【GD32测试】+TFT LCD显示
26529|666
gaochy1126|  楼主 | 2013-8-13 23:29 | 显示全部楼层 |阅读模式
评分
参与人数 1威望 +5 收起 理由
永远的不知 + 5 很给力!
代码:
#include "stm32f10x.h"
#include "16x8.h"
#include "OV7670.h"
#include "delay.h"
#define uint unsigned int
#define        uchar unsigned char
#define LCD_RD0 GPIO_ResetBits(GPIOA,GPIO_Pin_0)
#define LCD_WR0 GPIO_ResetBits(GPIOA,GPIO_Pin_1)
#define LCD_RS0 GPIO_ResetBits(GPIOA,GPIO_Pin_2)
#define LCD_CS0 GPIO_ResetBits(GPIOA,GPIO_Pin_3)
#define LCD_REST0 GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define LCD_RD1 GPIO_SetBits(GPIOA,GPIO_Pin_0)
#define LCD_WR1 GPIO_SetBits(GPIOA,GPIO_Pin_1)
#define LCD_RS1 GPIO_SetBits(GPIOA,GPIO_Pin_2)
#define LCD_CS1 GPIO_SetBits(GPIOA,GPIO_Pin_3)
#define LCD_REST1 GPIO_SetBits(GPIOA,GPIO_Pin_4)
void init_Gpio()
        GPIO_InitTypeDef        GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);   //使能PA端口时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;//GPIO_Pin_7 |GPIO_Pin_6 |GPIO_Pin_5 |GPIO_Pin_4 |GPIO_Pin_3 |GPIO_Pin_2 |GPIO_Pin_1 |GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);   //使能PA端口时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_3 |GPIO_Pin_2 |GPIO_Pin_1 |GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;        //推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStructure);
void delayms(int count)  // /* X1ms */
        int i,j;
        for(i=0;i<count;i++)
          for(j=0;j<100;j++);
void LCD_Writ_Bus(unsigned char VH,unsigned char VL)   //????????
        uint temp=0;
        GPIO_Write(GPIOB,(temp |VH)*256);
  LCD_WR0;
        LCD_WR1;
        temp=0;
        GPIO_Write(GPIOB,(temp |VL)*256);
        LCD_WR0;
        LCD_WR1;
void LCD_Write_COM(char VH,char VL)         //????
  LCD_RS0;
        LCD_Writ_Bus(VH,VL);
void LCD_Write_DATA(char VH,char VL)        //????
  LCD_RS1;
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
        LCD_Write_COM(0x00,0x20);LCD_Write_DATA(x1>>8,x1);          //??X????
  LCD_Write_COM(0x00,0x21);LCD_Write_DATA(y1>>8,y1);   //??Y????
  LCD_Write_COM(0x00,0x50);LCD_Write_DATA(x1>>8,x1);   //??X
        LCD_Write_COM(0x00,0x52);LCD_Write_DATA(y1>>8,y1);          //??Y
  LCD_Write_COM(0x00,0x51);LCD_Write_DATA(x2>>8,x2);   //??X
        LCD_Write_COM(0x00,0x53);LCD_Write_DATA(y2>>8,y2);   //??Y
  LCD_Write_COM(0x00,0x22);
void LCD_Init(void)
  LCD_REST1;
  delayms(5);
        LCD_REST0;
        delayms(5);
        LCD_REST1;
        LCD_CS1;
        LCD_RD1;
        LCD_WR1;
        delayms(5);
        LCD_CS0;  //??????
        //************* Start Initial Sequence **********//
        LCD_Write_COM(0x00,0xE5); LCD_Write_DATA(0x78,0xF0); // set SRAM internal timing
        LCD_Write_COM(0x00,0x01); LCD_Write_DATA(0x01,0x00); // set SS and SM bit
        LCD_Write_COM(0x00,0x02); LCD_Write_DATA(0x07,0x00); // set 1 line inversion
        LCD_Write_COM(0x00,0x03); LCD_Write_DATA(0x10,0x30); // set GRAM write direction and BGR=1.
