[技术问答]
华大MCU HC32F460 Systick
1668|28
binoo7|  楼主 | 2021-1-18 16:47 | 显示全部楼层 |阅读模式
这次来和大家一起学习华大MCU HC32F460 Systick部分,这部分其实华大给的PDF文档里的内容很少,但是我在例程看到了相关的内容,跟大家一起分享一下吧,废话不多说,开始喽
** \brief SysTick interrupt callback function.
** \param None
** \retval None
void SysTick_IrqHandler(void)
    SysTick_IncTick();
开始,打开工程就看到了一个这个,这是啥,也太简单了吧
binoo7|  楼主 | 2021-1-18 17:35 | 显示全部楼层
别着急,我继续更新
** \brief This function is called to increment a global variable "u32TickCount".
** \note  This variable is incremented in SysTick ISR.
** \param None
** \retval None
__WEAKDEF void SysTick_IncTick(void)
    m_u32TickCount += m_u32TickStep;
这个其实里面就是对一个全局变量进行赋值
binoo7|  楼主 | 2021-1-18 17:38 | 显示全部楼层
/* SysTick configuration */
    SysTick_Init(1000u);
这个函数是初始化Systick
** \brief This function Initializes the interrupt frequency of the SysTick.
** \param [in] u32Freq                 SysTick interrupt frequency (1 to 1000).
** \retval Ok                          SysTick Initializes succeed
** \retval Error                       SysTick Initializes failed
__WEAKDEF en_result_t SysTick_Init(uint32_t u32Freq)
    en_result_t enRet = Error;
    if ((0UL != u32Freq) && (u32Freq <= 1000UL))
        m_u32TickStep = 1000UL / u32Freq;
        /* Configure the SysTick interrupt */
        if (0UL == SysTick_Config(SystemCoreClock / u32Freq))
            enRet = Ok;
    return enRet;
仔细分析一下这个函数
这函数的关键是这里
这是什么意思啊,再次打开 SysTick_Config这个函数看一下
/* ##################################    SysTick function  ############################################ */
  \ingroup  CMSIS_Core_FunctionInterface
  \defgroup CMSIS_Core_SysTickFunctions SysTick Functions
  \brief    Functions that configure the System.
#if defined (__Vendor_SysTickConfig) && (__Vendor_SysTickConfig == 0U)
  \brief   System Tick Configuration
  \details Initializes the System Timer and its interrupt, and starts the System Tick Timer.
           Counter is in free running mode to generate periodic interrupts.
  \param [in]  ticks  Number of ticks between two interrupts.
  \return          0  Function succeeded.
  \return          1  Function failed.
  \note    When the variable <b>__Vendor_SysTickConfig</b> is set to 1, then the
           function <b>SysTick_Config</b> is not included. In this case, the file <b><i>device</i>.h</b>
           must contain a vendor-specific implementation of this function.
__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
  if ((ticks - 1UL) > SysTick_LOAD_RELOAD_Msk)
    return (1UL);                                                   /* Reload value impossible */
  SysTick->LOAD  = (uint32_t)(ticks - 1UL);                         /* set reload register */
  NVIC_SetPriority (SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); /* set Priority for Systick Interrupt */
  SysTick->VAL   = 0UL;                                             /* Load the SysTick Counter Value */
  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
                   SysTick_CTRL_TICKINT_Msk   |
                   SysTick_CTRL_ENABLE_Msk;                         /* Enable SysTick IRQ and SysTick Timer */
  return (0UL);                                                     /* Function successful */
#endif
mdc9 2022-11-28 16:52 回复TA
SysTick_Config 这个函数默认是屏蔽的。官方的专门的 嘀嗒定时器里程居然也是屏蔽的。 那么疑问就来了 没有这个函数的定义 编译为啥不报错?
binoo7|  楼主 | 2021-1-18 17:47 | 显示全部楼层
  \brief  Structure type to access the System Timer (SysTick).
