108khz微孔雾化片呼吸灯02
779|1
 楼主| 34af9uc 发表于 2020-11-1 22:12 | 显示全部楼层 |阅读模式
/********************QQ774145445*******************/
/*****************快手:共同学习STM8****************/
/****************108khz微孔雾化片******************/
/********************20201030*********************/
#include        "extern.h"
anjian                bit                pa.4;
led                        bit                pa.6;
wuhuapian        bit                pa.3;
void                yanshi();                //延时
void                huxideng();                //呼吸灯
byte                yanshi_a1;                //延时用
byte                huxi_a1,huxi_a2;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/2, IHRC=15MHz, VDD=5V;
$                wuhuapian                in,low;//High / Low置低
$                tm2c                ihrc,pa3,pwm;
//tm2ct                //tim2计数寄存器
//tm2b                //上限寄存器
$                tm2s                6bit,/1,/2;                //117.64khz
tm2b        =31;//127;
$                led                out,low;                //high
yanshi_a1                =100;                //最大130最小10
while (1)
huxideng();
void                huxideng()                //呼吸灯
//yanshi_a1                =100;                //最大130最小10
/**************************************************/        //渐亮
huxi_a1                =19;
huxi_a2                =20;        //10
while(!(huxi_a2==85))
        huxi_a1                ++;
        if(huxi_a1==huxi_a2)
                led        =0;
        if(huxi_a1==100)
                led        =1;
                huxi_a1        =0;
                huxi_a2        ++;
        yanshi();
/**************************************************/        //渐暗
huxi_a1                =19;
huxi_a2                =20;        //10
while(!(huxi_a2==85))//100-10//100
        huxi_a1                ++;
        if(huxi_a1==huxi_a2)                //比较打开
                led        =1;
        if(huxi_a1==100)                //关闭
                led        =0;
                huxi_a1        =0;
                huxi_a2        ++;
        yanshi();
led=1;
//yanshi_a1                -=1;
void        yanshi()                //延时
byte        yanshi_a2;
yanshi_a2        =yanshi_a1;
while(yanshi_a2)
yanshi_a2        -=1;
nop;
nop;
nop;
nop;
nop;
nop;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
zeshoufx 发表于 2020-11-2 08:43 | 显示全部楼层
谢谢分享【微孔雾化片呼吸灯】
319