        LCD_Write_COM(0x00,0x04); LCD_Write_DATA(0x00,0x00); // Resize register
        LCD_Write_COM(0x00,0x08); LCD_Write_DATA(0x02,0x07); // set the back porch and front porch
        LCD_Write_COM(0x00,0x09); LCD_Write_DATA(0x00,0x00); // set non-display area refresh cycle ISC[3:0]
        LCD_Write_COM(0x00,0x0A); LCD_Write_DATA(0x00,0x00); // FMARK function
        LCD_Write_COM(0x00,0x0C); LCD_Write_DATA(0x00,0x00); // RGB interface setting
        LCD_Write_COM(0x00,0x0D); LCD_Write_DATA(0x00,0x00); // Frame marker Position
        LCD_Write_COM(0x00,0x0F); LCD_Write_DATA(0x00,0x00); // RGB interface polarity
        //*************Power On sequence ****************//
        LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x00,0x00); // SAP, BT[3:0], AP, DSTB, SLP, STB
        LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x00,0x07); // DC1[2:0], DC0[2:0], VC[2:0]
        LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x00); // VREG1OUT voltage
        LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x00,0x00); // VDV[4:0] for VCOM amplitude
        LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x00,0x01);
        delayms(50); // Dis-charge capacitor power voltage
        LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x10,0x90); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB
        LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x02,0x27); // DC1[2:0], DC0[2:0], VC[2:0]
        delayms(50); // Delay 50ms
        LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x1F); //001C// Internal reference voltage= Vci;
        LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x15,0x00); //0x1000//1400   Set VDV[4:0] for VCOM amplitude  1A00
        LCD_Write_COM(0x00,0x29); LCD_Write_DATA(0x00,0x27); //0x0012 //001a  Set VCM[5:0] for VCOMH  //0x0025  0034
        LCD_Write_COM(0x00,0x2B); LCD_Write_DATA(0x00,0x0D); // Set Frame Rate   000C
        LCD_Write_COM(0x00,0x20); LCD_Write_DATA(0x00,0x00); // GRAM horizontal Address
        LCD_Write_COM(0x00,0x21); LCD_Write_DATA(0x00,0x00); // GRAM Vertical Address
        // ----------- Adjust the Gamma Curve ----------//
        LCD_Write_COM(0x00,0x30); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x31); LCD_Write_DATA(0x07,0x07);
        LCD_Write_COM(0x00,0x32); LCD_Write_DATA(0x03,0x07);
        LCD_Write_COM(0x00,0x35); LCD_Write_DATA(0x02,0x00);
        LCD_Write_COM(0x00,0x36); LCD_Write_DATA(0x00,0x08);//0207
        LCD_Write_COM(0x00,0x37); LCD_Write_DATA(0x00,0x04);//0306
        LCD_Write_COM(0x00,0x38); LCD_Write_DATA(0x00,0x00);//0102
        LCD_Write_COM(0x00,0x39); LCD_Write_DATA(0x07,0x07);//0707
        LCD_Write_COM(0x00,0x3C); LCD_Write_DATA(0x00,0x02);//0702
        LCD_Write_COM(0x00,0x3D); LCD_Write_DATA(0x1D,0x04);//1604
        //------------------ Set GRAM area ---------------//
        LCD_Write_COM(0x00,0x50); LCD_Write_DATA(0x00,0x00); // Horizontal GRAM Start Address
        LCD_Write_COM(0x00,0x51); LCD_Write_DATA(0x00,0xEF); // Horizontal GRAM End Address
        LCD_Write_COM(0x00,0x52); LCD_Write_DATA(0x00,0x00); // Vertical GRAM Start Address
        LCD_Write_COM(0x00,0x53); LCD_Write_DATA(0x01,0x3F); // Vertical GRAM Start Address
        LCD_Write_COM(0x00,0x60); LCD_Write_DATA(0xA7,0x00); // Gate Scan Line
        LCD_Write_COM(0x00,0x61); LCD_Write_DATA(0x00,0x01); // NDL,VLE, REV
        LCD_Write_COM(0x00,0x6A); LCD_Write_DATA(0x00,0x00); // set scrolling line
        //-------------- Partial Display Control ---------//
        LCD_Write_COM(0x00,0x80); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x81); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x82); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x83); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x84); LCD_Write_DATA(0x00,0x00);
        LCD_Write_COM(0x00,0x85); LCD_Write_DATA(0x00,0x00);
        //-------------- Panel Control -------------------//
        LCD_Write_COM(0x00,0x90); LCD_Write_DATA(0x00,0x10);
        LCD_Write_COM(0x00,0x92); LCD_Write_DATA(0x06,0x00);
        LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x01,0x33); // 262K color and display ON
        LCD_CS1;  //??????
