[STM32F1] stm32 gpio直接驱动数码管做动态扫描没有反应
738|1
 楼主| qqjmjso 发表于 2022-8-31 19:51 | 显示全部楼层 |阅读模式
#include"main.h"
const uint32_t SEG_SegPins[]=
        GPIO_PIN_0,GPIO_PIN_1,GPIO_PIN_2,GPIO_PIN_3,GPIO_PIN_4,GPIO_PIN_5,GPIO_PIN_6,GPIO_PIN_7,
const uint32_t SEG_DigPins[]=
        GPIO_PIN_8,GPIO_PIN_9,GPIO_PIN_10,GPIO_PIN_11,
void Seg_Init(void);
void Seg_DisplaySingleDigit(uint8_t n);
void Seg_DynamicScan(uint8_t n1,uint8_t n2,uint8_t n3,uint8_t n4);
int main(void)
uint32_t tsStart;
uint32_t counter=0;
uint8_t n1,n2,n3,n4;
HAL_Init();
Seg_Init();
while(1)
         tsStart=HAL_GetTick();
         n1=(counter/1000)%10;
         n2=(counter/100)%10;
         n3=(counter/10)%10;
         n4=counter%10;
         while(HAL_GetTick()-tsStart >=1000)
                 Seg_DynamicScan(n1,n2,n3,n4);
    counter++;
void Seg_Init(void)
        GPIO_InitTypeDef gpioinit;
        uint32_t i;
    //1.初始化数码管的段选引脚
        gpioinit.Mode=GPIO_MODE_OUTPUT_PP;
        gpioinit.Speed=GPIO_SPEED_FREQ_LOW;
        __HAL_RCC_GPIOA_CLK_ENABLE();
        for(i=0;i<8;i++)
                gpioinit.Pin=SEG_SegPins[i];
        HAL_GPIO_WritePin(GPIOA,SEG_SegPins[i],GPIO_PIN_RESET);
        HAL_GPIO_Init(GPIOA,&gpioinit);
         //2.初始化数码管的位选引脚
                for(i=0;i<4;i++)
                        gpioinit.Pin=SEG_DigPins[i];
                HAL_GPIO_WritePin(GPIOA,SEG_DigPins[i],GPIO_PIN_SET);
        const uint8_t font[]=
                        0x3f,0x06,0x5B,0x4F,0x66,0x6D,0X7D,0X07,0X7F,0X6F
     uint32_t i;
     for(i=0;i<8;i++)
       if((font[n] & (0x1 << i))!=0)
               HAL_GPIO_WritePin(GPIOA,SEG_SegPins [i],GPIO_PIN_SET);
       else
               HAL_GPIO_WritePin(GPIOA,SEG_SegPins [i],GPIO_PIN_RESET);
     uint32_t i, j;
     uint8_t numbers[4];
     numbers[0]=n1;
     numbers[1]=n2;
     numbers[2]=n3;
     numbers[3]=n4;
     for(i=0;i<4;i++)
      for(j=0;j<4;j++)
             HAL_GPIO_WritePin(GPIOA,SEG_DigPins[j],GPIO_PIN_SET);
      Seg_DisplaySingleDigit(numbers[i]);
      HAL_GPIO_WritePin(GPIOA,SEG_DigPins[i],GPIO_PIN_RESET);
      HAL_Delay(10);
c17 发表于 2022-8-31 23:58 | 显示全部楼层
必须将这两个管脚复用为普通的GPIO管脚,
