PMS150CSOP23-6PADAUK-0.91四线流水灯
570|0
34af9uc|  楼主 | 2021-2-28 14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/**************四线流水灯****************/
/*************QQ774145445****************/
/***********快手共同学习STM8*************/
/*******PMS150CSOP23-6PADAUK-0.91********/
//              PMS150-C
//           _______@_______
//      yi--|1 PA4     PA3 6|--er
//          |2 GND     VDD 5|
//      si--|3_PA6_____PA5_4|--san
//  ___第一种显示___      ___第二种显示___      ___第三种显示___     ___第四种显示___
// _|_  _|_  _|_    |    _|_  _|_  _|_    |    _|_  _|_  _|_    |   _|_  _|_  _|_    |
//  @2   @3   @4    @1    @1   @3   @4    @2   @1   @2   @4    @3   @1   @2   @3    @4
//@1----------------------------------------------------------------------------------yi
//@2----------------------------------------------------------------------------------er
//@3----------------------------------------------------------------------------------san
//@4----------------------------------------------------------------------------------si
//原理:用四个三态引脚用拼灯原理可以显示12个发光二极管(3*4=12)
#include        "extern.h"
/****************************************/ //使用手册,mini.c介绍,io的设定
$                yi                out,high
$                yi                out,low
$                yi                in;
$                er                out,high
$                er                out,low
$                er                in
$                san                out,pull
$                san                out,low
$                san                in
$                si                out,high
$                si                out,low
$                si                in
yi                bit                pa.4;
er                bit                pa.3;
san                bit                pa.5;
si                bit                pa.6;
void                xianshi();                //显示
void                yanshi();                //延时
word                xian_a1;                //显示用
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/8                //        SYSCLK=IHRC/4
byte                a1,a2,a3;
a1                =1;                //左移1
while(a1--)
xian_a1                =0b0000_0000_0000_0001;                //初值
a2                        =12;
while(a2--)
        a3                =20;                //50次约1秒
        while(a3--)        {xianshi();}
        xian_a1                <<=1;
a1                =1;                //右移1
while(a1--)
xian_a1                =0b0000_1000_0000_0000;                //初值
a2                        =12;
while(a2--)
        a3                =10;                //50次约1秒
        xian_a1                >>=1;
while(1)                //心跳
word                b1,b2;
b1=0b0000_0000_0100_0000;
b2=0b0000_0000_0010_0000;
xian_a1                =0;
a2                        =5;
while(a2--)
xian_a1                |=b1;
xian_a1                |=b2;
a3        =5;        while(a3--)        {xianshi();}
b1                        <<=1;
b2                        >>=1;
b1=0b0000_1111_1100_0000;
b2=0b0000_0000_0011_1111;
xian_a1                =0;
a2                        =5;
while(a2--)
xian_a1                |=b1;
xian_a1                |=b2;
a3        =4;        while(a3--)        {xianshi();}
b1                        >>=1;
b1.5                =0;
b2                        <<=1;
b2.6                =0;
xian_a1                =0;
void                yanshi()                //延时
.delay                10000;
void                xianshi()                //显示
byte                x_b1,x_b2;
x_b1                =xian_a1$1;                //取高八位
x_b2                =xian_a1$0;                //取低八位
$                yi                out,high;                //第一种显示
$                er                in;
$                san                in;
$                si                in;
if(x_b1.3)                {$                er                out,low;}
if(x_b1.2)                {$                san                out,low;}
if(x_b1.1)                {$                si                out,low;}
yanshi();
$                yi                in;                //第二种显示
$                er                out,high;
$                san                in;
$                si                in;
if(x_b1.0)                {$                yi                out,low;}
if(x_b2.7)                {$                san                out,low;}
if(x_b2.6)                {$                si                out,low;}
yanshi();
$                yi                in;                //第三种显示
$                er                in;
$                san                out,high,pull;                //pa5开漏输出
$                si                in;
if(x_b2.5)                {$                yi                out,low;}
if(x_b2.4)                {$                er                out,low;}
if(x_b2.3)                {$                si                out,low;}
yanshi();
$                yi                in;                //第四种显示
$                er                in;
$                san                in;
$                si                out,high;
if(x_b2.2)                {$                yi                out,low;}
if(x_b2.1)                {$                er                out,low;}
if(x_b2.0)                {$                san                out,low;}
yanshi();
4IO流水灯.rar
1.13 KB
发新帖
