F460 DMA串口发送 软件AOS触发问题
3541|1
woai32lala|  楼主 | 2021-7-30 17:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
F460 的DMA串口发送  软件AOS触发不了
#define USART_DMA_UNIT                     (M4_DMA1)
#define RX_DMA_CH                          (DmaCh0)
#define RX_DMA_TRG_SEL                     (EVT_USART1_RI)
#define TX_DMA_CH                          (DmaCh1)
#define TX_DMA_TRG_SEL                     (EVT_USART1_TI)
/* DMA block transfer complete interrupt */
#define RX_DMA_BTC_INT_NUM                 (INT_DMA1_TC0)
#define RX_DMA_BTC_INT_IRQn                (Int006_IRQn)
#define TX_DMA_BTC_INT_NUM                 (INT_DMA1_TC1)
#define TX_DMA_BTC_INT_IRQn                (Int005_IRQn)
void dma_tx_init(void)
    stc_dma_config_t stcDmaInit;
    stc_irq_regi_conf_t stcIrqRegiCfg;
    /* Enable peripheral clock */
    PWC_Fcg0PeriphClockCmd(PWC_FCG0_PERIPH_DMA1 | PWC_FCG0_PERIPH_DMA2,Enable);
    /* Enable DMA. */
    DMA_Cmd(USART_DMA_UNIT,Enable);
    /* Initialize DMA. */
    MEM_ZERO_STRUCT(stcDmaInit);
    stcDmaInit.u16BlockSize = 10u; /* 1 block */
    stcDmaInit.u32SrcAddr = ((uint32_t)(send_buff)); /* Set source address. */
    stcDmaInit.u32DesAddr = (uint32_t)(&USART_CH->DR);     /* Set destination address. TDR*/
    stcDmaInit.stcDmaChCfg.enLlpEn = Disable;         /* Disable linked list transfer. */
    stcDmaInit.stcDmaChCfg.enSrcInc = AddressIncrease;  /* Set source address mode. */
    stcDmaInit.stcDmaChCfg.enDesInc = AddressFix;  /* Set destination address mode. */
    stcDmaInit.stcDmaChCfg.enIntEn = Enable;       /* Enable interrupt. */
    stcDmaInit.stcDmaChCfg.enTrnWidth = Dma8Bit;   /* Set data width 8bit. */
    stcDmaInit.u16TransferCnt = 1;
    DMA_InitChannel(USART_DMA_UNIT, TX_DMA_CH, &stcDmaInit);
    /* Enable the specified DMA channel. */
    DMA_ChannelCmd(USART_DMA_UNIT, TX_DMA_CH, Enable);
    /* Clear DMA flag. */
    DMA_ClearIrqFlag(USART_DMA_UNIT, TX_DMA_CH, TrnCpltIrq);
    /* Enable peripheral circuit trigger function. */
    PWC_Fcg0PeriphClockCmd(PWC_FCG0_PERIPH_PTDIS,Enable);
    /* Set DMA trigger source. */
    DMA_SetTriggerSrc(USART_DMA_UNIT, TX_DMA_CH, EVT_AOS_STRG);
    /* Set DMA block transfer complete IRQ */
    stcIrqRegiCfg.enIRQn = TX_DMA_BTC_INT_IRQn;
    stcIrqRegiCfg.pfnCallback = &Dma_TX_IrqCallback;
    stcIrqRegiCfg.enIntSrc = TX_DMA_BTC_INT_NUM;
    enIrqRegistration(&stcIrqRegiCfg);
    NVIC_SetPriority(stcIrqRegiCfg.enIRQn, DDL_IRQ_PRIORITY_DEFAULT);
    NVIC_ClearPendingIRQ(stcIrqRegiCfg.enIRQn);
    NVIC_EnableIRQ(stcIrqRegiCfg.enIRQn);
   AOS_SW_Trigger();
以上就是初始化,没法正常输出,有时候会输出一个字节
还想请问下 block是指 的是一次发送数据的量吧,u16TransferCnt 这个是指发送数据的次数  总数据量应该是 block*u16TransferCnt 吧。不知道这里有没有理解错误
woai32lala|  楼主 | 2021-7-30 17:43 | 只看该作者
请各位大佬麻烦帮忙看一下,好几天一直没进展,谢谢各位了
