//20200530_tm1651_pfc161测试02
393|0
34af9uc|  楼主 | 2021-6-4 22:19 | 显示全部楼层 |阅读模式
PFC, AN, IO, se, IDT, ck
#include        "extern.h"
tm1651_clk                bit                pb.0;                //tm1651时钟输入
tm1651_dio                bit                pb.7;                //tm1651数据输入输出
void                        tm1651_yanshi();        //tm1651延时
byte                        tm1651_a1;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
/**************************************************/                //start起始
$        tm1651_clk        out;        $        tm1651_dio        out;
tm1651_clk        =1;
tm1651_dio        =1;
tm1651_yanshi();
tm1651_dio        =0;
tm1651_yanshi();
/**************************************************/                //data数据
tm1651_a1        =0b1000_1011;
tm1651_clk        =0;        tm1651_yanshi();
if(tm1651_a1.0)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}                //bit0(先发低)
tm1651_clk        =1;        tm1651_yanshi();
if(tm1651_a1.1)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.2)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.3)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.4)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.5)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.6)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
if(tm1651_a1.7)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
/**************************************************/                //ack应答
$        tm1651_clk        out;        $        tm1651_dio        in,pull;
tm1651_clk        =0;        tm1651_yanshi();                //第八个时钟的下降沿
while(tm1651_dio==0){nop;}                                //ack
while (1)
void                        tm1651_yanshi()        //tm1651延时
.delay        5000;
发新帖
