[AT32F421]
串口1复用测试不通过,原厂技术支持请回复。-done
3225|5
芯片型号 AT32F421C8T6,串口1默认在PA9和PA10,布板原因,把端口改到了PB6和PB7。现在调试不通过,代码如下:
#define USART1_TX_PORT       GPIOB
#define USART1_TX_PIN        GPIO_Pins_6
#define USART1_TX_SOURCE     GPIO_PinsSource6
#define USART1_TX_AF         GPIO_AF_1
#define USART1_RX_PORT       GPIOB
#define USART1_RX_PIN        GPIO_Pins_7
#define USART1_RX_SOURCE     GPIO_PinsSource7
#define USART1_RX_AF         GPIO_AF_1
#define USART1_GPIO_RCC      RCC_AHBPERIPH_GPIOB
static void bsp_InitHardUART(void)
    GPIO_InitType GPIO_InitStructure;
    USART_InitType USART_InitStructure;
#if USART1_EN
    RCC_AHBPeriphClockCmd(USART1_GPIO_RCC, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_USART1, ENABLE);
    GPIO_StructInit(&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
    GPIO_InitStructure.GPIO_Pins = USART1_TX_PIN;
    GPIO_InitStructure.GPIO_OutType = GPIO_OutType_PP;
    GPIO_Init(USART1_TX_PORT, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pins = USART1_RX_PIN;
    GPIO_InitStructure.GPIO_Pull = GPIO_Pull_PU;
    GPIO_Init(USART1_RX_PORT, &GPIO_InitStructure);
    GPIO_PinAFConfig(USART1_TX_PORT, USART1_TX_SOURCE, USART1_TX_AF);
    GPIO_PinAFConfig(USART1_RX_PORT, USART1_RX_SOURCE, USART1_RX_AF);
    USART_InitStructure.USART_BaudRate = USART1_BAUD;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;                          /* ֹͣλ */
    USART_InitStructure.USART_Parity = USART_Parity_No;                             /* ¼ìÑéλ */
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; /* Ó²¼þÁ÷¿Ø */
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                 /* ģʽ */
    USART_Init(USART1, &USART_InitStructure);
    USART_INTConfig(USART1, USART_INT_RDNE, ENABLE);
    USART_Cmd(USART1, ENABLE);
#endif
不知道代码哪里有问题,请大家帮助看看!
hoop| | 2021-6-19 14:35 | 只看该作者
你的AF配置错误,请参考RM
78730460|  楼主 | 2021-6-22 21:10 | 只看该作者
hoop 发表于 2021-6-19 14:35
你的AF配置错误,请参考RM
#define USART1_TX_AF         GPIO_AF_0
#define USART1_RX_AF         GPIO_AF_0
改成这样测试依然收不到串口数据
78730460|  楼主 | 2021-6-22 21:19 | 只看该作者
你的AF配置错误,请参考RM
skyred| | 2021-7-3 10:47 | 只看该作者
这种情况,检查引脚分配和初始化部分
