按键蜂+鸣器_05
456|0
34af9uc|  楼主 | 2021-6-20 09:37 | 显示全部楼层 |阅读模式
/*****************按键蜂+鸣器**********************/
/*****************qq:774145445*********************/
/*****************快手:共同学习stm8****************/
/*****************IDE:PADAUK_0.91******************/
/********完成功能:按键按几次蜂鸣器响几次***********/
/*****************20210617*************************/
//             _______    ______
//           -|vdd    \_/    gnd|-
//    anjian -|pa7  pms150g  pa0|- led
//           -|pa6           pa4|- fengmingqi
//           -|pa5___________pa3|-
#include        "extern.h"
io_fengmingqi                bit                pa.4;
io_anjian                        bit                pa.7;
io_led                                bit                pa.0;
byte                anjian_a1;                        //按键标志位
byte                anjian_b1;                        //按键次数
byte                anjian_c1;                        //按键退出条件
byte                anjian_c2;                        //按键退出条件
byte                fengmingqi_a1;                //蜂鸣器标志位
byte                fengmingqi_a2;                //蜂鸣器次数
void                fengmingqi();                //蜂鸣器
void                anjian();                        //按键
void                yanshi();                        //延时
void                fengmingqi_yanshi();//蜂鸣器延时
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                io_fengmingqi                out,low;                //输出低
$                io_anjian                        in,pull;                //输入上拉
$                io_led                                out,high;                //输出高
anjian_a1                =1;                //0不检测,1检测,2计算次数
anjian_b1                =0;
anjian_c1                =0;
anjian_c2                =0;
fengmingqi_a1                =0;
fengmingqi_a2                =0;
while (1)
anjian();
fengmingqi();
yanshi();
void                        fengmingqi()                //蜂鸣器
word                fengmingqi_b1;
if(fengmingqi_a1==1)
fengmingqi_a1                =0;
while(fengmingqi_a2--)                //次数
fengmingqi_b1                =1000;
while(fengmingqi_b1--)
        if(io_fengmingqi){io_fengmingqi=0;}        else{io_fengmingqi=1;}
        io_fengmingqi                =0;
fengmingqi_a2                =0;
anjian_a1                        =1;                //开始检测按键
if(io_led){io_led        =0;}        else{io_led        =1;}
void                        anjian()                        //按键(标志位版带释放)
if(anjian_a1==1)                //0不检测,1检测,2计算次数
if(io_anjian==0)
        anjian_a1                =2;
        anjian_c1                =200;                //2秒退出条件
        anjian_c2                =200;
if(anjian_a1==2)
if(anjian_c1 >0)                //退出条件1
        if(io_anjian==0)
                {yanshi();}
        if(io_anjian==0)
                yanshi();
                while(io_anjian==0)
                        yanshi();
                        anjian_c1                --;
                        if(anjian_c1 ==0)                //退出
                                anjian_a1                =0;
                                fengmingqi_a1        =1;                //打开蜂鸣器
                                fengmingqi_a2        =anjian_b1;                //蜂鸣器次数
                                anjian_b1                =0;
                anjian_b1                ++;                //按键次数+1
                anjian_c1                =200;                //续2秒时间
                anjian_c2                =200;
if(anjian_c2 >0)                //退出条件2
        anjian_c2                --;
        if(anjian_c2 ==0)
                anjian_a1                =0;
                anjian_b1                =0;
void                yanshi()                        //延时
.delay                20000;
void                fengmingqi_yanshi()                //蜂鸣器延时
.delay        2500;
按键蜂鸣器.rar
3.22 KB
发新帖
