[DemoCode下载]
硬件除法器使用方法
3748|6
玛尼玛尼哄|  楼主 | 2021-6-20 20:44 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
* $Revision: 3 $
* $Date: 14/01/28 11:44a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC029 Series Timer Controller and Watchdog Timer Driver Sample Code
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xAN.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCON &= ~CLK_PWRCON_XTL12M_EN_Msk;
    CLK->PWRCON |= (0x1 << CLK_PWRCON_XTL12M_EN_Pos); // XTAL12M (HXT) Enabled
    /* Waiting for 12MHz clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Enable IP clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk; // UART Clock Enable
    /* Select IP clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
    CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UART_S_Pos);// Clock source from external 12 MHz
    /* Set P30(RXD0),P31(TXD0) multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
void UART0_Init(void)
    /* Init UART        */
    /* Configure UART0 and set UART0 Baudrate */
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
void HDIV_Init(void)
    /* Enable Hardware Divider Clock */
    CLK->AHBCLK |= CLK_AHBCLK_HDIV_EN_Msk;
/*  MAIN function        */
int main(void)
    /* Disable register write-protection function */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init Divider */
    HDIV_Init();
    printf("+----------------------------------------------+\n");
    printf("|       Divider Sample Code                    |\n");
    printf("\n");
    printf("12341 / 123 = %d\n", HDIV_Div(12341, 123));
    printf("12341 %% 123 = %d\n", HDIV_Mod(12341, 123));
    /* Lock protected registers */
    SYS_LockReg();
    printf("Done\n");
    while(SYS->PDID);
    return 0;
玛尼玛尼哄|  楼主 | 2021-6-20 20:47 | 显示全部楼层
直接用库函数就可以调用硬件除法器了。
mutable| | 2021-7-9 14:14 | 显示全部楼层
一直不清楚那种带硬件乘法器,除法器的片子,到底怎么用
zhengshuai888| | 2021-7-10 13:42 | 显示全部楼层
所谓硬件乘除法器只需要调用接口,由硬件完成乘除法。
734774645| | 2021-7-25 22:45 | 显示全部楼层
就是一个外设吧。通过电路实现计算。
li880wert| | 2021-8-2 17:44 | 显示全部楼层
这个功能很ji累,又不是带除法指令,整数除本来就很快了,要不了几个周期,还整个硬件寄存器除
caigang13| | 2021-8-2 21:21 | 显示全部楼层
没有硬件乘法器实用
