[技术问答] UART:调试助手接收到数据和M482发送的不一致
888|8
 楼主| Tars 发表于 2020-4-20 10:58 | 显示全部楼层 |阅读模式
新唐M482SIDAE
芯片发送一组pu8TxBuf[10] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09};
我用USB-TTL,直接与PA.8、PA.9、GND相连
不知道为什么会这样,请各位大神指教。
代码如下:
#include "stdio.h"
#include "NuMicro.h"
#define PLL_CLOCK   192000000
#define RXBUFSIZE   1024
void SYS_Init(void)
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2); // PCLK divider set 2
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART1_MODULE);
    CLK_EnableModuleClock(UART2_MODULE);
    /* Select UART clock source is HXT */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_UART1SEL_Msk) | (0x0 << CLK_CLKSEL1_UART1SEL_Pos);
   /* Set GPA multi-function pins for UART1 RXD and TXD */
    SYS->GPA_MFPH &= ~(SYS_GPA_MFPH_PA8MFP_Msk | SYS_GPA_MFPH_PA9MFP_Msk);
    SYS->GPA_MFPH |= (SYS_GPA_MFPH_PA8MFP_UART1_RXD | SYS_GPA_MFPH_PA9MFP_UART1_TXD);
void UART1_Init()
        SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 baud rate */
        UART_SetLineConfig(UART1, 115200, UART_WORD_LEN_8, UART_PARITY_NONE, UART_STOP_BIT_1);
void Delay(int count)
        int32_t a;
        for ( ; count>0; count--)
                for (a = 0; a < 1000; a++);
/* UART Test Sample        */
/* Test Item        */
/* It sends the received data to HyperTerminal.                                                            */
int32_t main(void)
        uint8_t pu8TxBuf[10] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09};
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf and test */
    UART1_Init();
    while(1)
                UART_Write(UART1, pu8TxBuf, 10);
                Delay(60000);
 楼主| Tars 发表于 2020-4-21 13:10 | 显示全部楼层
找到问题了,我用的是8M晶振,官方例程中HET设置为12M
修改之后就好了(/汗)
谢谢各位!
zhuomuniao110 发表于 2020-4-20 13:01 | 显示全部楼层
你用printf试试看。
zhuomuniao110 发表于 2020-4-20 13:02 | 显示全部楼层
你这种情况我真没遇到过。
zhuomuniao110 发表于 2020-4-20 13:03 | 显示全部楼层
你先发送一个数字,比如0x00
 楼主| Tars 发表于 2020-4-20 13:29 | 显示全部楼层
你先发送一个数字,比如0x00
您好,我发送一个字节和printf,调试助手显示依旧和发送内容不一样
dongnanxibei 发表于 2020-4-20 19:30 | 显示全部楼层
莫非波特率设置有问题?
dongnanxibei 发表于 2020-4-20 19:32 | 显示全部楼层
官方有串口的例子,你跑一个原版例子看看。
jasontu 发表于 2020-4-21 07:57 | 显示全部楼层
检查下调试助手的设定
