DSP 调试问题 error #10234-D: unresolved symbols remain
16073|12
瓦地|  楼主 | 2013-1-30 11:43 | 显示全部楼层 |阅读模式
大家好,
新人一枚,请大家多多指教!
我用的板子是TMDXEVM6678L,新建一个工程,拷贝了helloworld例程中的".c"和".cfg"文件,"Build Project"出错,输出如下:
**** Build of configuration Debug for project InternetPingPong ****
C:\ti\ccsv5\utils\bin\gmake -k all
'Building target: InternetPingPong.out'
'Invoking: C6000 Linker'
"C:/ti/ccsv5/tools/compiler/c6000/bin/cl6x" -mv6600 -g --
display_error_number --diag_warning=225 --abi=eabi -z -
m"InternetPingPong.map" --warn_sections -
i"C:/ti/ccsv5/tools/compiler/c6000/lib" -
i"C:/ti/ccsv5/tools/compiler/c6000/include" --reread_libs --rom_model -o
"InternetPingPong.out" -l"./configPkg/linker.cmd"  "./resourcemgr.obj"
"./platform_osal.obj" "./NetThread.obj" "./MainThread.obj" -l"libc.a"
<Linking>
warning #10247-D: creating output section ".myDDRsect" without a
SECTIONS
   specification
undefined        first referenced
  symbol              in file
Osal_paMtCsEnter C:\ti\pdk_C6678_1_0_0_20\packages\ti\drv\pa\lib
\ti.drv.pa.ae66<pa.oe66>
Osal_paMtCsExit  C:\ti\pdk_C6678_1_0_0_20\packages\ti\drv\pa\lib
error #10010: errors encountered during linking; "InternetPingPong.out" not
   built
尝试改正方法:
Include Options—>"${TI_PDK_C6678_INSTALL_DIR}/packages/ti/drv/pa"
File Search Path—>"${TI_PDK_C6678_INSTALL_DIR}/packages/ti/drv/pa/lib\ti.drv.pa.ae66"
但是错误还在,是加入文件路径的方法不对吗?
先谢过各位了!
pmp| | 2013-1-30 12:38 | 显示全部楼层
**好了软件了?
zrsing| | 2013-1-31 09:20 | 显示全部楼层
不太懂啊
582114482| | 2015-5-4 09:23 | 显示全部楼层
同问同问,怎么解决的
error #10010: errors encountered during linking; "EvPwm01.out" not built
wmqwmq| | 2015-5-16 15:20 | 显示全部楼层
582114482 发表于 2015-5-4 09:23
同问同问,怎么解决的
error #10010: errors encountered duri ...
我也是我也是。怎么弄啊
shanyeqiaofu| | 2015-8-8 09:48 | 显示全部楼层
求解?
lgt12002| | 2016-5-4 17:48 | 显示全部楼层
error #10010: errors encountered during linking; "TWO_GPIO_Led.out" not built
zcl_l| | 2017-1-18 16:45 | 显示全部楼层
这个缺少相应的文件造成的。
kkzz| | 2017-1-18 22:55 | 显示全部楼层
C:/ti/ccsv5/tools/compiler/c6000/lib 这个路径正确吗
kkzz| | 2017-1-18 22:58 | 显示全部楼层
C:/ti/ccsv5/tools/compiler/c6000/lib 感觉这个目录存在问题
xiaoyaodz| | 2017-1-19 22:41 | 显示全部楼层
找不到定义的
xiaoyaodz| | 2017-1-19 22:44 | 显示全部楼层
点击错误看看定位到哪里
狼烟客| | 2018-9-4 14:19 | 显示全部楼层
是不是定义 Osal_paMtCsEnter 、Osal_paMtCsExit 变量或函数的文件没有被包含到工程里面?