typedef struct
  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  SysTick Control and Status Register */
  __IOM uint32_t LOAD;                   /*!< Offset: 0x004 (R/W)  SysTick Reload Value Register */
  __IOM uint32_t VAL;                    /*!< Offset: 0x008 (R/W)  SysTick Current Value Register */
  __IM  uint32_t CALIB;                  /*!< Offset: 0x00C (R/ )  SysTick Calibration Register */
} SysTick_Type;
看到上一个初始化是怎么做的了吧,就是给SysTick结构体里的内容赋值,
#define MRC_VALUE ((uint32_t)8000000)   /*!< Internal middle speed RC freq. */
初始化的时候用到了一个时钟的一个全局变量,这个变量的赋值是根据这个数来的,8000000就是8M的内部中速时钟频率
binoo7|  楼主 | 2021-1-18 19:10 | 显示全部楼层
** \brief This function provides minimum delay (in milliseconds).
** \param [in] u32Delay                Delay specifies the delay time.
** \retval None
__WEAKDEF void SysTick_Delay(uint32_t u32Delay)
    const uint32_t tickStart = SysTick_GetTick();
    uint32_t tickEnd;
    uint32_t tickMax;
    if (m_u32TickStep != 0UL)
        tickMax = 0xFFFFFFFFUL / m_u32TickStep * m_u32TickStep;
        /* Add a freq to guarantee minimum wait */
        if ((u32Delay >= tickMax) || ((tickMax - u32Delay) < m_u32TickStep))
            tickEnd = tickMax;
        else
            tickEnd = u32Delay + m_u32TickStep;
        while ((SysTick_GetTick() - tickStart) < tickEnd)
这是延时函数,一直在判断设定时间是否与延时的时间是否相同,如果达到后就停止,如果不相同就一直等待,没有用到Systick的中断
mdc9 2022-11-28 16:54 回复TA
这个 嘀嗒定时器 官方 注明了 最大频率 1000Hz “ SysTick interrupt frequency (1 to 1000). “ 没办法微妙级延时吗
binoo7|  楼主 | 2021-1-18 19:20 | 显示全部楼层
STM32是怎么做的呢?下面讲解一下正点原子的方法
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);        //选择外部时钟  HCLK/8
        fac_us=SystemCoreClock/8000000;                                //为系统时钟的1/8
fac_ms=(u16)fac_us*1000;                                        //非OS下,代表每个ms需要的systick时钟数
void delay_us(u32 nus)
        u32 temp;
        SysTick->LOAD=nus*fac_us;                                         //时间加载
        SysTick->VAL=0x00;                                                //清空计数器
        SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk ;        //开始倒数
        do
                temp=SysTick->CTRL;
        }while((temp&0x01)&&!(temp&(1<<16)));                //等待时间到达
        SysTick->CTRL&=~SysTick_CTRL_ENABLE_Msk;        //关闭计数器
        SysTick->VAL =0X00;                                               //清空计数器
//延时nms
//注意nms的范围
//SysTick->LOAD为24位寄存器,所以,最大延时为:
//nms<=0xffffff*8*1000/SYSCLK
//SYSCLK单位为Hz,nms单位为ms
//对72M条件下,nms<=1864
void delay_ms(u16 nms)
        u32 temp;
        SysTick->LOAD=(u32)nms*fac_ms;                                //时间加载(SysTick->LOAD为24bit)
        SysTick->VAL =0x00;                                                        //清空计数器
        do
                temp=SysTick->CTRL;
xyz549040622| | 2021-1-18 22:10 | 显示全部楼层
支持下,,谢谢分享。
麻花油条| | 2021-1-19 15:22 | 显示全部楼层
很棒,支持下
wwppd| | 2022-12-1 17:10 | 显示全部楼层
hc32f460中,systick具体延时时间怎么计算的?
51xlf| | 2022-12-1 19:13 | 显示全部楼层
是否有Systick工程文件可以借鉴呢?
mattlincoln| | 2022-12-1 19:42 | 显示全部楼层
HC32F460 怎么开启systick定时器
caigang13| | 2022-12-1 19:55 | 显示全部楼层
和某T的很像啊
ulystronglll| | 2022-12-1 20:13 | 显示全部楼层
能不能把Systick帖子整合一下?
lzbf| | 2022-12-1 21:15 | 显示全部楼层
systick中断逻辑包括哪些?
iyoum| | 2022-12-1 22:06 | 显示全部楼层
Systick允许的最长和最短定时是多少?
mikewalpole| | 2022-12-2 19:30 | 显示全部楼层
SysTick的优先级是高还是低?
ccook11| | 2022-12-2 20:12 | 显示全部楼层
HC32F460 如何使用Systic(库函数)
bartonalfred| | 2022-12-6 13:20 | 显示全部楼层
Systick的精度怎么样
earlmax| | 2022-12-6 14:20 | 显示全部楼层
为什么芯片不多设计一个定时器,而要添加Systick呢?
janewood| | 2022-12-6 15:01 | 显示全部楼层
感觉Systick比定时器差太多了。
