\r\n");
 while('\0'!=dirpath)
  if('\\'==dirpath || '/'==dirpath)
   dirname[index]='\0';
   index=0;
   res=Get_Dir_Start_Cluster(dirname,pCluster);
   if(res)
                 printf("333\r\n");
                        return res;  //·µ»Ø´íÎóÂë
   *pos=i+1;
  else
   dirname[index]=dirpath;
   index++;
   #ifndef USE_LFN
   if(index>12) //Èç¹û²»Ê¹Óó¤Ãû£¬ÔòĿ¼ÃûÒÔ¼°ÎļþÃû×²»Äܳ¬¹ý8+1+3
                        printf("444\r\n");
        return ERR_SFN_ILL_LEN; //Ŀ¼Ãû³¤ÓÚ8.3£¬Òà·ÀÖ¹dirnameÒç³ö
   #else
   if(index>MAX_LFN_LEN) //Èç¹ûʹÓó¤Ãû£¬ÔòĿ¼ÃûÒÔ¼°ÎļþÃû×²»Äܳ¬¹ýÉ趨µÄ³¤Ãû×³¤¶È
                 printf("555\r\n");
        return ERR_LFN_BUF_OUT; //Ŀ¼Ãû³¤ÓÚMAX_LFN_LEN£¬Òà·ÀÖ¹dirnameÒç³ö
   #endif
  i++;
 printf("666\r\n");
 return ERR_SUCC; //³É¹¦
int main(void)
        UINT32 res=0,len=0;
        UINT32 i,j,n,x,y;
        UINT8 temp;
        UINT32 ncluster=0;        //Ö¸¶¨Ä¿Â¼ÎªÊ×Ŀ¼
        UINT32 *p;
        delay_init();
        uart_init(115200); //´®¿Ú³õʼ»¯Îª115200
        printf("´®¿ÚÉèÖÃÍê±Ï\r\n");
        znFAT_Device_Init(); //´æ´¢É豸³õʼ»¯
  printf("SD¿¨³õʼ»¯Íê±Ï\r\n");
        TFT_init2();
        TFT_clear(0x001f);
        TFT_GPIO_DeInit();
        znFAT_Select_Device(0,&Init_Args); //Ñ¡ÔñÉ豸
        TFT_init1();
        TFT_clear(0x0000);
        res=znFAT_Init(); //Îļþϵͳ³õʼ»¯
         if(!res) //Îļþϵͳ³õʼ»¯³É¹¦
                printf("Suc. to init FS\r\n");
                printf("BPB_Sector_No: %d",Init_Args.BPB_Sector_No);
                printf("Total_SizeKB: %d",Init_Args.Total_SizeKB);
                printf("BytesPerSector: %d",Init_Args.BytesPerSector);
                printf("FATsectors: %d",Init_Args.FATsectors);
                printf("SectorsPerClust: %d",Init_Args.SectorsPerClust);
                printf("FirstFATSector: %d",Init_Args.FirstFATSector);
                printf("FirstDirSector: %d",Init_Args.FirstDirSector);
                printf("FSsec: %d",Init_Args.FSINFO_Sec);
                printf("Next_Free_Cluster: %d",Init_Args.Next_Free_Cluster);
                printf("FreenCluster: %d\n",Init_Args.Free_nCluster);
         else //Îļþϵͳ³õʼ»¯Ê§°Ü
                printf("Fail to init FS , Err Code: %d",res);
         printf("AAA\r\n");
         //if(!znFAT_Enter_Dir("\\ABC\\A\\B\\C\\D\\E\\F\\G\\H\\I\\J\\",&ncluster,p))
         if(!znFAT_Enter_Dir2("\\ABC\\",&ncluster,p))
                 printf("start cluster is %d\n",ncluster);
         else
                 printf("fail.\n");
         printf("BBB\r\n");
        return 0;
 //while(1);
定义了一个函数:
功能是进入一个目录,获取目录的开始簇。
程序下载进去,用串口助手查看,如下:
只打印到AAA就停止了。
我在znFAT_Enter_Dir2这个函数内部也设置了好多打印语句,可是一句也没打印出来。
貌似进入该函数以后,出不来了,而且好像什么也没执行。
我感到很奇怪,百思不得其解。
还有一个问题,UINT8,UINT32明明定义了,可是双击找定义的地方,提示:
求高手解惑,谢谢!
