pfc161+tm1651
365|0
34af9uc|  楼主 | 2021-6-8 23:59 | 显示全部楼层 |阅读模式
AN, PA7, PFC, IO, AN, IDT
/*****************pfc161+tm1651********************/
/******************20210608************************/
/****************qq:774145445**********************/
/****************快手:共同学习stm8*****************/
//               _______    ______
//          dio-|1 pb7  \_/  pb010|-clk
//              |2 vdd       gnd 9|
//        cs-||-|3 pa7       pa0 8|-hong
//          tk8-|4 pa6       pa4 7|-lv
//          tk9-|5_pa5_______pa3_6|-lan
//       5v
//  pb0--clk
//  pb7--dio
//       gnd
#include        "extern.h"
tm1651_clk                bit                pb.0;
tm1651_dio                bit                pb.7;
byte                tm1651_a1;
void                tm1651_yanshi();                //延时
void                tm1651_start();                        //起始信号
void                tm1651_data();                        //数据
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                tm1651_clk                out,high;                //输出,高
$                tm1651_dio                out,high;
tm1651_start();
tm1651_yanshi();
while (1)
tm1651_clk                =1;
tm1651_clk                =0;
void                tm1651_yanshi()                //延时
.delay 50;
void                tm1651_start()                        //起始信号
tm1651_clk                =1;
tm1651_dio                =1;
tm1651_yanshi();
tm1651_dio                =0;
tm1651_yanshi();
void                tm1651_data()                        //数据
byte        tm1651_b1;
byte        tm1651_b2;
byte        tm1651_b3;
tm1651_b1        =tm1651_a1;
tm1651_b2        =8;
while(tm1651_b2--)
tm1651_clk                =0;
nop; nop; nop;
if(tm1651_b1 && 0x01)        {tm1651_dio        =1;}        else{tm1651_dio        =0;}
tm1651_clk                =1;
nop; nop; nop;
tm1651_b1                >>=1;
tm1651_clk                =0;                //应答
nop; nop; nop;
tm1651_clk                =1;                //第九脉冲
nop; nop; nop;
$                tm1651_dio                in,pull;
nop; nop; nop;
while(tm1651_dio){nop;}
$                tm1651_dio                out,low;
nop; nop; nop;
tm1651_clk                =0;
nop; nop; nop;
发新帖
