[PIC®/AVR®/dsPIC®产品]
PIC18F系列单片机EEPROM可以操作多少次?
1796|3
jack^wu|  楼主 | 2021-10-21 09:52 | 显示全部楼层 |阅读模式
lcczg| | 2021-10-21 10:20 | 显示全部楼层
具体芯片的数据手册里有EEPROM endurance.
海滨消消| | 2021-10-21 10:55 | 显示全部楼层
看看数据手册
MianQi| | 2021-10-21 19:16 | 显示全部楼层
Special Microcontroller Features:
• C Compiler Optimized Architecture with Optional
Extended Instruction Set
• 100,000 Erase/Write Cycle Enhanced Flash
Program Memory Typical
• 1,000,000 Erase/Write Cycle Data EEPROM
Memory Typical
• Flash/Data EEPROM Retention: > 40 Years
地址:https://ww1.microchip.com/downloads/en/devicedoc/39632e.pdf
