哪位高手请指点一下
974|0
lixingde|  楼主 | 2008-10-16 23:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   小弟现在在做多功能红外遥控器。
   下面是一段资料里的汇编程序,但我是从C51入门的,所以有些看得不大懂。还望哪位高手指点一下各段子程序的功能。
   程序清单
    伪定义:
            KEYX0   EQU   P1.0
            KEYX1   EQU   P1.1
            KEYX2   EQU   P1.2
            KEYX3   EQU   P1.3
            KEYY    EQU   P0
                 主 程 序 和 中 断 程 序 入 口
    ORG     0000H
    ORG     AJMP   START
    ORG     0003H
             RETI
    ORG     000BH
             RETI
    ORG     0013H
             RETI
    ORG     001BH
             LJMP   INTT1
    ORG     0023H
             RETI
    ORG     002BH
             RETI
                      初 始 化 程 序
CLEARMEMIO:  CLR   A
             DEC   A
             MOV   P0,A
             MOV   P1,A
             MOV   P2,A
             MOV   P3,A
             CLR   P3.5
CLEARMEM:    MOV   SP,#70H
             MOV   IE,#00H
             MOV   IP,#01H
             MOV   TMOD,#22H
             MOV   TH1,#0F3H
             MOV   TL1,#0F3H
             SETB  EA //开总中断
             RET
主程序
START:       LCALL   CLEARMEMIO
MAIN:        LCALL   KEYWORK
             LJMP    MAIN
             NOP
             NOP
             NOP
             LJMP    START
;                  T1中断服务程序
INTT1:       CPL     P3.5
             RET1
KEYWORK:     MOV     KEYY,#0FFH
             CLR     KEYX0
             CLR     KEYX1
             CLR     KEYX2
             CLR     KEYX3
             MOV     A,KEYY
             MOV     B,A
             CLNE    A,#0FFH,KKEYHIT
KEYOUT:      RET
KEYHIT:      LCALL    DL10MS
             MOV      A,KEYY
             CJNE     A,B,KEYOUT
             SETB     KEYX1
             SETB     KEYX2
             SETB     KEYX3
             MOV      A,KEYY
             CJNE     A,#0FFH,KEYVAL0
             SETB     KEYX0
             CLR      KEYX1
             MOV      A,KEYY
             CJNE     A,#0FFH,KEYVAL1
             SETB     KEYX1
             CLR      KEYX2
             MOV      A,KEYY
             CJNE     A,#0FFH,KEYVAL2
             SETB     KEYX2
             CLR      KEYX3
             MOV      A,KEYY
             CJNE     A,#0FFH,KEYVAL3
             LJMP     KEYOUT
KEYVAL0:     MOV      R2,#00H
             LJMP     KEYVAL4
KEYVAL1:     MOV      R2,#08H
             LJMP     KEYVAL4
KEYVAL2:     MOV      R2,#10H
             LJMP     KEYVAL4
KEYVAL3:     MOV      R2,#18H
             LJMP     KEYVAL4
KEYVAL4:     MOV      DPTR,#KEYVALTAB
             MOV      B,A
             CLR      A
             MOV      R0,A
KEYVAL5:     MOV      A,R0
             SUBB     A,#08H
             JNC      KEYOUT
             MOV      A,R0
             MOVC     A,@A+DPTR
             INC      R0
             CJNE     A,B,KEYVAL5
             DEC      R0
             MOV      A,R0
             ADD      A,R2
             MOV      B,A
             RL       A
             ADD      A,B
             MOV      DPTR,#KEYFUNTAB
             JMP      @A+DPTR
KEYFUNTAB:   LJMP     KEYFUN00
             LJMP     KEYFUN01
             LJMP     KEYFUN02
             LJMP     KEYFUN03
             LJMP     KEYFUN04
             LJMP     KEYFUN05
             LJMP     KEYFUN06
             LJMP     KEYFUN07
KEYVALTAB    DB      0FEH,0FDH,0FBH,0F7H,0EFH,ODFH,0BFH,7FH;
             RET
KEYFUN00:    MOV      A,#02H
             LJMP     REMOTE
             RET
KEYFUN01:    MOV      A,#03H
             LJMP     REMOTE
             RET
KEYFUN02:    MOV      A,#04H
             LJMP     REMOTE
             RET
KEYFUN03:    MOV      A,#05H
             LJMP     REMOTE
             RET
KEYFUN04:    MOV      A,#06H
             LJMP     REMOTE
             RET
KEYFUN05:    MOV      A,#07H
             LJMP     REMOTE
             RET
KEYFUN06:    MOV      A,#08H
             LJMP     REMOTE
             RET
KEYFUN07:    MOV      A,#09H
             LJMP     REMOTE
             RET
    编码发射程序
REMOTE:      MOV      R1,A
             LJMP     OUT3
OUT:         MOV      R0,#55H
OUT1:        SETB     ET1//开定时器中断
             SETB      TR1//启动定时器
             NOP
             NOP
             NOP
             NOP
             NOP
             DJNZ      R0,OUT1
             MOV       R0,#32H
OUT2:        CLR       TR1
             CLR       ET1
             CLR       P3.5
             NOP
             NOP
             NOP
             NOP
             NOP
             DJNZ       R0,OUT2
             DJNZ       R1,OUT
             LCALL      DL500MS
             RET
OUT3:        MOV        R0,#0FFH
             LJMP       OUT1
    延时513μS
DELAY:       MOV        R2,#0FFH
DELAY1:      DJNZ       R2,DELAY1
             RET
    10ms延时程序
DL10MS:      MOV        R3,#14H
DL10MS1:     LCALL      DELAY
             DJNZ       R3,DL10MS1
             RET
             END
