[STM32F4]
STM32+SSD1351
506|14
songqian17|  楼主 | 2021-4-12 19:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
屏幕使用的是1.5寸全彩0LED显示屏,在显示使用窗口绘制矩形验证屏幕的时候,发现窗口部分横向背景颜色明显比纵向背景颜色亮很多,想请教一下各位大神有没有遇到过类似的问题,应该如何解决啊
chenho| | 2021-4-12 19:04 | 只看该作者
屏有问题吧;正常的话颜色亮度差不多,是不是背景光LED的影响;
songqian17|  楼主 | 2021-4-12 19:06 | 只看该作者
我现在用的这种OLED屏是通过软件发送指令后经过初始化才能点亮,不是用得背景光这种模式。就是不知道是不是屏幕的问题
gongche| | 2021-4-12 19:08 | 只看该作者
卖家没有提供测试例程吗,下进去试试看是不是屏的问题
huwr| | 2021-4-12 19:10 | 只看该作者
找卖家要测试代码,一般他们都有的。
happy_10| | 2021-4-12 19:11 | 只看该作者
SSD1351 display driver library[size=1.4]The SSD1351 display controller is supported by the RAMTEX SSD1339 display driver library package.
Full GUI display driver C source code. Processor and C compiler independent.
[size=1.3]Graphic library for SSD1351
SSD1351 display controller characteristics
Below is a brief introduction to the main characteristics for the SSD1351 RGBdisplay controller (seen from a software driver design viewpoint).
For information about the SSD1351 driver software support please go to the library description.
SSD1351 device type
COG RGB color display controller for use in small embedded systems with on-chip frame buffer and OLED screen driver .
The SSD1351 supports OLED screens with a size up to 128 x 128 pixels (WxH)
On-chip OLED driver with voltage generator and software controlled intensity regulation.
Frame buffer
RGB pixel resolution (bits per pixel): 16-bit, 18-bit.
SSD1351 frame buffer organization: 128 RGB pixels on scan line, 128 lines.
Processor interfaces on SSD1351
SSD1351 parallel bus interface
Parallel bus types: 8080 bus type and 6800 bus type
Parallel bus size: 8-bit, 16-bit, 18 (32)-bit.
Addressing concept: Indexed bus interface (1 chip select pin + 1 address bit pin (Data/Command))
Serial bus interfaces on SSD1351
SPI bus: 4-wire: /CS, DC, SDIN, SCLK
SPI bus: 3-wire: /CS, SDIN, SCLK
In SPI bus there is no read-back of frame buffer memory
The bus interfaces are all supported by the SSD1351 display driver software package.
Special SSD1351 hardware features:
0-180 degree frame buffer rotation with hardware support
Support for screen driver intensity (contrast) requlation in hardware.
Full driver software support.
bqyj| | 2021-4-12 19:14 | 只看该作者
zhenykun| | 2021-4-12 19:16 | 只看该作者
关于SSD1351驱动全彩OLED的问题,我也遇到类似的情况,请问你最后解决的吗,是怎么解决的?
shimx| | 2021-4-12 19:18 | 只看该作者
应该是屏的质量有问题吧
songqian17|  楼主 | 2021-4-12 19:20 | 只看该作者
其实还是不大明白,我再琢磨琢磨吧,多谢了哈
keaibukelian| | 2021-5-7 10:57 | 只看该作者
换一个显示屏试试看
labasi| | 2021-5-7 10:57 | 只看该作者
背光供电有问题吧
paotangsan| | 2021-5-7 11:01 | 只看该作者
找卖家换一个试试
renzheshengui| | 2021-5-7 11:15 | 只看该作者
换一下接口 横向和纵向的表现换吗
wakayi| | 2021-5-7 11:22 | 只看该作者
看现象是屏幕的问题
