[其他产品]
Microchip:LAN9252/3 EtherCAT module开发板 评估板
32737|67
      MicrochipTechnologyInc.(美国微芯科技公司)今日宣布推出集成了两个10/100PHY的分立EtherCAT®从属控制器LAN9252。这款高度集成的器件配有两个10/100以太网收发器,同时支持光纤和铜线,并具备电缆诊断功能。LAN9252支持传统的主机总线和SPI/SQI™通信以及独立的数字I/O接口,令系统设计人员在执行实时EtherCAT通信标准时可以从多种单片机型号中灵活选择。此外,对于在工厂自动化、过程控制、电机/运动控制及物联网(IoT)工业以太网应用中使用EtherCAT的开发人员而言,LAN9252可以有效降低系统复杂性和成本。
       LAN9252是集成了两路以太网PHY的2/3端口EtherCAT从控制器,包括了全双工100BASE-TX收发器和支持100Mbps (100BASE-TX),支持3个Fieldbus存储器管理单元(FMMU)和4个SyncManagers,主要用在马达控制,过程/工厂自动化,通信模块,接口卡,传感器,水和气动阀门系统等.
游名科技产品目录20210129.pdf
1.13 MB
LAN9252&LAN9253_module.pdf
485.76 KB
mmuuss586|  楼主 | 2021-1-29 18:03 | 只看该作者
LAN9252/3 is a 2/3-port EtherCAT slave controller with 3 Fieldbus Memory Management Units (FMMUs) and 4 SyncManagers
• Interfaces to most 8/16-bit embedded controllers and 32-bit embedded controllers with an 8/16-bit bus
• Integrated Ethernet PHYs with HP Auto-MDIX
• Wake on LAN (WoL) support
• Low power mode allows systems to enter sleep mode until addressed by the Master
• Cable diagnostic support
• 1.8V to 3.3V variable voltage I/O
• Integrated 1.2V regulator for single 3.3V operation
• Low pin count and small body size package
TABLE OF CONTENTS
1.        Key benefits?
2.        Target Applications
3.        Pinout diagram
4.        Jumpers and settings
5.        LEDs and buttons
6.        Software support
7.        Third party support
8.        Downloads
mmuuss586|  楼主 | 2021-1-29 18:06 | 只看该作者
mmuuss586|  楼主 | 2021-1-29 18:11 | 只看该作者
KEY BENEFITS?
• Integrated high-performance 100Mbps Ethernet transceivers - Compliant with IEEE 802.3/802.3u (Fast Ethernet) - 100BASE-FX support via external fiber transceiver - Loop-back modes - Automatic polarity detection and correction - HP Auto-MDIX
• EtherCAT slave controller - Supports 3 FMMUs - Supports 4 SyncManagers - Distributed clock support allows synchronization with other EtherCAT devices - 4K bytes of DPRAM
• 8/16-Bit Host Bus Interface - Indexed register or multiplexed bus - Allows local host to enter sleep mode until addressed by EtherCAT Master - SPI / Quad SPI support
• Digital I/O Mode for optimized system cost
• 3rd port for flexible network configurations
• Comprehensive power management features - 3 power-down levels - Wake on link status change (energy detect) - Magic packet wakeup, Wake on LAN (WoL), wake on broadcast, wake on perfect DA - Wakeup indicator event signal
• Power and I/O - Integrated power-on reset circuit - Latch-up performance exceeds 150mA per EIA/JESD78, Class II - JEDEC Class 3A ESD performance - Single 3.3V power supply (integrated 1.2V regulator)
• Additional Features - Multifunction GPIOs - Ability to use low cost 25MHz crystal for reduced BOM
• Packaging - Pb-free RoHS compliant 64-pin QFN or 64-pin TQFPEP
• Available in commercial, industrial, and extended industrial* temp. ranges
TARGET APPLICATIONS
• Motor Motion Control
• Process/Factory Automation
• Communication Modules, Interface Cards
• Sensors
• Hydraulic & Pneumatic Valve Systems
• Operator Interfaces
mmuuss586|  楼主 | 2021-1-29 18:12 | 只看该作者
PINOUT DIAGRAM
This table shows how the pinout on LAN9252/3 Pro.
LAN9253 the details of PIN description, Pls refer Datasheet Page12 LAN9253 datasheet
LAN9252 the details of PIN description, Pls refer Datasheet Page12 LAN9252 datasheet
The LAN9252/3 EtherCAT module PIN description as following:
PIN        Notes        PIN        Notes        PIN        Notes
1        GPIO0        2        GPIO1        CS        Chip select
3        GPIO2        4        GPIO3        SCK        SPI Clock
5        GPIO4        6        GPIO5        MISO        SPI data OP
7        GPIO6        8        GPIO7        MOSI        SPI data IP
9        GPIO8        10        GPIO9        IRQ        IRQ
11        GPIO10        12        GPIO11        RST        Reset
13        GPIO12        14        GPIO13        +3.3V        Power supply
15        GPIO14        16        GPIO15        GND        Ground
17        SYNC0        18        SYNC1
mmuuss586|  楼主 | 2021-1-29 18:13 | 只看该作者
Chip set
ADDITIONAL PINS
CHIP MODE SELECTION
Jumper settings as following:
mmuuss586|  楼主 | 2021-1-29 18:14 | 只看该作者
LEDS AND BUTTONS
Designator        Name        Type        Description
D1        D1        INDICATOR        INDICATOR
SOFTWARE SUPPORT
We provide a library for the LAN9252/3 Pro on Microchip page:for LAN9252
https://www.microchip.com/wwwproducts/en/LAN9252
for LAN9253 https://www.microchip.com/wwwproducts/en/LAN9253
as well as a demo application (example), developed using. The demo can run on all the mainboard.
DOWNLOADS
Pls Press Ctrl+click to enter the link
LAN9252 datasheet
LAN9252 all Doc
LAN9252 reference design
LAN9252 Driver
LAN9253 datasheet
LAN925x family Doc
LAN9253 all Doc
LAN9253 reference design
LAN9252 & LAN9253 compare
LAN9253 Driver
13
mmuuss586|  楼主 | 2021-1-29 18:21 | 只看该作者
mmuuss586|  楼主 | 2021-2-1 14:27 | 只看该作者
mmuuss586|  楼主 | 2021-2-6 19:03 | 只看该作者
mmuuss586|  楼主 | 2021-2-13 14:45 | 只看该作者
mmuuss586|  楼主 | 2021-2-20 09:33 | 只看该作者
mmuuss586|  楼主 | 2021-2-25 13:42 | 只看该作者
mmuuss586|  楼主 | 2021-3-1 10:30 | 只看该作者
mmuuss586|  楼主 | 2021-3-11 11:49 | 只看该作者
个人签名:欢迎进入21IC论坛 游名科技:提供直流无刷电机驱动整体解决方案
696
