谁给推荐个5.2V,2A输出升压IC,输入3.7V
2060|13
PT99| | 2012-8-16 10:41 | 显示全部楼层
FP6291.pdf (454.31 KB)
yanemperor| | 2012-8-16 12:14 | 显示全部楼层
楼上的,你的开关管的开关电流才2A,输出能到2A吗?
其实我也在找,但没找到便宜的
lyjian| | 2012-8-17 08:28 | 显示全部楼层
tps61030
PT99| | 2012-8-17 09:50 | 显示全部楼层
FP6293 ALLEN.ZHANG QQ 1357569351.PDF (462 KB)
fujunxian| | 2012-8-17 12:14 | 显示全部楼层
收藏 学习
jany.wei| | 2012-8-17 12:21 | 显示全部楼层
hbtsljg| | 2012-8-17 15:55 | 显示全部楼层
收藏了,学习中。顶起来!
zhoulvxingfu| | 2012-8-17 16:54 | 显示全部楼层
你好,我这边有2A以上的升压IC,可提供DEMO板,可以加我QQ:1450531601,谢谢
FP5139| | 2012-8-18 13:17 | 显示全部楼层
FP6291不行,电流不够,AM3309,FP5139,ME2139可以
我QQ1592475680
mikeldm| | 2012-8-19 12:13 | 显示全部楼层
你可以用ME2109,需外置MOS,价格才几毛钱,定能满足你的要求,或者加入“移动电源开发技术讨论”QQ群:250087630,里面高手云集
trevor2011| | 2012-11-7 12:13 | 显示全部楼层
http://www.ti.com/product/tps61030
The TPS6103x devices provide a power supply solution for products powered by either a one-cell Li-Ion or Li-polymer, or a two to three-cell alkaline, NiCd or NiMH battery. The converter generates a stable output voltage that is either adjusted by an external resistor divider or fixed internally on the chip. It provides high efficient power conversion and is capable of delivering output currents up to 1 A at 5 V at a supply voltage down to 1.8 V. The implemented boost converter is based on a fixed frequency, pulse-width- modulation (PWM) controller using a synchronous rectifier to obtain maximum efficiency. At low load currents the converter enters Power Save mode to maintain a high efficiency over a wide load current range. The Power Save mode can be disabled, forcing the converter to operate at a fixed switching frequency. It can also operate synchronized to an external clock signal that is applied to the SYNC pin. The maximum peak current in the boost switch is limited to a value of 4500 mA.
The converter can be disabled to minimize battery drain. During shutdown, the load is completely disconnected from the battery. A low-EMI mode is implemented to reduce ringing and, in effect, lower radiated electromagnetic energy when the converter enters the discontinuous conduction mode.
The device is packaged in a 16-pin QFN package measuring 4 mm x 4 mm (RSA) or in a 16-pin TSSOP PowerPAD package (PWP).
http://www.ti.com/product/tps61087
The TPS61087 is a high frequency, high efficiency DC to DC converter with an integrated 3.2 A, 0.13  power switch capable of providing an output voltage up to 18.5 V. The selectable frequency of 650 kHz or 1.2 MHz allows the use of small external inductors and capacitors and provides fast transient response. The external compensation allows optimizing the application for specific conditions. A capacitor connected to the soft-start pin minimizes inrush current at startup.