void dot(char x,char y,uint color)
  Address_set(x,y,x,y);
  LCD_Write_DATA(color/256,color%256);
void Pant(char VH,char VL)
        int i,j;
        Address_set(0,0,239,319);
    for(i=0;i<320;i++)
          for (j=0;j<240;j++)
                 LCD_Write_DATA(VH,VL);
void printf_char(uchar x, uint y,uchar c, uint color,uint b_color)
        uchar  s_x ,s_y, temp ;
          uint j;
          c -= 32;
          for( s_y=0 ; s_y < 16 ; s_y++ )
                if(s_y+y<320)
                        j=c;
                   j=j*16+s_y;
                   temp=font16x8[j];
                     for( s_x=0 ; s_x<8 ; s_x++ )
                            if(x+s_x<240)
                                     if((temp&(0x80>>(s_x))) == (0x80>>(s_x))  )
                                               dot(x+s_x, y+s_y,color) ;
                                     else
                                             dot(x+s_x, y+s_y,b_color) ;
void printf_string(uchar x, uint y,char  *s, uint color,uint b_color)
        for(;*s!='\0';s++)
                printf_char(x, y,*s, color,b_color);
                x=x+8;
void hanzi32_32(uint x,uint y,uchar *value,uint dcolor,uint bgcolor)
        uint i,j;
  Address_set(x,y,x+31,y+31); //????
        for(j=0;j<128;j++)
                for(i=0;i<8;i++)
                         if((*value&(1<<i))!=0)
                                LCD_Write_DATA(dcolor>>8,dcolor); //?????
                        else
                                LCD_Write_DATA(bgcolor>>8,bgcolor);        //?????
                value++;
void zf32_32(uint y,uint x,uchar *value,uint dcolor,uint bgcolor)
        uint i,j;
  Address_set(x,y,x+15,y+31); //????
        for(j=0;j<64;j++)
                for(i=0;i<8;i++)
                        else
                value++;
int main(void)
        unsigned long TimerCnt = 0;
        unsigned int temp7670 = 0;
        unsigned int value,val,val1,val2;
        SystemInit();                          //系统时钟初始化为72M          SYSCLK_FREQ_72MHz
        init_Gpio();
        LCD_Init();                 //TFT???
        LCD_CS0;
        Pant(0xff,0xff);         //TFT??
        printf_string(10,10,"HELLO ------",0,0x0fff);
        printf_string(10,30,"3KS,21IC ------",0,0xf8ff);
        printf_string(10,50,"3KU,GigaDivice ------",0,0x6fff);
        printf_string(10,70,"www.realsence.com.cn",0,0xff0f);
        while(1);
leikewen 2018-9-17 15:54 回复TA
这是用的GD32的EXMC功能吗
yuchl| | 2013-8-14 09:45 | 显示全部楼层
mark
jack888518| | 2013-8-14 14:46 | 显示全部楼层
piaoyu175816| | 2013-8-14 15:56 | 显示全部楼层
不错,支持国产芯片~
ygl968| | 2013-8-14 16:07 | 显示全部楼层
收藏
xufei043| | 2013-8-14 17:26 | 显示全部楼层
完全兼容ST的FSMC功能。
55854234| | 2013-8-26 19:03 | 显示全部楼层
不错  Mark  学习
gaochy1126|  楼主 | 2013-8-27 09:57 | 显示全部楼层
yuchl 发表于 2013-8-14 09:45
mark
谢谢支持的。
jack888518 发表于 2013-8-14 14:46
谢谢。
gaochy1126|  楼主 | 2013-8-27 09:58 | 显示全部楼层
piaoyu175816 发表于 2013-8-14 15:56
不错,支持国产芯片~
国产芯片要支持的。
ygl968 发表于 2013-8-14 16:07
收藏
谢谢的。
gaochy1126|  楼主 | 2013-8-27 09:59 | 显示全部楼层
xufei043 发表于 2013-8-14 17:26
完全兼容ST的FSMC功能。
没有使用FSMC功能
55854234 发表于 2013-8-26 19:03
不错  Mark  学习
3ks
gygp| | 2013-8-27 15:07 | 显示全部楼层
看着还不错的,谢谢分享的。
只是照片质量不给力的。
gaochy1126|  楼主 | 2013-8-27 15:08 | 显示全部楼层
gygp 发表于 2013-8-27 15:07
看着还不错的,谢谢分享的。
用的宏定义写的,应该还可以吧
gaochy1126|  楼主 | 2013-8-27 15:09 | 显示全部楼层
只是照片质量不给力的。
等自己做个stm32的照相机试试看的。
gygp| | 2013-8-27 15:10 | 显示全部楼层
gaochy1126 发表于 2013-8-27 15:08
用的宏定义写的,应该还可以吧
使用这方法比较简单一些而已。
gaochy1126 发表于 2013-8-27 15:09
等自己做个stm32的照相机试试看的。
建议使用ov7670
个人签名:这个社会混好的两种人:一是有权有势,二是没脸没皮的。
1025
